Viessman Aquastilla smart Topic is solved
Mozekam
Hello everyone,
First of all, I'd like to praise this forum – it's a never-ending source of knowledge and help! I have a quick question. Is there any way to retrieve data from the Viessman Aquastilla app? I know the ViCare app works with Domoticz, but unfortunately, my water softener can only connect to the dedicated Aquastilla app.
Has anyone had any experience with this?
Best regards!
Best regards!
- Domoticz version: 2025.1
Re: Viessman Aquastilla smart
There is a python library for this. If it works for you it can be used to integrate it as a Python plugin or use it as a simple interface with virtual devices.
https://github.com/alakdae/aquastilla-softener
Mozekam
Thank you for your quick reply. Do you have any instructions for someone who's never done this before?
Invest some time in learning the principles of Python.
Install the python library so you can use it. Instruction should be in the GitHub repository.
Then copy/paste the script example in the readme of the library and create a file test.py.
Modify the contents so it has the correct account credentials.
Then run in a terminal session in the folder where the test.py script is
You should see information about the device and some commands are sent to the device (last lines of the script).
When you change the commands you can run the script again.
If you run into errors try chatgpt or copilot or another AI to solve it.
python3 test.pyWhen you change the commands you can run the script again.
Mozekam
Hello, thank you very much for your suggestions - I underestimated the AI tools. Got it sorted. Everything works beautifully.
- Screenshot_20260111_230901_ImperiHome.jpg (366.12 KiB) Viewed 68 times
Nice!
Can you share your solution? Do you have a github repository?
Mozekam
Of course, I will describe everything - I just need a moment, only late yesterday evening I managed to run a satisfactory script
As for github, I don't have it yet.
Mozekam
Below I'm posting a script for reading data via the Aquastilla API.
It collects data such as:
- salt level
- water used today
- remaining water until the next regeneration
- expected regeneration date
- flood alarm (I have a dedicated wireless sensor connected)
- vacation mode (status preview and remote on/off capability)
- display of the current operating mode
In the future, I'll probably want to add the ability to remotely turn off the water flow – this option is available in the app.
crontab task:
The script runs once every 15 minutes. I haven't tried running it at a shorter interval, because, according to the information I have, too frequent calls can temporarily lock the account. Secondly, I don't think it makes sense to update such data too frequently.
you need to create a file and paste the following script into it (You'll need to provide your login details, IP address, and optionally, the names of the displayed information—e.g., modes or error messages)
/home/pi/domoticz/scripts/python/aquastilla_domoticz.py
The attached photo shows what types of virtual sensors should be added in domoticz.
This is my first post, so please be understanding when it comes to descriptions and information
Thanks again to waltervl for effectively pointing me in the right direction
- salt level
- water used today
crontab task:
*/15 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/python/aquastilla_domoticz.pyyou need to create a file and paste the following script into it (You'll need to provide your login details, IP address, and optionally, the names of the displayed information—e.g., modes or error messages)
import requests
import json
from datetime import datetime, timedelta, timezone
from aquastilla_softener import AquastillaSoftener
# --- KONFIGURACJA DANYCH LOGOWANIA ---
EMAIL = "TWÓJ_EMAIL"
PASSWORD = "TWOJE_HASLO"
DOMOTICZ_URL = "http://localhost:8080"
# --- TWOJE NUMERY IDX Z DOMOTICZA ---
IDX_SOL = 10
IDX_WODA_DZIS = 11
IDX_WODA_ZAPAS = 12
IDX_ALARM = 13
IDX_DATA_REGEN = 14
IDX_WAKACJE_SW = 15
IDX_TRYB = 16
def update_domoticz(idx, nvalue, svalue):
url = f"{DOMOTICZ_URL}/json.htm?type=command¶m=udevice&idx={idx}&nvalue={nvalue}&svalue={svalue}"
try:
response = requests.get(url, timeout=5)
return response.status_code == 200
except Exception as e:
print(f"Błąd Domoticz (IDX {idx}): {e}")
return False
# Słownik tłumaczeń trybów (dostosuj, jeśli API zwróci inne nazwy)
TRYBY_PRACY = {
"SERVICE": "Zmiękczanie",
"REGENERATION": "Regeneracja",
"BACKWASH": "Płukanie wsteczne",
"BRINE": "Solankowanie",
"RINSE": "Płukanie końcowe",
"REFILL": "Napełnianie zbiornika",
"STANDBY": "Oczekiwanie"
try:
softener = AquastillaSoftener(email=EMAIL, password=PASSWORD)
devices = softener.list_devices()
if not devices:
print("Nie znaleziono urządzeń.")
else:
device = devices[0]
uuid = device['uuid']
headers = softener._get_headers()
base = softener._api_base_url
res_state = requests.get(f"{base}/device/{uuid}/state", headers=headers)
data = res_state.json()
res_settings = requests.get(f"{base}/device/{uuid}/settings", headers=headers)
settings = res_settings.json()
# --- OBRÓBKA DANYCH ---
sol = data.get("saltPercent", 0)
woda_dzis = round(data.get("todayWaterUsage", 0) * 1000, 1)
woda_zapas = round(data.get("waterLeft", 0) * 1000, 1)
# Pobieranie i mapowanie trybu pracy
raw_mode = data.get("operationMode", "UNKNOWN").upper()
tryb_tekst = TRYBY_PRACY.get(raw_mode, f"Inny ({raw_mode})")
raw_date = data.get("expectedRegenerationDate", "Brak")
clean_date = raw_date.split("T")[0] if "T" in raw_date else raw_date
is_vacation = settings.get("vacationMode", False)
vac_n = 1 if is_vacation else 0
vac_s = "On" if is_vacation else "Off"
# Alarm zalania
flood_status = device.get("deviceHistory", {}).get("flood")
n_alert, s_alert = 1, "System bezpieczny"
if flood_status:
flood_time = datetime.fromisoformat(flood_status.replace("Z", "+00:00"))
if datetime.now(timezone.utc) - flood_time < timedelta(minutes=30):
n_alert, s_alert = 4, "ALARM! WYKRYTO ZALANIE!"
# --- WYSYŁKA DO DOMOTICZA ---
update_domoticz(IDX_SOL, 0, sol)
update_domoticz(IDX_WODA_DZIS, 0, woda_dzis)
update_domoticz(IDX_WODA_ZAPAS, 0, woda_zapas)
update_domoticz(IDX_DATA_REGEN, 0, clean_date)
update_domoticz(IDX_ALARM, n_alert, s_alert)
update_domoticz(IDX_WAKACJE_SW, vac_n, vac_s)
update_domoticz(IDX_TRYB, 0, tryb_tekst) # <--- Wysyłka trybu
print(f"[{datetime.now().strftime('%H:%M:%S')}] Aktualizacja OK.")
print(f"Tryb: {tryb_tekst}, Sól: {sol}%, Woda dziś: {woda_dzis}L")
print(f"Błąd krytyczny: {e}")
- Zrzut ekranu 2026-01-14 224941.png (64.25 KiB) Viewed 50 times
Thanks for sharing. Next wonderful step would be to make this a python plugin but that is perhaps for another Aquastilla user with python skills to do...
