Hardware listed twice
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
athoopen
Domoticz version: 2025.2
Post by athoopen »
All,
In my hardware list, a number of hardware types are listed twice (idx 24,27,30,34,35). They are completely identical. Is this s a bug, or can I adjust it myself or ....
Any tips or tricks are welcome to make my hardware list populated with unique hardware types.
Cheers,
Arjan
Rp3 Using : RFXCom, LaCrosse, KNMI, Remeha, TinyTuya, zigbee and a few others
Domoticz version: 2025.1
Re: Hardware listed twice
Pres ctrl-F5 or clear your browser cache. Something is wrong on the browser side.
athoopen
Post by athoopen »
Thanks for your tip! I pressed ctrl-F5: no change. I opened the page in private: no change. I also opened the page in chrome (I normally use Firefox) and also no change. Double checked in chrome incognito: no change.
Cheers,
Arjan
you can check with an API call to see if you have doubles there too (change YourDomoticzServer:Port to real values) in a browser:
http://YourDomoticzServer:Port/json.htm?type=command&param=gethardware
You should get a json back.
If you see the double there too then you have an issue in your database.
If you do not see them in double in the json then it is browser related (javascript caching).
athoopen
Post by athoopen »
Via the API I get the same types, incl the same doubles. I gues the DB is messed up. ;)
Cheers,
Arjan
athoopen
Post by athoopen »
I just viewed the database, there are also doubles. I guess I'll backup the database and try to remove the double entries in the db. Scary .... I am not that much of a db goeroe :)
Cheers,
Arjan
athoopen
Re: Hardware listed twice (SOLVED)
Post by athoopen »
Removing the entries from the db did the trick.
Cheers,
Arjan
Great, at least this issue is solved for you....
Users browsing this forum: RonkA and 1 guest
