#PRIORITY not set in settings>Notifications>CustomHTTP/Action
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
edgarhildering
Domoticz version: 2023.2
Post by edgarhildering »
Version: 2025.2
Build Hash: e63981b18
Compile Date: 2025-10-13 11:42:57
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
Platform: Linux 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
Description: a priority in the SendNotification string is not reflected in the #PRIORITY field of the customHTTP/Action settings.
commandArray[#commandArray+1] = {['SendNotification'] = '#Alert: testswitch turned off#4###http'}
I use a script to pick up the fields and send them to my ntfy-server, like this:
script://.../ntfy.sh --user #FIELD2 --topic #FIELD1 --server #TO --org "#FIELD4 #PRIORITY" --message "#MESSAGE" --prio 3
The priority is combined with #FIELD4. The expected result is "HZN 4", however this is the result:
Screenshot from 2025-12-19 14-53-46.png (24.63 KiB) Viewed 131 times
AFAIK the messge for SendNotification is build up as follows:
subject#message#priority#sound#extradata#subsystem
In case I'm wrong, let me know how to do it.
kind regards, --Edgar
RaspberryPi running Domoticz 2025.2
PIRs + lightswitches
thermometers + heating control
hygrometers + dehumifiers
TUYA switches
Domoticz version: 2025.1
Re: #PRIORITY not set in settings>Notifications>CustomHTTP/Action
I am not a Domoticz lua script user but is seems I miss a subject field in your command
   commandArray['SendNotification']='subject#body#priority#sound#extradata#subsystem'
          -- Subject is .. the subject
          -- Body is the content of the message
          -- priority is a number from 0 (low) to 4 (emergency)
          -- sound is the sound you want to use if you use pushover
          -- extradata can be used by some of the notification.
          -- subsystem is one or more of: clickatell;email;fcm;http;kodi;lms;prowl;pushalot;pushbullet;pushover;pushsafer;telegram
So perhaps it should be something like
commandArray[#commandArray+1] = {['SendNotification'] = 'Domoticz Alert#Alert: testswitch turned off#4###http'}
edgarhildering
Hi and thanks for the reply. I kept the subject empty. Even when I define a notification on a switch
  • you can't set a subject, but you can set a message
  • the result is exactly the same: #PRIORITY in the report as above, instead of the selected priority. (in my case: Emergency)
--Edgar
TUYA switches
I dont know if #Priority is meant for this way.
Perhaps check in discussion viewtopic.php?p=304181&hilit=ntfy#p304181 how they handle notifications priority over ntfy.sh
with commandArray[#commandArray+1] = {['SendNotification'] = 'Subject#Alert: testswitch turned off#4###http'} you send something to the Domoticz http custom notification action. There you should be able to use it. https://wiki.domoticz.com/Notifications
Edit: Now I get it...... in the first topic the script definition is used in the URL/Action field of the HTTP notification.
But did you try it with a subject added in the lua command? Does it give the same result?
When I look in dzvents for the notify function the field subject is not an optional field...
notify(subject, message [,priority][,sound][,extra][,subsystem][,delay]):
edgarhildering
ok, i've added a subject to my notification:
commandArray[#commandArray+1] = {['SendNotification'] = 'MySubject#Alert: testswitch turned off#4###http'}
Unfortunately, there's no difference. And even when I send a test message from the customHTTP/action (test button), I don't see any priority.
The 'Hello' message is the result of turning the switch on. The Alert message is from the commandArray-call above (subject added). The test message is from the test button.
Screenshot from 2025-12-19 16-32-43.png (69.59 KiB) Viewed 105 times
TUYA switches
edgarhildering
It is not about using the priority in ntfy. That works fine. See my script where I use --prio 3. It is about getting the priority from Domoticz...
TUYA switches
When I test this with my telegram bot in the HTTP action field and try to send the priority I get a nice 0 returned as that is the default priority
https://api.telegram.org/bot6xxxxxx:sbgwrbvgwevgfbbbbbbb/sendMessage?chat_id=#TO&text=#PRIORITY
When using below I get the text: 0Text in field4
&text=#PRIORITY#FIELD4
But when I put quotes around it in the action field I get no response at all...
&text="#PRIORITY#FIELD4"
So perhaps try
script://.../ntfy.sh --user #FIELD2 --topic #FIELD1 --server #TO --org #FIELD4#PRIORITY --message #MESSAGE --prio 3
edgarhildering
I did try #FIELD4#PRIORITY, no success...
TUYA switches
edgarhildering
I've done some "finger exercises" with double quotes (with quotes, without quotes, escaped quotes, etc.). No matter what I try, I can't get #PRIORITY to be entered as a parameter. The #SUBJECT parameter does work: I receive the subject in this key and can also use it in the call to ntfy.
Regarding Telegram: I see that I can't call a script there and that 'FIELDS' aren't available either; lucky you that it works for Telegram.
I'm waiting for the next release of Domoticz and will test it again then... Any suggestion is welcome in the mean time...
--Edgar
TUYA switches
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Maybe this can be an option for you.
viewtopic.php?p=273355#p273355
This a script which reads out the log and send a message.
i've adjusted myself to send messages by Prowl
for example
 local SCRIPT_VAR    = 'ErrorLogCallback'
local SCRIPT_NAME   = 'ErrorLog'
local LOG_LEVEL     = domoticz.LOG_STATUS   -- zet op LOG_ERROR bij productie
        httpResponses = { SCRIPT_VAR },
        timer = { "every hour" },
        -- devices = { 290 },
    logging = {
        level = LOG_LEVEL,
        marker = SCRIPT_NAME
    data = {
        lastlogtime = { initial = 0 }
    execute = function(dz, item)
        -- Zoeken naar foutmeldingen in Domoticz log
        local searchTerms = { "Error", "Warning", "Failure" }
        local ignoreStrings = {
            "CheckAuthToken", "dzVents: Info:", "dzVents: !Info:", "dzVents: Debug:",
            "transport", "http", "Discarding device", "CConnection_connect",
            "PARSE", "KeyError", "nan"
        local function isRelevant(str)
            if not str or str == "" then return false end
            for _, ignore in ipairs(ignoreStrings) do
                if str:find(ignore) then return false end
            for _, term in ipairs(searchTerms) do
                if str:find(term) then return true end
            return false
        -- Log opvragen (lastlogtime direct vastzetten!)
        local function requestLog()
            local baseUrl = dz.settings['Domoticz url']
            local previousTime = dz.data.lastlogtime
            local now = os.time()
            local url = string.format(
                "%s/json.htm?type=command&param=getlog&lastlogtime=%d&loglevel=4",
                baseUrl,
                previousTime
            dz.openURL({ url = url, callback = SCRIPT_VAR })
            -- BELANGRIJK: direct opslaan → crash-/restart-safe
            dz.data.lastlogtime = now
        -- Extract recente logregels
        local function findLogMessage(json)
            if json and json.result and type(json.result) == "table" then
                for i = #json.result, 1, -1 do
                    local msg = json.result[i].message
                    if isRelevant(msg) then return msg end
            return nil
        -- Timestamp loskoppelen van de rest
        local function splitAfterTimestamp(msg)
            local prefix, suffix = msg:match(
                "^(%d%d%d%d%-%d%d%-%d%d %d%d:%d%d:%d%d[^\n]-:%s)(.+)"
            if prefix and suffix then return prefix, suffix end
            return msg, ""
        -- Schoonmaken van foutmeldingen (zonder interpretatie)
        local function prettyMessage(msg)
            if not msg or msg == "" then return "" end
            local ts, rest = msg:match(
                "^(%d%d%d%d%-%d%d%-%d%d %d%d:%d%d:%d%d.-:%s)(.+)"
            ts = ts or ""
            rest = rest or msg
            rest = rest:gsub('b"[^"]*"', "[data]")
            rest = rest:gsub("{[^}]*}", "[details]")
            rest = rest:gsub("%s+", " "):gsub("^%s*(.-)%s*$", "%1")
            return ts .. rest
        -- Fallback parsing als JSON stukgelopen is
        local function manualParseFromRaw(raw)
            if not raw or raw == "" then return nil end
            if not (raw:find('"LastLogTime"') or raw:find('"GetLog"')) then return nil end
            local lastRelevant = nil
            for line in raw:gmatch("[^\r\n]+") do
                if line:find('"message"') then
                    local msg = line:match('"message"%s*:%s*"(.*)"%s*,?%s*$')
                    if msg and isRelevant(msg) then
                        lastRelevant = msg
            return lastRelevant
        -- HOOFDLOGICA
        if item.isDevice or item.isTimer then
            requestLog()
        elseif item.isHTTPResponse then
            if not item.ok then
                dz.log(
                    "HTTP fout bij ophalen log. Statuscode: " ..
                    tostring(item.statusCode),
                    dz.LOG_ERROR
                return
            if item.json then
                local found = findLogMessage(item.json)
                if found then
                    local p1, p2 = splitAfterTimestamp(found)
                    local pretty = prettyMessage(p1 .. p2)
                    dz.log("Relevante foutmelding gevonden: " .. pretty, dz.LOG_FORCE)
                    dz.notify("Domoticz Foutmelding", pretty, dz.PRIORITY_HIGH)
                local rawData = item.data or ""
                if rawData:find("<!DOCTYPE html>") then
                    dz.log(
                        "HTML response (loginpagina). Voeg 127.0.0.1 toe aan 'Lokale Netwerken'.",
                        dz.LOG_ERROR
                    return
                local manualMsg = manualParseFromRaw(rawData)
                if manualMsg then
                    local pretty = prettyMessage(manualMsg)
                    dz.log("Relevante foutmelding (fallback): " .. pretty, dz.LOG_FORCE)
                    dz.log("HTTP response bevat geen geldige JSON.", dz.LOG_ERROR)
edgarhildering wrote: Friday 19 December 2025 20:39 I've done some "finger exercises" with double quotes (with quotes, without quotes, escaped quotes, etc.). No matter what I try, I can't get #PRIORITY to be entered as a parameter. The #SUBJECT parameter does work: I receive the subject in this key and can also use it in the call to ntfy.
--Edgar
As said, if you create a telegram bot you can also use it with http command.
I used it with latest stable 2025.2 I do not think a lot in this has changed recently. My test proofed the http notification changes #PRIORITY into a number and uses that in the http command. So it also should work for you.
edgarhildering
The initial problem (passing the priority) hasn't worked yet. Here's an update.
waltervl wrote: Saturday 20 December 2025 0:07 My test proofed the http notification changes #PRIORITY into a number and uses that in the http command. So it also should work for you.
  • It turns out the priority is indeed passed correctly when an http(s) call is used. I haven't been able to do this for a script call (script://).
  • After some searching, I found a way to access the message server without using a script. It works like this:
https://<message-server-address>/<topic>/publish?<key=value>&<key=value>...
  • Unfortunately, the priorities of Domoticz and NTFY are not compatible; see the table below.
domoticz prio | Domoticz code | NTFY equivalent |
   very low   |   -2          |   1             |
   low        |   -1          |   2             |
   normal     |    0          |   3             |
   high       |    1          |   4             |
   emergency  |    2          |   5             |
So, you can't use the domoticz code without some tricks. The NTFY server returns an error if the key 'priority=' is provided with an illegal value.
I'm still investigating how to use NGINX to change the value of the domoticz parameter (provided as domprio=...) to its NTFY equivalent and then add it to the URL. But at least I can get some messages now!
TUYA switches
You are right, the notify by script section in the source does not have a #PRIORITY translation like the http part has. So you could make a GitHub issue to get this corrected.
https://github.com/domoticz/domoticz/bl ... onHTTP.cpp
Users browsing this forum: gizmocuz and 1 guest
