Pilot 2026.6 — WebSocket Basic authentication rejected with Domoticz 2026.4
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
seby901
Domoticz version: 2026.4
Post by seby901 »
I am investigating an issue with automatic device updates in the Pilot iOS app.
Version: Domoticz 2026.4 stable
Build hash: cc668a12b
Compile date: 2026-10-01 06:59:44
Platform: Raspberry Pi 3, Raspberry Pi OS Bookworm
Application: Pilot iOS 2026.6
Setup:
External HTTPS access through a Synology reverse proxy.
Proxy destination: Domoticz HTTPS listener on port 4431.
WebSocket Upgrade and Connection headers configured, HTTP/1.1 enabled.
Domoticz reverse proxy header: X-Forwarded-For.
Trusted networks: 192.168.1.0/24;127.0.0.1.
Pilot local server option disabled.
Symptoms:
Pilot loads device values successfully, and manual refresh works.
Automatic updates fail over 4G/5G.
Automatic updates were observed working on home Wi-Fi with the same Pilot settings. Whether trusted-network authentication explains this difference has not yet been verified.
In a desktop browser using the same external URL, the WebSocket connection receives HTTP 101 and device update messages.
The logs captured on November 27 show that Pilot's Basic authentication succeeds for /json.htm API requests, including getconfig, getversion and getdevices.
However, its WebSocket upgrade request to /json includes a Basic Authorization header and is rejected:
2026-11-27 11:14:09.672 Debug: [Auth Check] Basic Authorization ignored as this is not a call to the API!
2026-11-27 11:14:09.672 Debug: [web:4431] isPage 0 isAction 0 isUpgrade 1 needsAuthentication 1 isAuthenticated 0 () isNew 1
2026-11-27 11:14:09.672 Debug: [web:4431] Did not find suitable Authorization!
This is reproducible. The request reaches Domoticz with the WebSocket upgrade headers and Basic Authorization header present.
Is rejecting Basic authentication on /json intentional in this version? Which authentication method should a third-party application use for WebSocket connections? Is there a relevant server setting or a subsequent fix?
I found this related report, although its error concerns Origin validation rather than the authentication rejection shown above:
viewtopic.php?t=45115
I have also contacted the Pilot developer but have not received a response to the detailed report.
Thank you for your help.
