problem using json in container
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi! I am facing problems when I try to use json
Domoticz in docker.
services:
  domoticz:
    image: domoticz/domoticz:stable
    container_name: domoticz
    restart: unless-stopped
    # Pass devices to container
    devices:
      - "/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1BFAMG-if00-port0:/dev/ttyUSB0"
    ports:
      - "8080:8080"
    volumes:
      - ./config:/opt/domoticz/userdata/
      # regel toegevoegd om extra schermen (custom) te bereiken
      - ./custom:/opt/domoticz/www/custom
    environment:
      - TZ=Europe/Amsterdam
      #- LOG_PATH=/opt/domoticz/userdata/domoticz.log
This does not work (404 error) (input from browser IP# and port are correct)
http://192.168.2.100:8080/domoticz/json.htm?type=devices
Chatgpt says
🔹 Important Point
In the Domoticz Docker image domoticz/domoticz:stable from version 2025.2:
The old /json.htm API is not available in this container build.
This image is mainly intended for GUI + plugins.
Any scripts that try to fetch data via /json.htm will always return 404.
So, regardless of roomplan or idx, you cannot use this API.
any idea? chatgpt propose to downgrade to older container which I don't think being a real solution
any suggestions?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
jvdz
Domoticz version: 4.107
Re: problem using json in container
Post by jvdz »
Is localhost and/or. 127.0.0.1 part of the trusted networks in domoticz setup?
BartSr
Post by BartSr »
In trusted networks:
192.168.2.*;127.0.0.*
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
RonkA
Domoticz version: 2025.1
Post by RonkA »
In my Docker setup inside my nas i can see under network it says bridge.
If i expand this line it reads that the gateway uses 127.17.0.1, so internal this is the first IP-adres used.
The second internal IP-adres is 127.17.0.2 and that is the IP-adres used for Domoticz inside the Docker-container in my setup..
This IP-adres i set into trusted networks and all worked for me..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
BartSr
Post by BartSr »
RonkA, thanks for your message. Are you using the official domoticz container? Is the bridge something being part of Nas network?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Chatgpt is partly right, you use an old API call. But the new one will work....
You have to use
/json.htm?type=command&param=getdevices
See also wiki https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
You probably used an example based on old API calls
RonkA
Post by RonkA »
I use the official container docker:latest on my Synology Nas, this is what i see:
so for usage of json in scripts i use for example:
-- Clear the log of the textdevice
        domoticz.openURL('http://127.17.0.2:80/json.htm?type=command&param=clearlightlog&idx=337')
Users browsing this forum: Thorgal789 and 1 guest
