Getting error 256 when I add import DomoticzEvents as DE
cmisip
If I run a regular python script (via the web UI) without using any domoticz variables, there is no error. It's like my python scripts are not seeing the domoticz python module. I get an error code 256 if I try to import DomticzEvents as DE.
I wish to be able to use domoticz variables in lua or python. I suppose I could just write python sql to adjust the status of devices in the database but working within the domoticz python framework would be easier.
I can't even find the python domoticz module. Where is it installed? it is not in dist-packages.
This is a fresh install on RPI 3 with Trixie. Any ideas?
Thanks,
Chris
Thanks,
Chris
cmisip
Re: Getting error 256 when I add import DomoticzEvents as DE
Well, my scripts did not follow the naming convention. When I changed the name to "script_device_halllight.lua", it worked. I wish we had better error logging. Did the same for the python version and it worked, however, the python version is returning error 256.
From the log:
Here is the python code:
Anybody have any ideas why its returning error 256?
Thanks,
Chris
From the log:
2026-02-22 13:09:30.369 Error: Error executing script command (/home/pi/domoticz/scripts/python/script_device_foyerlight.py). returned: 256
2026-02-22 13:09:32.081 Executed: heyu on B9Code: Select all
#!/usr/bin/env python3
import os
TRIGGER_SWITCH = "Foyer Light"
HEYU_ON_CMD = "heyu on B9"
HEYU_OFF_CMD = "heyu off B9"
if DE.changed_device_name == TRIGGER_SWITCH:
if DE.Devices["Foyer Light"].n_value_string == "On":
os.system(HEYU_ON_CMD)
DE.Log(f"Executed: {HEYU_ON_CMD}")
elif DE.Devices["Foyer Light"].n_value_string == "Off":
os.system(HEYU_OFF_CMD)
DE.Log(f"Executed: {HEYU_OFF_CMD}")
Thanks,
Chris
Thorgal789
- Target OS: -
Have you tried the python script included by defaut to test ?
script_device_demo.py- jvdz
- Domoticz version: 4.107
What exactly are you expecting this line to do as that returns the 256?:
cmisip
Its expanded to
The device is working. I can turn it on and off via lua or python script. However, I get the 256 error in the logs for the python version of the script.
heyu on B9- jvdz
I knew that much already, but isn't "os.system('heyu on B9')" trying to run 'heyu on B9' in an os shell?
Is that an existing commandline command in your installation as that seems to returns 256.
cmisip
It has to run in a shell. Its the heyu program which is used to run x10 devices. Its not providingng an error code when its run in a terminal. I am not aware of any other way to do this. It works. It's just annoying to see the errors in the log.
I switched all the scripts to lua:
The scripts work. But they display the error.
#!/usr/bin/lua
if (devicechanged['Hall Light'] == 'On') then
os.execute('sudo -u pi /usr/local/bin/heyu on a6')
elseif (devicechanged['Hall Light'] == 'Off') then
os.execute('sudo -u pi /usr/local/bin/heyu off a6')
2026-02-22 20:07:46.998 Error: Error executing script command (/home/pi/domoticz/scripts/lua/script_device_halllight.lua). returned: 256- jvdz
You could try shelling without waiting by adding a & at the end of the commandline.
os.execute('sudo -u pi /usr/local/bin/heyu off a6 &')-
cmisip
That eliminated the 256 error in the lua scripts. There is a new error though.
This is the lua script code:
There doesn't seem to be any negative effects. The lights are still working.
I got the info from here:
https://wiki.domoticz.com/X10_with_CM11a
2026-02-23 01:48:09.078 Error: SQLHelper: Error script not found '/lua/script_device_foyerlight.lua'Code: Select all
if (devicechanged['Foyer Light'] == 'On') then
os.execute('sudo -H -u pi /usr/local/bin/heyu on a1 &')
elseif (devicechanged['Foyer Light'] == 'Off') then
os.execute('sudo -H -u pi /usr/local/bin/heyu off a1 &')
Users browsing this forum: PatrickH67 and 1 guest
