Moderators: leecollings , remb0
BartSr
Posts: 541 Joined: Sunday 03 July 2016 16:16
Domoticz version: V2024.7
Post
by BartSr » Wednesday 18 February 2026 12:10
Hi! I am facing problems when I try to use json
Domoticz in docker.
services:
domoticz:
image: domoticz/domoticz:stable
container_name: domoticz
restart: unless-stopped
# Pass devices to container
devices:
- "/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1BFAMG-if00-port0:/dev/ttyUSB0"
ports:
- "8080:8080"
volumes:
- ./config:/opt/domoticz/userdata/
# regel toegevoegd om extra schermen (custom) te bereiken
- ./custom:/opt/domoticz/www/custom
environment:
- TZ=Europe/Amsterdam
#- LOG_PATH=/opt/domoticz/userdata/domoticz.log
This does not work (404 error) (input from browser IP# and port are correct)
http://192.168.2.100:8080/domoticz/json.htm?type=devices
Chatgpt says
🔹 Important Point
In the Domoticz Docker image domoticz/domoticz:stable from version 2025.2:
The old /json.htm API is not available in this container build.
This image is mainly intended for GUI + plugins.
Any scripts that try to fetch data via /json.htm will always return 404.
So, regardless of roomplan or idx, you cannot use this API.
any idea? chatgpt propose to downgrade to older container which I don't think being a real solution
any suggestions?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
jvdz
Posts: 2476 Joined: Tuesday 30 December 2014 19:25
Domoticz version: 4.107
Post
by jvdz » Wednesday 18 February 2026 12:13
Is localhost and/or. 127.0.0.1 part of the trusted networks in domoticz setup?
BartSr
Post
by BartSr » Wednesday 18 February 2026 12:18
In trusted networks:
192.168.2.*;127.0.0.*
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
RonkA
Posts: 141 Joined: Tuesday 14 June 2022 12:57
Domoticz version: 2025.1
Post
by RonkA » Wednesday 18 February 2026 15:30
In my Docker setup inside my nas i can see under network it says bridge.
If i expand this line it reads that the gateway uses 127.17.0.1, so internal this is the first IP-adres used.
The second internal IP-adres is 127.17.0.2 and that is the IP-adres used for Domoticz inside the Docker-container in my setup..
This IP-adres i set into trusted networks and all worked for me..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
BartSr
Post
by BartSr » Wednesday 18 February 2026 18:37
RonkA, thanks for your message. Are you using the official domoticz container? Is the bridge something being part of Nas network?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Posts: 7019 Joined: Monday 28 January 2019 18:48
Post
by waltervl » Wednesday 18 February 2026 19:14
Chatgpt is partly right, you use an old API call. But the new one will work....
You have to use
/json.htm?type=command¶m=getdevices
See also wiki
https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
You probably used an example based on old API calls
RonkA
Post
by RonkA » Wednesday 18 February 2026 19:48
I use the official container docker:latest on my Synology Nas, this is what i see:
so for usage of json in scripts i use for example:
-- Clear the log of the textdevice
domoticz.openURL('http://127.17.0.2:80/json.htm?type=command¶m=clearlightlog&idx=337')
