The attached is not really what I requested, but this time it is enough to figure out your issue.
Open your config and remove the hostname as that needs to point to "api.mijnafvalwijzer.nl", which is the default when left empty, so just leave it empty!
jvdz wrote: Sunday 27 July 2025 23:13
EDIT: Using your postcode&housenr you listed in the url, I indeed see that the module "m_mijnafvalwijzer" has an issue with the data returned, which I will have a look at
Committed an update to cope with the changed returned Website data for module "m_mijnafvalwijzer".
Preference should be to use the "m_mijnafvalwijzer_api" module as that is less likely to be sensitive to any changes made on their side.
cyberclwn wrote: Thursday 30 October 2025 21:44
The url i get redirected to, when i check on the site for my information, is https://afvalportaal.2go-mobile.com
If i can be of assistance to help resolve this issue, let me know.
Sure, but you will have to provide way more information than this! https://github.com/jvanderzande/Garbage ... -debugging
-or-
When this is a new installation, you can provide me with your zipcode & housenr in an email or PM, so I can do some checking and testing.
Just provide me with that in an email so I can have a look.
-or-
Hi, Yes, you are right, the post was a bit basic, my apologies.
And sorry for the late reply, but i was struggling a bit.
The script i was using until a few days ago, was working without any errors, so i had no need to check up on it.
But it seems there was a more recent version (20250614-1700) then the one i was still running (20200406-2030 )
Only if i noticed that more sooner then i like to admit
So i have been backing up the old config and implementing the new script. And that is running again now.
It just is not using ['pmd'] but ['packages'] as tag for the pmd. But that is just a little change in the config, and workable.
So: sorry i just "stress"-posted the post, and thanks for great script. I just need to check for updates sometimes, and especially when it looks like it broke.
cyberclwn wrote: Tuesday 04 November 2025 20:34
No worries, glad it all works after updating to the latest version.
I normally check the online garbagecalender to check which provider is use and then test it with the guessed module. Provide/PM me with/the zipcode&housenumber in case you need help.
jvdz wrote: Tuesday 06 January 2026 9:37
PM gestuurd / Send
Gadget freak - Domoticz beginner - ios and android user
