update dummy device Baromater
knasson
Domoticz version: 2024-4
Post by knasson »
hi,
I created a dummy devic to manage the barometer pressure supplied by visual crossing.
why a got this? however the pressure appears in the device but not in the widget nor the icon.
jvdz
Domoticz version: 4.107
Re: update dummy device Baromater
Post by jvdz »
How do you feed the data to the dummy barometer and what are the nvalue & svalue you supply?
knasson
Post by knasson »
the nvalue and svalue are coming from a script.
json = (loadfile "/home/kan/domoticz/scripts/lua/JSON.lua")()  -- For Linux
local config=assert(io.popen("curl -s 'http://127.0.0.1:8080/json.htm?type=command&param=getdevices&rid=1306'"))
local blocjson = config:read('*all')
config:close()
local jsonValeur = json:decode(blocjson)
Baro = jsonValeur.result[1].Barometer
commandArray ['UpdateDevice']= '1511|0|'..Baro
the device 1306 is a THB of viSual crossing wihich supply Temp, Hygrometry and Barometer.
the pressure is extracted correctly by the script but the display of the widget is not completed.
jvdz
Post by jvdz »
This is what is expected for nValue & sValue: https://wiki.domoticz.com/Domoticz_API/ ... #Barometer
So maybe it helps when you change the sValue to: BAR;BAR_FOR
Just as a test you could fix the forcast to 0=stable:
commandArray ['UpdateDevice']= '1511|0|'..Baro..";0"
knasson
Post by knasson »
Excellent the right syntax that works for me is what you propose but with simple strokes
commandArray ['UpdateDevice']= '1511|0|'..Baro..';0'
i had seen the svalue needs 2 values like you say but i ignored the right syntax
Many thanks
for our pleasure
Domoticz version: 2025.1
Perhaps a stupid remark from me but as you use Visual Crossing data to have weather data in Domoticz like me: I have a Barometer automatically created by Domoticz based on the temp/hun/baro data from visual Crossing in the weather tab. Did you not have that?
I do not need to put barometer values in a separate dummy device. It is already there....
