Pilot: Home Automation Control (iOS app)
elmardam
Re: Pilot: Home Automation Control (iOS app)
Post by elmardam »
Hey Patoo, Thanks for responding!
unfortunately, i cant get it back to work, i even updated to the latest beta (16587) and got version, 2025.2.2 installed. anyone experiencing the same problem?
patoo77 wrote: Tuesday 11 February 2025 0:06 Hello everyone,
First, I apologize for the delay in responding. I wanted to share some good news: a new version of Pilot will be released soon to support the latest Domoticz API. This update ensures that Pilot remains compatible with Domoticz 2024.7 and future versions.
You can expect the release by the end of the week. In the meantime, feel free to reach out if you have any questions!
vlimper
Post by vlimper »
Morning Elmardam! I found this post in my search to why Pilot app isn't working anymore with Domoticz 2025.2 installed on my Raspberry Pi. Did you find a solution for it? I tried to reach out to Mr. Patrick Ferreira, but no response so far. Maybe you can help me forward... or can confirm that Pilot isn't working with this version. Thanks for your reply in advance! Nice weekend!
elmardam
Post by elmardam »
Unfortunately … app still isnt working on my side.. anyone else?
mvveelen
Post by mvveelen »
What's the problem you're having exactly, I'm using the latest Beta and the latest Pilot and don't have any problems.
vlimper
Post by vlimper »
The Pilot app just doesn't connect with the correct account settings.
mvveelen
Post by mvveelen »
I think you need to review every step you make. Does Pilot connect with the internal IP address? Do you use the right port? What security settings in Domoticz do you use? Has something changed in your setup? Etc. etc.
rapscallion42
Domoticz version: 2025.2
Post by rapscallion42 »
Please note that there has been an update to the Thermostat support in domoticz, where these devices could and now do appear as "Thermostat 6" type (since Dec 2025). This is a combined setpoint and temperature device for which the standard device.updateSetpoint() command will no longer work. Hence, this is likely to cause havoc for Pilot users.
Please reference https://github.com/tuk90/RemehaHome-Domoticz/issues/40
It would be great if Pilot could be updated to work with the new api call device.updateThermostat() instead, and note that there are more parameters. Unfortunately, the Thermostat6 type behaves a little differently and Pilot will need to support the old type and this new type concurrently it seems.
Note: At the moment, Pilot will not allow the set-point of these devices to be updated.
Domoticz version: 2026.3
rapscallion42 wrote: Monday 09 February 2026 16:42 Please note that there has been an update to the Thermostat support in domoticz, where these devices could and now do appear as "Thermostat 6" type (since Dec 2025). This is a combined setpoint and temperature device for which the standard device.updateSetpoint() command will no longer work. Hence, this is likely to cause havoc for Pilot users.
What has dzvents command device.updateSetpoint() has to do with this. It should still work for thermostat 6 https://wiki.domoticz.com/DzVents:_next ... eta_2025.2
The default API setpoint command will also still work: https://github.com/domoticz/domoticz/issues/6480
patoo77
Post by patoo77 »
Hi everyone,
I’ve just released a maintenance update for Pilot — version 2026.2 — with a focus on Apple Watch responsiveness and interactive widgets on iOS.
✅ What’s New in 2026.2
⌚ Apple Watch
* Faster app launch on the Watch
* More responsive controls for devices/scenes
* Better sync between Watch and iPhone
* Smoother handling of larger device lists
📱 Interactive iOS Widgets
* Tap-to-control behavior
* More reliable widget refresh
* Better consistency with real-time states
The main goal here was to make quick interactions — like toggling a light, controlling blinds, or launching a scene — feel snappier and more predictable, especially from the Apple Watch and Home Screen widgets.
Let me know what you think, and happy to hear feedback about any potential update requests.
More info here: https://pilot.patrickferreira.com/domot ... s-app-2026
felek
Post by felek »
I updated the application to version 2026.2, and regarding the widgets, I’m still seeing the issue I described earlier in the post.
viewtopic.php?p=323991#p323991
Is there any chance this bug can be fixed? In my case, assigning some sensors to specific "Rooms" causes their values not to be displayed in the widget.
patoo77
Post by patoo77 »
felek wrote: Sunday 22 February 2026 14:46 I updated the application to version 2026.2, and regarding the widgets, I’m still seeing the issue I described earlier in the post.
Thanks for reporting this issue and for the details about your setup.
I've been looking into this but I need to see what your Domoticz server is returning to the app. Could you send me the debug data so I can investigate?
Here's how:
1. Open Pilot and go to Settings
2. Scroll down to the very bottom
3. Tap on the "Version" cell (it shows the app version number)
4. This will open an email with a debug.json file attached — just send it as-is
This file contains the raw data your Domoticz server sends to the app. It will help me see whether room-assigned devices are included in the response or not, which will tell me where the issue lies.
Thanks for your patience!
patoo77
Post by patoo77 »
Hi everyone, a new update is available for Pilot, and it's both a big one and a small one. Be sure to check the blog post here: https://pilothomecontrol.com/pilot-2026 ... eedom-ios/
The update brings a simpler "Liquid-Glass" compatible UI, more flexibility to select the number of columns in the grid, a more efficient apple watch app.
There are also some bug fixes that users reported with the releast of last month's update.
Let me know what you think!
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
I am using Pilot version 2026.6 with Domoticz 2026.2.
The application successfully connects to my Domoticz server and accepts my login credentials, but after synchronization it shows 0 devices in “All”, Favorites, Cameras and User Variables.
My Domoticz server itself works correctly. I tested the current Domoticz API directly in Safari using:
http://LOCAL-IP:8082/json.htm?type=comm ... order=Name
The request works correctly and returns the full JSON list of my Domoticz devices.
I have also tested the Legacy login mode in Pilot, but it still shows 0 devices.
Configuration:
Pilot: 2026.6
Domoticz: 2026.2
HTTP
Port: 8082
Authentication enabled
Local and remote server addresses configured
Direct Domoticz API access works correctly
Could you please confirm whether Pilot 2026.6 is fully compatible with Domoticz 2026.2 and the current Domoticz API?
I am particularly interested in using Pilot with Apple Watch, but I would like to confirm that device synchronization works before purchasing the Premium subscription.
If you need any logs or additional information, I can provide them.
Thank you.
patoo77
Post by patoo77 »
Daro1003 wrote: Wednesday 26 August 2026 19:58 Hello,
Configuration:
Pilot: 2026.6
Domoticz: 2026.2
HTTP
Port: 8082
Thank you.
I think you're the one I just answered by email, let's continue there. :)
And if anyone's interested, this might simply be due to toggling on the basic auth check box to allow API Access.
If it's not related to that, I'll update you all.
seby901
Domoticz version: 2026.4
Post by seby901 »
Hello ,
I’m experiencing an issue with automatic device updates in Pilot iOS 2026.6, using Domoticz 2026.4 stable (build cc668a12b) through a Synology reverse proxy.
Device values load correctly and manual refresh works, but real-time updates fail over 4G/5G. The browser receives WebSocket updates correctly through the same external URL.
Domoticz accepts Pilot’s Basic authentication for /json.htm API requests, but rejects its WebSocket connection to /json:
Basic Authorization ignored as this is not a call to the API!
isUpgrade 1 needsAuthentication 1 isAuthenticated 0
Did not find suitable Authorization!
I have posted the configuration and diagnostic details here:
viewtopic.php?t=45368
I previously contacted you by email and have now also sent a private message. Could you check whether Pilot’s WebSocket authentication is compatible with this Domoticz version, or whether a specific server setting is required?
I’m available to help test a fix, including through TestFlight if useful.
Thank you,
Sébastien
