Original domoticz container is running in docker (compose)
I am running 'stable' but because of promising updates I want to try the non stable version.
What to change in the docker.yaml file?
Domoticz in docker compose
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- jvdz
- Domoticz version: 4.107
Re: Domoticz in docker compose
Just change the image tag to use in your config.
- Domoticz version: 2026.3
See also https://wiki.domoticz.com/Docker#docker_image_tags
You cannot revert back to stable as the database datamodel has changed!
Or you need to make a copy of your current domoticz.db from stable and place it back if you want to revert back.
- gizmocuz
