Python PLugin : Lyrion Music Server
- madpatrick
- Domoticz version: 2026.1
I've made a Plugin for the Lyrion Music Server, formaly known as Logitsch Media Server
The buildin plugin still works, but is a bit limited
There are not mpw devices and functionalities added.
I've tested the plugin and it is working, but of course the can always be some issues.
The plugin is not tested with multiple devices
Please share you findings
You can find the plugin over here : https://github.com/MadPatrick/domoticz_Lyrion
- Domoticz version: 2026.3
Re: Python PLugin : Lyrion Music Server
Thanks, so the current Logitech media server integration is not working anymore? https://wiki.domoticz.com/Logitech_Media_Server
- madpatrick
Still working, but limitedwaltervl wrote: Saturday 15 November 2025 20:18 Thanks, so the current Logitech media server integration is not working anymore? https://wiki.domoticz.com/Logitech_Media_Server
Also it gives sometimes an error in the JSON.
See the raised issue on Domoticz GIT
- capman
I have this error in the log: Error: Lyrion Music Server: Unable to load icon pack 'LMS.zip'
In the plugin it's named lyrion.zip , so I renamed it to LMS.zip , but no luck.
- madpatrick
You need also correct the names inside the zip./
I've corrected it and uploaded the correct LMS.zip
Also a new version with a small fix
- capman
Working now , thanksmadpatrick wrote: Friday 27 February 2026 14:42 Hi,
lamaisondelou69
Thanks for your plugin, it works very well. Really useful compared to the former one LMS.
I have a question :
- I see my playlists but only 5 of them. This behaviour is linked to the default process to create the switch selector ?
If possible, it could me more user-friendly to get all our existing playlists.
I don't try yet to add other playlists manually. I guess I could but not try.
- I don't see if it possible to add a trigger and launch the favourites ? It could be very nice to add it if you can (to launch a radio you registered as favourite for example)
Thanks again for your exciting work !
I have a question :
- madpatrick
You can set the amount playlist to load in the settings
I'll check if the information of the favorates is retreivable form the LMS
lamaisondelou69
Many thanks !!! It works well.
Do you have any plugin to learn me how to open my eyes ?
- madpatrick
no problem.
I've added the Favorites option
It is available in the Beta branch
Not yet fully completed and tested, but give it a go
- capman
How to use these devices in a blockly script ?
I try to setup a event for testing but it's not working.
In blockly is no 'play' command , only 'playing'. (beta 2025.2 build17074).
- madpatrick
I'm not using or familair with Blocky, but i think you need to you use "Level=20"
Better to use DzVents which has more flexibility
Something like this, but you need to tweak to your devices
devices = { 'Test dummy' }
local lmsControl = domoticz.devices('Lyrion - Muziek Bureel Control')
local lmsVolume = domoticz.devices('Lyrion - Muziek Bureel Volume')
if device.state == 'On' and lmsControl.state == 'Stop' then
lmsVolume.setLevel(30)
lmsControl.setLevel(20) -- 20 = Playing
elseif device.state == 'Off' then
lmsControl.setLevel(30) -- 30 = Stop
- capman
Thanks a lot 4 helping me out. I had now the time to test it with DzVents.
I was not familiar with it
, but it worked like you say. Many thanks !!
- capman
Also work with blockly
