Problem with the blockly script turning on the light
Maciek90
I have two lamps that I want to turn on with a motion sensor at specific times. I created a Blockly script as shown below. It turns the lamp on when the sensor detects motion, and turns it off after a set period of time after the motion sensor switches to off. It usually works well, but occasionally it won't turn off the lamp 30 seconds after the motion sensor switches to off, leaving it on continuously until I turn it off in Domoticz. Could someone explain why this is happening and help me improve the script?
- 1.png (42.31 KiB) Viewed 293 times
- madpatrick
- Domoticz version: 2025.2
Re: Problem with the blockly script turning on the light
Maybe it is easier to use a DZvents script.
More flexibel and options
Maybe this example can help you
local SCRIPT_NAME = 'PIR '
local LOG_LEVEL = domoticz.LOG_FORCE
devices = {450,451,452,453 },
logging = {
level = LOG_LEVEL,
marker = SCRIPT_NAME
execute = function(dz, device)
local pirDevice1 = dz.devices(450)
local pirDevice2 = dz.devices(451)
local lamp1 = dz.devices(452)
local lamp1 = dz.devices(453)
if pirDevice1.state == "On" and lamp1.state == "On"
then pirDevice1.switchOn().checkFirst()
dz.log('Switch lamp1 ON', LOG_LEVEL)
elseif pirDevice1.state == "Off" and lamp1.state == "On"
then pirDevice1.switchOff().checkFirst().afterSec(30)
dz.log('Switch lamp1 OFF', LOG_LEVEL)
if pirDevice2.state == "On" and lamp2.state == "On"
then pirDevice2.switchOn().checkFirst()
dz.log('Switch lamp2 ON', LOG_LEVEL)
elseif pirDevice2.state == "Off" and lamp2.state == "On"
then pirDevice2.switchOff().checkFirst().afterSec(30)
dz.log('Switch lamp2 OFF', LOG_LEVEL)
}-= HP server GEN11 =- ZwaveJS-=- Domoticz v2025.2 -=- Dashticz =-
Maciek90
Thank you for your reply. I changed the IDX in the script to match my devices, but unfortunately it doesn't work. My lights don't turn on when the motion sensor is activated. DzVents isn't my strong suit, unfortunately.
devices = {68,69,1574,1575 },
logging = {
level = LOG_LEVEL,
local pirDevice1 = dz.devices(69)
local pirDevice2 = dz.devices(1575)
local lamp1 = dz.devices(68)
local lamp1 = dz.devices(1574)
}- madpatrick
Let add some log to see what is happening
devices = {68, 69, 1574, 1575},
logging = {
level = LOG_LEVEL,
-- Log which device triggered the script
dz.log('Script triggered by device: ' .. device.name .. ' (ID: ' .. device.id .. ')', LOG_LEVEL)
-- Apparaten ophalen
local lamp2 = dz.devices(1574)
-- PIR1 and lamp1
if pirDevice1.state == "On" and lamp1.state == "On" then
dz.log('PIR1 triggered. Switching Lamp1 ON', LOG_LEVEL)
elseif pirDevice1.state == "Off" and lamp1.state == "On" then
dz.log('PIR1 triggered. Switching Lamp1 OFF in 30 sec', LOG_LEVEL)
-- PIR2 andlamp2
if pirDevice2.state == "On" and lamp2.state == "On" then
dz.log('PIR2 triggered. Switching Lamp2 ON', LOG_LEVEL)
elseif pirDevice2.state == "Off" and lamp2.state == "On" then
dz.log('PIR2 triggered. Switching Lamp2 OFF in 30 sec', LOG_LEVEL)
Maciek90
2026-01-04 16:52:38.875 dzVents: !Info: PIR : Script triggered by device: Drzwi wejściowe sensor (ID: 69)
2026-01-04 16:52:58.322 dzVents: !Info: PIR : Script triggered by device: Drzwi wejściowe sensor (ID: 69)
- madpatrick
my mistake
I switchon the PIR
I switchon the PIR
logging = {
level = LOG_LEVEL,
-- PIR1 and lamp1
lamp1.switchOn().checkFirst()
lamp1.switchOff().checkFirst().afterSec(30)
-- PIR2 andlamp2
lamp2.switchOn().checkFirst()
lamp2.switchOff().checkFirst().afterSec(30)
Maciek90
Still not working
2026-01-04 20:34:26.691 dzVents: !Info: PIR : Script triggered by device: Drzwi wejściowe sensor (ID: 69)
2026-01-04 20:34:39.419 dzVents: !Info: PIR : Script triggered by device: Drzwi wejściowe sensor (ID: 69)
2026-01-04 20:34:49.283 dzVents: !Info: PIR : Script triggered by device: Dom światło sensor (ID: 1575)
2026-01-04 20:34:58.025 dzVents: !Info: PIR : Script triggered by device: Dom światło sensor (ID: 1575)
- madpatrick
Sorry.. i was too quick
When the lamp = On switch On doesn't make sense
Lamp should be Off to switch On
logging = {
level = LOG_LEVEL,
-- PIR1 and lamp1
if pirDevice1.state == "On" and lamp1.state == "Off" then
lamp1.switchOn()
lamp1.switchOff().afterSec(30)
-- PIR2 and lamp2
if pirDevice2.state == "On" and lamp2.state == "Off" then
lamp2.switchOn()
lamp2.switchOff().afterSec(30)
Maciek90
It seems to be working perfectly now. However, I'd like to expand this script a bit. I think I can handle most of the issues myself, but I'm not sure how to approach one particular issue. I'd like the lights to stay on after I turn them on in Domoticz with the motion sensor disabled until I turn them off again via Domoticz. Could you please help?
- madpatrick
Can you try this.
Not sure if it will work
Basically we want to check if the lamp1 is on before PIR1
logging = {
level = LOG_LEVEL,
local diff1 = lamp1.lastUpdate < pirDevice1.lastUpdate
local diff2 = lamp2.lastUpdate < pirDevice2.lastUpdate
-- PIR1 and lamp1
and diff1 then
lamp1.switchOn()
-- PIR2 and lamp2
and diff2 then
lamp2.switchOn()
Maciek90
Doesn't work, doesn't turn on the lights. Logs below.
2026-01-06 22:51:24.270 dzVents: !Info: PIR2 : Script triggered by device: Dom światło sensor (ID: 1575)
2026-01-06 22:51:25.249 dzVents: !Info: PIR2 : Script triggered by device: Drzwi wejściowe sensor (ID: 69)
- habahabahaba
- Domoticz version: 2024.4
I think you need 2 different scripts and 1 user variable.
A user variable will be a flag - were your lights turned on from Dz by hands or not (0 or 1 value)
Create a dummy switch and put a script on it where:
a) if you turning it on - change the flag( user varible) to 1, turn on all lights you need
b) at off action - chenge the flag to 0, turn off all lights
And in the current working script just add the IF condition where you chek whether the flag is "1" or not
- madpatrick
You can try this
This wil use the last update of the device
Or by using User variables which is better/more secure
Make 2 new User Variables in Domoticz Setup
Lamp1_PIR (Type: Boolean, false)
Lamp2_PIR (Type: Boolean, false)
local SCRIPT_NAME = 'PIR'
devices = {68, 69, 1574, 1575}, -- Lamp and PIR devices
logging = {
level = LOG_LEVEL,
local pir1 = dz.devices(69)
local pir2 = dz.devices(1575)
-- PIR 1 / Lamp 1 logic
-- PIR triggers → turn lamp on
if pir1.state == 'On' and lamp1.state == 'Off' then
dz.log('PIR1 → Lamp1 ON', LOG_LEVEL)
-- Only turn off if PIR turned lamp on (lamp last updated before PIR)
if pir1.state == 'Off' and lamp1.state == 'On' then
if lamp1.lastUpdate < pir1.lastUpdate then
dz.log('PIR1 → Lamp1 OFF in 30 sec', LOG_LEVEL)
dz.log('Lamp1 manually turned on, not turning off', LOG_LEVEL)
-- PIR 2 / Lamp 2 logic
if pir2.state == 'On' and lamp2.state == 'Off' then
dz.log('PIR2 → Lamp2 ON', LOG_LEVEL)
if pir2.state == 'Off' and lamp2.state == 'On' then
if lamp2.lastUpdate < pir2.lastUpdate then
dz.log('PIR2 → Lamp2 OFF in 30 sec', LOG_LEVEL)
dz.log('Lamp2 manually turned on, not turning off', LOG_LEVEL)
logging = {
level = LOG_LEVEL,
-- Get user variables for tracking PIR-controlled lamps
local lamp1PirVar = dz.variables('Lamp1_PIR')
local lamp2PirVar = dz.variables('Lamp2_PIR')
-- PIR triggers → turn lamp on and mark as PIR-controlled
lamp1PirVar.set(true)
dz.log('PIR1 → Lamp1 ON (PIR mode)', LOG_LEVEL)
-- PIR stops → only turn off if lamp was turned on by PIR
if pir1.state == 'Off' and lamp1.state == 'On' and lamp1PirVar.value == true then
dz.log('PIR1 → Lamp1 OFF in 30 sec (PIR mode)', LOG_LEVEL)
-- Manual lamp activation → disable PIR mode
if device.id == lamp1.id and lamp1.state == 'On' then
lamp1PirVar.set(false)
dz.log('Lamp1 manually turned on → PIR mode disabled', LOG_LEVEL)
lamp2PirVar.set(true)
dz.log('PIR2 → Lamp2 ON (PIR mode)', LOG_LEVEL)
if pir2.state == 'Off' and lamp2.state == 'On' and lamp2PirVar.value == true then
dz.log('PIR2 → Lamp2 OFF in 30 sec (PIR mode)', LOG_LEVEL)
if device.id == lamp2.id and lamp2.state == 'On' then
lamp2PirVar.set(false)
dz.log('Lamp2 manually turned on → PIR mode disabled', LOG_LEVEL)
Maciek90
I tried the variable script, and it doesn't work correctly. When the PIR detects motion and turns on the lamp, Domoticz thinks the lamp was manually turned on and leaves it on continuously. This can be seen in the log screenshot.
One more question: Is a Boolean variable the same as a string?
- 1.png (26.64 KiB) Viewed 189 times
- habahabahaba
- madpatrick
This script should work. I've tested is shortly with some dumy devices
You need to make a UserVariable
Type : Integer
Value : 0
Type : Integer
Value : 0
logging = {
level = LOG_LEVEL,
if device.id == pir1.id and pir1.state == 'On' and lamp1.state == 'Off' and lamp1PirVar.value == 0 then
lamp1PirVar.set(1)
if device.id == pir1.id and pir1.state == 'Off' and lamp1.state == 'On' and lamp1PirVar.value == 1 then
lamp1PirVar.set(0)
if device.id == lamp1.id and lamp1.state == 'On' and pir1.state == 'Off' and lamp1PirVar.value == 0 then
dz.log('Lamp1 manually turned on → PIR mode remains disabled', LOG_LEVEL)
if device.id == pir2.id and pir2.state == 'On' and lamp2.state == 'Off' and lamp2PirVar.value == 0 then
lamp2PirVar.set(1)
if device.id == pir2.id and pir2.state == 'Off' and lamp2.state == 'On' and lamp2PirVar.value == 1 then
lamp2PirVar.set(0)
if device.id == lamp2.id and lamp2.state == 'On' and pir2.state == 'Off' and lamp2PirVar.value == 0 then
dz.log('Lamp2 manually turned on → PIR mode remains disabled', LOG_LEVEL)
Type : Integer
Value : 0
Type : Integer
Value : 0
akamming
Just a hint: ask ChatGPT these questions while referring to the dzvents socumentation. You’ll be surprised how well it can do dzvents scriptie. Sometime the scripts have bugs, But if you aso ChatGPT to solve them (just feed with the error or behaviour) it Will also correct them…Maciek90 wrote: Tuesday 13 January 2026 19:43 I tried the variable script, and it doesn't work correctly. When the PIR detects motion and turns on the lamp, Domoticz thinks the lamp was manually turned on and leaves it on continuously. This can be seen in the log screenshot.
Maciek90
I ran your script today and it's working fine so far. I'll try to test all the possibilities in the next few days and let you know if everything works as it should.This script should work. I've tested is shortly with some dumy devices
Last year, I tried to write what turned out to be a fairly simple script using chatGPT, and unfortunately, I gave up after a few days. I managed to get the script working on the forum within a dayJust a hint: ask ChatGPT these questions while referring to the dzvents socumentation. You’ll be surprised how well it can do dzvents scriptie. Sometime the scripts have bugs, But if you aso ChatGPT to solve them (just feed with the error or behaviour) it Will also correct them…
ChatGPT is constantly evolving, and perhaps dzvents is as well. Maybe I'll give it another try some other time.
Maciek90
Unfortunately, the script doesn't work perfectly. There's a similar problem to the Blockly script presented in the first post: sometimes, the script won't turn off the light even though 30 seconds have passed since the motion sensor signal went off. This happens very rarely, once every few days. Below are screenshots of the Domoticz logs and the light button logs. You can see that the light turned on at 8:38 PM, and at 9:13 PM, I manually turned it off because it didn't automatically turn off after 30 seconds. There's also another problem with this script. If the light doesn't turn off after 30 seconds, the value of the variable doesn't change from 1 to 0. Therefore, when I manually turn off the light, I also have to manually change the value of the variable to 0. Otherwise, the motion sensor signal doesn't turn on the light.
2026-01-28 20:30:58.924 Status: Set UserVariable Lamp2_PIR = 1
2026-01-28 20:31:07.483 Status: Set UserVariable Lamp2_PIR = 0
2026-01-28 20:35:11.881 Status: Set UserVariable Lamp1_PIR = 1
2026-01-28 20:35:20.750 Status: Set UserVariable Lamp1_PIR = 0
2026-01-28 20:38:11.479 Status: Set UserVariable Lamp2_PIR = 1
2026-01-28 20:45:48.930 Status: Set UserVariable Lamp1_PIR = 1
2026-01-28 20:45:57.460 Status: Set UserVariable Lamp1_PIR = 0 Code: Select all
- 2.jpg (29.71 KiB) Viewed 108 times
- habahabahaba
Do you need to turn on the lights individually or together?
