Domoticz own dashbords electricity, bidirectional measurement
geoterm
I've created my own dashboard for electricity consumption and production in a single-family home. It's based on a PZEM-004T system with six units. Three are for production and three are for consumption by the building. Now I need to create devices: the amount of energy in kWh, the energy pumped into the grid (when there's overproduction), and the energy drawn from the grid so I can compare it with the utility's bidirectional energy meter. There's a device in Domoticz called a smart meter (an attachment), but I don't know how to use it. Please help.
- d3.JPG (36.65 KiB) Viewed 147 times
- d1.JPG (164.48 KiB) Viewed 147 times
- d2.JPG (106.75 KiB) Viewed 147 times
HvdW
- Domoticz version: 2023.2
Re: Domoticz own dashbords electricity, bidirectional measurement
Most important: https://wiki.domoticz.com/DzVents:_next ... _scripting
Learn to use dzVents, the easiest scripting language around.
to get all data from Power - P1
domoticz.devices('Power').dump()
Watch the log every minute.
Here is another script
Create a dummy device with the name 'Electricity' should be the type TEXT device.
The script fills in the data.
timer = { 'every minute' }
execute = function(domoticz)
domoticz.log(domoticz.devices('Power').dump(), domoticz.LOG_INFO)
local powerDevice = domoticz.devices('Power')
local textDevice = domoticz.devices('Electricity')
if not powerDevice or not textDevice then
domoticz.log('Power of Electricity device niet gevonden', domoticz.LOG_ERROR)
return
-- sValue opsplitsen
local values = domoticz.utils.stringSplit(powerDevice.sValue, ';')
local usageT1 = values[1] or '0' -- laag
local usageT2 = values[2] or '0' -- hoog
local returnT1 = values[3] or '0'
local returnT2 = values[4] or '0'
local currentPower = values[5] or '0'
local returnExtra = values[6] or '0'
-- Verbruik vandaag (kWh)
local counterToday = powerDevice.counterToday or '0'
-- Netjes opgemaakte tekst
local text =
'⚡ Electricity overzicht\n' ..
'----------------------\n' ..
'Verbruik vandaag : ' .. counterToday .. ' kWh\n' ..
'\n' ..
'Verbruik T1 (laag) : ' .. usageT1 .. ' Wh\n' ..
'Verbruik T2 (hoog) : ' .. usageT2 .. ' Wh\n' ..
'Teruglevering T1 : ' .. returnT1 .. ' Wh\n' ..
'Teruglevering T2 : ' .. returnT2 .. ' Wh\n' ..
'Actueel vermogen : ' .. currentPower .. ' W\n' ..
'Teruglevering : ' .. returnExtra
-- Update Text device
textDevice.updateText(text)
Bugs bug me.
- Domoticz version: 2025.1
See also the wiki for the Dummy/Virtual devices that states what they are used for.
https://wiki.domoticz.com/Dummy_for_vir ... mart_meter
geoterm
Ok, Thank You, i will try.
geoterm
I definitely need to create two output devices – one to count kWh drawn from the grid, and the other pumped into the grid. Two input devices: the total kWh from the photovoltaics and the total kWh consumed by the building.
You can do that with the P1 smart meter device, it has 2 counters, one for usage and one for delivery.
You do not have a real grid meter that measures these values for you?
geoterm
Okay, I'll do it through P1.
I have a bidirectional meter at the property line – from the power company – and I'm curious how these two measurements will compare.
Of course, I could buy a bidirectional meter at home, but it's important that it works with Domoticz so I don't have to buy BACnet gateways, etc.
geoterm
There is some problem.
Logs:
2025-12-23 20:39:31.087 Error: GetJSonDevices: exception occurred : 'stoull'
2025-12-23 20:40:00.970 Error: UpdateMultiMeter: Error converting sValue values! (IDX: 287, sValue: '-601;nil;nil;nil;nil;nil', dType: 250, sType: 1)
2025-12-23 20:43:33.064 Error: dzVents: An error occurred when calling event handler L123sP1 287 dzvents
2025-12-23 20:43:33.064 Error: dzVents: ...cripts/dzVents/generated_scripts/L123sP1 287 dzvents.lua:8: attempt to call a table value
dz vents:
Logs:
dz vents:
devices = {
160
domoticz.devices(287).updateP1(domoticz.utils.round((domoticz.devices(161).actualWatt - domoticz.devices(160).actualWatt), 0))
}- Attachments
- a1.JPG (21.26 KiB) Viewed 87 times
A P1 device needs 6 values, read the docs. You only supply 2.
