Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
- Xenomes
- Domoticz version: 2025.2
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Do you have Bookworm or Trixie?
How are you running Domiticz local or docker?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
DomoticzRob
- Domoticz version: 2025.1
New to this forum but in the meantime many years enjoying Domoticz!
I started with Domoticz on my NAS, later to Raspberry PI but now for a couple of years on Windows (2025.1 version) which works for me very well as I'm not such a Linux guy.
My latest hardware connected to Domoticz is a Tuya thermostat which I like very well. The Tuya app is superb and access to the cloud work good.
But my wish is to automatically set a temperature from Domoticz.
So, I installed Python 32 bit V3.10 and of course the TinyTuya plugin.
This was not much of a struggle, Domoticz sees the hardware and my device variables.
The actual temperature is read and within a couple of minutes I see changes of the actual value and set value on my Domoticz.
Note that temperature set value was done on the thermostat or via the Tuya app (see question 1).
Now the questions:
1. When I change the set value from Domoticz, the changed value never reaches the thermostat.
The thermostat keeps it old value.
2: Not always is the actual temperature value "actual". The "Last Seen" value is sometimes way back...
3: Log errors:
I do have some errors:
Error: (JSONtoPython) failed to add item '-1', to list for string.
Error: Tuya: Domoticz.Configuration read failed: <built-in function Configuration> returned a result with an exception set
Error: Tuya: Device read failed: bf0fa6dfdcb9523a1cqgjw
What can possibly go wrong?
My data:
Windows 10
Domoticz cersion: 2025.1
Build Hash: 89d5c900d
Compile Date: 2025-05-05 09:02:49
dzVents Version: 3.1.8
Python Version: 3.10.0 (tags/v3.10.0:b494f59, Oct 4 2021, 18:46:30) [MSC v.1929 32 bit (Intel)]
Now the questions:
3: Log errors:
My data:
Windows 10
jmd33
I have PiOS Trixie and local Domoticz 2025.2
but I can reformat to Bookworm (or older !) if necessary
Raspberry Pi3B - PiOS Trixie - Domoticz 2025-2
- Xenomes
Did you put the device on DP instructions? If No, change it as instcucted in de pdf and restart Domoticz and test again. If Yes, can you run the debug_discoverty.py from the tools directory and make a issue on https://github.com/Xenomes/Domoticz-Tin ... gin/issues and add the dump.json file to the issue.DomoticzRob wrote: Wednesday 17 December 2025 7:15 Now the questions:
3: Log errors:
- Xenomes
Okay, I test it last night on Trixie indeed the == version where a issue, but the code without == worked. Did you use sudo to install the pip3 modules?jmd33 wrote: Wednesday 17 December 2025 10:34 I have PiOS Trixie and local Domoticz 2025.2
Domoticz is running local as super user. without sudo they are installed under the user and not het root (super user).
DomoticzRob
Thnx Xenomes,
I created an issue with the error messages in Domoticz log and the dump file.
- Varazir
I'm getting this, I just updated
2026-01-21 19:51:47.496 Error: TinyTUYA: Fatal error during Tuya initialization: Failed to initialize Tuya Cloud API: name 'requests' is not defined
2026-01-21 19:51:47.498 Error: TinyTUYA: handleThread: Failed to initialize Tuya Cloud API: name 'requests' is not defined line 1044Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- Xenomes
That is a strange one. requests is part of Tinytuya, and on my three test systems I don't have the error. I have added it to the import of the plugin. Hopefully the error is gone now. Version 2.3.6cVarazir wrote: Wednesday 21 January 2026 19:53 I'm getting this, I just updated
2026-01-21 19:51:47.496 Error: TinyTUYA: Fatal error during Tuya initialization: Failed to initialize Tuya Cloud API: name 'requests' is not defined 2026-01-21 19:51:47.498 Error: TinyTUYA: handleThread: Failed to initialize Tuya Cloud API: name 'requests' is not defined line 1044
- Varazir
Did a git pull and restarted domoticz dockerXenomes wrote: Friday 23 January 2026 19:37That is a strange one. requests is part of Tinytuya, and on my three test systems I don't have the error. I have added it to the import of the plugin. Hopefully the error is gone now. Version 2.3.6cVarazir wrote: Wednesday 21 January 2026 19:53 I'm getting this, I just updated
2026-01-23 22:15:20.728 Error: TinyTUYA: (tinytuya) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/:/opt/domoticz/userdata/Domoticz_Python_Environment:/opt/venv/lib/python3.11/site-packages:/usr/lib/python313.zip:/usr/lib/python3.13:/usr/lib/python3.13/lib-dynload:/opt/venv/lib/python3.13/site-packages:/opt/venv/local/lib/python3.13/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.13/dist-packages'.
2026-01-23 22:15:20.797 Error: TinyTUYA: Traceback (most recent call last):
2026-01-23 22:15:20.797 Error: TinyTUYA: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 73, in <module>
2026-01-23 22:15:20.797 Error: TinyTUYA: import requests
2026-01-23 22:15:20.797 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/requests/__init__.py", line 43, in <module>
2026-01-23 22:15:20.797 Error: TinyTUYA: import urllib3
2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/__init__.py", line 7, in <module>
2026-01-23 22:15:20.798 Error: TinyTUYA: from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url
2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/connectionpool.py", line 11, in <module>
2026-01-23 22:15:20.798 Error: TinyTUYA: from .exceptions import (
2026-01-23 22:15:20.798 Error: TinyTUYA: ...<13 lines>...
2026-01-23 22:15:20.798 Error: TinyTUYA: )
2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/exceptions.py", line 2, in <module>
2026-01-23 22:15:20.798 Error: TinyTUYA: from .packages.six.moves.http_client import IncompleteRead as httplib_IncompleteRead
2026-01-23 22:15:20.798 Error: TinyTUYA: ModuleNotFoundError: No module named 'urllib3.packages.six.moves'Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
- Xenomes
Python 3.13 are you in trixie? if so there is part on the Readme for Trixie, that includes the install of the missing urllib3 python module.Varazir wrote: Friday 23 January 2026 22:16 Did a git pull and restarted domoticz docker
2026-01-23 22:15:20.728 Error: TinyTUYA: (tinytuya) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/:/opt/domoticz/userdata/Domoticz_Python_Environment:/opt/venv/lib/python3.11/site-packages:/usr/lib/python313.zip:/usr/lib/python3.13:/usr/lib/python3.13/lib-dynload:/opt/venv/lib/python3.13/site-packages:/opt/venv/local/lib/python3.13/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.13/dist-packages'. 2026-01-23 22:15:20.797 Error: TinyTUYA: Traceback (most recent call last): 2026-01-23 22:15:20.797 Error: TinyTUYA: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 73, in <module> 2026-01-23 22:15:20.797 Error: TinyTUYA: import requests 2026-01-23 22:15:20.797 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/requests/__init__.py", line 43, in <module> 2026-01-23 22:15:20.797 Error: TinyTUYA: import urllib3 2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/__init__.py", line 7, in <module> 2026-01-23 22:15:20.798 Error: TinyTUYA: from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url 2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/connectionpool.py", line 11, in <module> 2026-01-23 22:15:20.798 Error: TinyTUYA: from .exceptions import ( 2026-01-23 22:15:20.798 Error: TinyTUYA: ...<13 lines>... 2026-01-23 22:15:20.798 Error: TinyTUYA: ) 2026-01-23 22:15:20.798 Error: TinyTUYA: File "/opt/domoticz/userdata/Domoticz_Python_Environment/urllib3/exceptions.py", line 2, in <module> 2026-01-23 22:15:20.798 Error: TinyTUYA: from .packages.six.moves.http_client import IncompleteRead as httplib_IncompleteRead 2026-01-23 22:15:20.798 Error: TinyTUYA: ModuleNotFoundError: No module named 'urllib3.packages.six.moves'
- Varazir
I have run this this since I reinstalled using Docker. Something has happen with.Xenomes wrote: Friday 23 January 2026 22:25Python 3.13 are you in trixie? if so there is part on the Readme for Trixie, that includes the install of the missing urllib3 python module.Varazir wrote: Friday 23 January 2026 22:16 Did a git pull and restarted domoticz docker
I'll test installing
- Varazir
I'm running Python 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0] on linuxXenomes wrote: Friday 23 January 2026 22:25Python 3.13 are you in trixie? if so there is part on the Readme for Trixie, that includes the install of the missing urllib3 python module.Varazir wrote: Friday 23 January 2026 22:16 Did a git pull and restarted domoticz docker
Now I remember I did large update of apps on my system few days ago. Something broke this I guess.
- Xenomes
The Domoticz Docker container has been updated to a higher release of the distribution. I will test it and fix the code or the requirements guide.Varazir wrote: Friday 23 January 2026 23:27 I'm running Python 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0] on linux
- Varazir
I notice the about page looks more high techXenomes wrote: Saturday 24 January 2026 8:48The Domoticz Docker container has been updated to a higher release of the distribution. I will test it and fix the code or the requirements guide.Varazir wrote: Friday 23 January 2026 23:27 I'm running Python 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0] on linux
- Xenomes
Out of the scope of the plugin:
You need to update your docker installation to the current version.
https://github.com/domoticz/domoticz-docker
put docker-entrypoint.sh in your directory where your customstart.sh is located.
Edit your customstart.sh to remove old lines see the customstart.sh in github.
In the scope:
The plugin needs tinytuya and PyCryptodome for the pip3 installation. Then it should work again.
- Varazir
What do you mean with "Edit your customstart.sh to remove old lines see the customstart.sh in github" ?Xenomes wrote: Saturday 24 January 2026 15:29Out of the scope of the plugin:
In the scope:
I never got installing tinytuya and PyCryptodome using the customstart.sh script.
So I installed all lib's to folder and point my docker to that for python.
- Xenomes
The customstart.sh script handles all my package installations, both apt and pip dependencies. When I rebuild the container, everything gets freshly installed. I keep my git clones in a separate Docker shared volume so they persist between rebuilds.Varazir wrote: Saturday 24 January 2026 17:17 What do you mean with "Edit your customstart.sh to remove old lines see the customstart.sh in github" ?
- Varazir
Could you share your customstart.sh and docker-entrypoint.sh ?Xenomes wrote: Saturday 24 January 2026 17:36The customstart.sh script handles all my package installations, both apt and pip dependencies. When I rebuild the container, everything gets freshly installed. I keep my git clones in a separate Docker shared volume so they persist between rebuilds.Varazir wrote: Saturday 24 January 2026 17:17 What do you mean with "Edit your customstart.sh to remove old lines see the customstart.sh in github" ?
- Xenomes
They are not really exciting, the docker-entrypoint.sh is unchanged, and the customstart.sh is only simply modified.Varazir wrote: Saturday 24 January 2026 18:27 Could you share your customstart.sh and docker-entrypoint.sh ?
https://raw.githubusercontent.com/domot ... rypoint.sh
- Spoiler: show
- Varazir
I'm getting this,Xenomes wrote: Sunday 25 January 2026 8:56They are not really exciting, the docker-entrypoint.sh is unchanged, and the customstart.sh is only simply modified.Varazir wrote: Saturday 24 January 2026 18:27 Could you share your customstart.sh and docker-entrypoint.sh ?
- Spoiler: show
domoticz-1 | building '_cffi_backend' extension
domoticz-1 | creating build/temp.linux-armv7l-cpython-313/src/c
domoticz-1 | arm-linux-gnueabihf-gcc -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O2 -Wall -fPIC -DFFI_BUILDING=1 -I/usr/include/ffi -I/usr/include/libffi -I/opt/venv/include -I/usr/include/python3.13 -c src/c/_cffi_backend.c -o build/temp.linux-armv7l-cpython-313/src/c/_cffi_backend.o
domoticz-1 | error: command 'arm-linux-gnueabihf-gcc' failed: No such file or directory
domoticz-1 | [end of output]
domoticz-1 |
domoticz-1 | note: This error originates from a subprocess, and is likely not a problem with pip.
domoticz-1 | ERROR: Failed building wheel for cffi
domoticz-1 | Failed to build PyCryptodome cffi
domoticz-1 | error: failed-wheel-build-for-install
domoticz-1 |
domoticz-1 | × Failed to build installable wheels for some pyproject.toml based projects
domoticz-1 | ╰─> PyCryptodome, cffiCode: Select all
domoticz-1 | 2026-01-25 13:29:47.381 Status: EventSystem: reset all device statuses...
domoticz-1 | 2026-01-25 13:29:47.702 Status: PluginSystem: 2 plugins started.
domoticz-1 | 2026-01-25 13:29:48.092 Status: Python EventSystem: Initializing event module.
domoticz-1 | 2026-01-25 13:29:48.093 Status: EventSystem: Started
domoticz-1 | 2026-01-25 13:29:48.094 Status: EventSystem: Queue thread started...
domoticz-1 | 2026-01-25 13:29:49.016 Error: TinyTUYA: (tinytuya) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/:/usr/lib/python313.zip:/usr/lib/python3.13:/usr/lib/python3.13/lib-dynload:/opt/venv/lib/python3.13/site-packages:/opt/venv/local/lib/python3.13/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.13/dist-packages'.
domoticz-1 | 2026-01-25 13:29:49.032 Error: TinyTUYA: Traceback (most recent call last):
domoticz-1 | 2026-01-25 13:29:49.032 Error: TinyTUYA: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 78, in <module>
domoticz-1 | 2026-01-25 13:29:49.032 Error: TinyTUYA: import tinytuya
domoticz-1 | 2026-01-25 13:29:49.032 Error: TinyTUYA: ModuleNotFoundError: No module named 'tinytuya'
