Domoticz in docker compose
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
Post by BartSr »
Original domoticz container is running in docker (compose)
I am running 'stable' but because of promising updates I want to try the non stable version.
What to change in the docker.yaml file?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
jvdz
Domoticz version: 4.107
Re: Domoticz in docker compose
Post by jvdz »
Just change the image tag to use in your config.
Domoticz version: 2026.3
See also https://wiki.domoticz.com/Docker#docker_image_tags
You cannot revert back to stable as the database datamodel has changed!
Or you need to make a copy of your current domoticz.db from stable and place it back if you want to revert back.
gizmocuz
Post by gizmocuz »
