Getting error 256 when I add import DomoticzEvents as DE
cmisip
Post by cmisip »
If I run a regular python script (via the web UI) without using any domoticz variables, there is no error. It's like my python scripts are not seeing the domoticz python module. I get an error code 256 if I try to import DomticzEvents as DE.
I wish to be able to use domoticz variables in lua or python. I suppose I could just write python sql to adjust the status of devices in the database but working within the domoticz python framework would be easier.
I can't even find the python domoticz module. Where is it installed? it is not in dist-packages.
This is a fresh install on RPI 3 with Trixie. Any ideas?
Thanks,
Chris
cmisip
Re: Getting error 256 when I add import DomoticzEvents as DE
Post by cmisip »
Well, my scripts did not follow the naming convention. When I changed the name to "script_device_halllight.lua", it worked. I wish we had better error logging. Did the same for the python version and it worked, however, the python version is returning error 256.
From the log:
2026-02-22 13:09:30.369 Error: Error executing script command (/home/pi/domoticz/scripts/python/script_device_foyerlight.py). returned: 256
2026-02-22 13:09:32.081 Executed: heyu on B9
Here is the python code:
#!/usr/bin/env python3
import os
TRIGGER_SWITCH = "Foyer Light"
HEYU_ON_CMD = "heyu on B9"
HEYU_OFF_CMD = "heyu off B9"
if DE.changed_device_name == TRIGGER_SWITCH:
    if DE.Devices["Foyer Light"].n_value_string == "On":
       os.system(HEYU_ON_CMD)
       DE.Log(f"Executed: {HEYU_ON_CMD}")
    elif DE.Devices["Foyer Light"].n_value_string == "Off":
        os.system(HEYU_OFF_CMD)
        DE.Log(f"Executed: {HEYU_OFF_CMD}")
Anybody have any ideas why its returning error 256?
Thanks,
Chris
Thorgal789
Post by Thorgal789 »
Have you tried the python script included by defaut to test ?
script_device_demo.py
jvdz
Domoticz version: 4.107
Post by jvdz »
What exactly are you expecting this line to do as that returns the 256?:
cmisip
Post by cmisip »
Its expanded to
heyu on B9
The device is working. I can turn it on and off via lua or python script. However, I get the 256 error in the logs for the python version of the script.
jvdz
Post by jvdz »
I knew that much already, but isn't "os.system('heyu on B9')" trying to run 'heyu on B9' in an os shell?
Is that an existing commandline command in your installation as that seems to returns 256.
cmisip
Post by cmisip »
It has to run in a shell. Its the heyu program which is used to run x10 devices. Its not providingng an error code when its run in a terminal. I am not aware of any other way to do this. It works. It's just annoying to see the errors in the log.
I switched all the scripts to lua:
#!/usr/bin/lua
if (devicechanged['Hall Light'] == 'On') then
	os.execute('sudo -u pi /usr/local/bin/heyu on a6')
elseif (devicechanged['Hall Light'] == 'Off') then
	os.execute('sudo -u pi /usr/local/bin/heyu off a6')
The scripts work. But they display the error.
2026-02-22 20:07:46.998 Error: Error executing script command (/home/pi/domoticz/scripts/lua/script_device_halllight.lua). returned: 256
jvdz
Post by jvdz »
You could try shelling without waiting by adding a & at the end of the commandline.
os.execute('sudo -u pi /usr/local/bin/heyu off a6 &')
cmisip
Post by cmisip »
That eliminated the 256 error in the lua scripts. There is a new error though.
2026-02-23 01:48:09.078 Error: SQLHelper: Error script not found '/lua/script_device_foyerlight.lua'
This is the lua script code:
if (devicechanged['Foyer Light'] == 'On') then
	os.execute('sudo -H -u pi /usr/local/bin/heyu on a1 &')
elseif (devicechanged['Foyer Light'] == 'Off') then
	os.execute('sudo -H -u pi /usr/local/bin/heyu off a1 &')
There doesn't seem to be any negative effects. The lights are still working.
I got the info from here:
https://wiki.domoticz.com/X10_with_CM11a
