Z4D plugin problem on Trixie
Fredom
Domoticz version: 2025.1
Post by Fredom »
Dear members,
I'm currently switching to Trixie. I've installed everything without any problems, but unfortunately, the Z4D plugin just won't work. I've carefully followed the wiki instructions, but I keep getting an error message that I can't figure out. Does anyone have a solution for me? Below is what I did and the error message.
fredom@raspberrypi:~ $ python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
ERROR: Could not open requirements file: [Errno 2] Bestand of map bestaat niet: 'requirements.txt'
fredom@raspberrypi:~ $ sudo python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
fredom@raspberrypi:~ $ cd /home/fredom/domoticz/plugins/Domoticz-Zigbee
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
jannl
Domoticz version: 2025.5.x
Re: Z4D plugin problem on Trixie
Post by jannl »
I was planning about moving to trixy as well. However some problems and reading about that made me gonto bookworm. Trixy is not stable enough to run on a pi, at least not for me on a production system.
Tip: us full-upgrade so you don't accidently brick your system a I did, because of missing dependencies.
If you do an ls in ~/domoticz/plugins/Domoticz-Zigbee is there a requirements.txt ?
Fredom
Post by Fredom »
waltervl wrote: Wednesday 31 December 2025 17:25 If you do an ls in ~/domoticz/plugins/Domoticz-Zigbee is there a requirements.txt ?
No it's emty
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ ls
Yours sincerely,
Fred
Then you did not follow the instructions :-)
https://zigbeefordomoticz.github.io/wik ... g-on-linux
But instead of the option to use the –break-system-packages use the python venv option as you already followed https://zigbeefordomoticz.github.io/wik ... alEnv.html
Fredom
Post by Fredom »
waltervl wrote: Wednesday 31 December 2025 21:19 Then you did not follow the instructions :-)
Hi Walter,
I've tried both links and keep running into the same problem, see below. I also tried using AI in various ways, and then I managed to install the plugin, but of course, it didn't work. The domoticz log was full of errors. I'm afraid this won't work on Trixie.
Yours sincerely,
Fred
Then the following command did go wrong in folder
git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Fredom
Post by Fredom »
waltervl wrote: Wednesday 31 December 2025 23:52 Then the following command did go wrong in folder
Hi Walter,
You made my day. Your suggestion solved the problem. It works now. I did see an error, and I'm not sure if I need to do anything about it, but Z4D does work. Thanks a lot!
fredom@raspberrypi:~/domoticz/plugins $ git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Cloning into 'Domoticz-Zigbee'...
remote: Enumerating objects: 57939, done.
remote: Counting objects: 100% (1634/1634), done.
remote: Compressing objects: 100% (304/304), done.
remote: Total 57939 (delta 1538), reused 1350 (delta 1330), pack-reused 56305 (from 3)
Receiving objects: 100% (57939/57939), 112.24 MiB | 6.88 MiB/s, done.
Resolving deltas: 100% (39293/39293), done.
fredom@raspberrypi:~/domoticz/plugins $ cd /home/fredom/domoticz/plugins/Domoticz-Zigbee
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
types-flask-migrate 4.0 requires Flask-SQLAlchemy>=3.0.1, which is not installed.
pyopenssl 25.0.0 requires cryptography<45,>=41.0.5, but you have cryptography 40.0.2 which is incompatible.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo systemctl restart domoticz.service
Warning: The unit file, source configuration file or drop-ins of domoticz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo systemctl daemon-reload
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ cd
Yours sincerely,
Fred
