This is what I could capture. After that things freeze. Hope this helps.ronalddevos wrote: Saturday 27 September 2025 19:02Is that the debug in the plugin config page?Xenomes wrote: Saturday 27 September 2025 16:31Can you set de debug to python, and report the data in the error lines.Should be faster, no 15 min wait until status change.ronalddevos wrote: Saturday 27 September 2025 16:16 Response time seems slower though (not an issue)
Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
ronalddevos
- Domoticz version: 2025.1
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
- TuyaErrorLog.txt
- (4.25 KiB) Downloaded 8 times
- Xenomes
- Domoticz version: 2025.2
Could it be possible that the subscription has been expired?ronalddevos wrote: Saturday 27 September 2025 20:22 This is what I could capture. After that things freeze. Hope this helps.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
ronalddevos
Considered that and checked and even renewed.Xenomes wrote: Sunday 28 September 2025 19:07Could it be possible that the subscription has been expired?ronalddevos wrote: Saturday 27 September 2025 20:22 This is what I could capture. After that things freeze. Hope this helps.
I have monitored the last 24 hours and it has been running without problem except three times the
"Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217"
1 time yesteday afternoon, 2 times this night, timing is not consistent but seems random
Still have not figured out the whens and whys...
Could it be something at the Tuya end?
- Xenomes
I added an extra error line to pinpoint the exact source of the problem.ronalddevos wrote: Monday 29 September 2025 8:17 I have monitored the last 24 hours and it has been running without problem except three times the
To update, switch to the Master branch, pull and then switch back to pulsar, and finally reload the plugin.
ronalddevos
Done & Thanks!Xenomes wrote: Monday 29 September 2025 21:31I added an extra error line to pinpoint the exact source of the problem.ronalddevos wrote: Monday 29 September 2025 8:17 I have monitored the last 24 hours and it has been running without problem except three times the
I will monitor
For now the initial error is gone, just irregularly getting the "Credentials are incorrect or tuya subscription has expired! line 1217"
ronalddevos
OK -got this with Pythob debug on:ronalddevos wrote: Tuesday 30 September 2025 8:40Done & Thanks!Xenomes wrote: Monday 29 September 2025 21:31I added an extra error line to pinpoint the exact source of the problem.ronalddevos wrote: Monday 29 September 2025 8:17 I have monitored the last 24 hours and it has been running without problem except three times the
I will monitor
2025-09-30 11:43:45.552 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
2025-09-30 11:43:45.657 TinyTuya: onHeartbeat called
2025-09-30 11:43:45.657 TinyTuya: onHeartbeat called last run: 24.174337148666382
2025-09-30 11:43:45.658 TinyTuya: Running Pulsar
2025-09-30 11:43:45.658 TinyTuya: Device name=ProxMox BU Server id=8106400140f520059c3c category=switch
ronalddevos
Managed to trap the whole sequence.ronalddevos wrote: Tuesday 30 September 2025 11:45OK -got this with Pythob debug on:ronalddevos wrote: Tuesday 30 September 2025 8:40Done & Thanks!Xenomes wrote: Monday 29 September 2025 21:31
I will monitor
- TuyaErrors-30-09-25.txt
- (4.42 KiB) Downloaded 5 times
ronalddevos
Also getting:ronalddevos wrote: Tuesday 30 September 2025 13:26Managed to trap the whole sequence.ronalddevos wrote: Tuesday 30 September 2025 11:45OK -got this with Pythob debug on:ronalddevos wrote: Tuesday 30 September 2025 8:40
Done & Thanks!
I will monitor
2025-09-30 19:09:14.589 TinyTuya: onCommand called for Device bf58f96d002fcb03beswmt Unit 1: Parameter 'On', Level: 0', Color:
2025-09-30 19:09:14.590 TinyTuya: Device ID: bf58f96d002fcb03beswmt
2025-09-30 19:09:14.590 TinyTuya: nValue: 0
2025-09-30 19:09:14.590 TinyTuya: sValue: False Type <class 'str'>
2025-09-30 19:09:14.591 TinyTuya: LastLevel: 0
2025-09-30 19:09:14.670 TinyTuya: onHeartbeat called
2025-09-30 19:09:14.670 TinyTuya: onHeartbeat called last run: 63.13947010040283
2025-09-30 19:09:14.671 TinyTuya: Running Pulsar
Does this give a clue?
- Xenomes
I see something in the log, You have tinytuya module 1.7.3, 1.7.4 is the latest.
This looks like a control issue. is bf58f96d002fcb03beswmt a light?ronalddevos wrote: Tuesday 30 September 2025 19:11 Also getting:
ronalddevos
bf58f96d002fcb03beswmt is a smart plug (controlling a light)Xenomes wrote: Tuesday 30 September 2025 20:03I see something in the log, You have tinytuya module 1.7.3, 1.7.4 is the latest.
I'll re-upgrade to 1.7.4
Other then the "False Type" no errors in the 14 hours...
- Xenomes
Thanks, I will check the code why there is a error.ronalddevos wrote: Wednesday 01 October 2025 8:15 bf58f96d002fcb03beswmt is a smart plug (controlling a light)
Nice! 1.7.4 had cloud updates.ronalddevos wrote: Wednesday 01 October 2025 8:15 I'll re-upgrade to 1.7.4
TroisSix
Hi Xenomes,
I am using your plugin for a while now, it was working perfectly with a lot of different plugs (multiplugs, simple plugs, ...)
But then I bought a new multi-plugs "4 plugs + usb", it is being recognized by your plugin after a de-activation and re-activation of the plugin TinyTuya, so good.
The weird thing is that when I switch on/off whatever plug of my new multi-plugs in Domoticz, it does nothing in real
But when I switch on/off the plugs in the application SmartLife, the plugin refreshes the values correctly in Domoticz after the polling of course, not immediatly.
So it only works one way for this new multi-plugs.
I activated the debug option of the plugin but it doesn't say anything more.
The others multi-plugs work perfectly the two ways (from domoticz or from SmartLife)
I have the version 2.3.2 of the plugin, on Domoticz 2025.2, on a VM Debian 12.
Do you have any suggestions?
Thank you for your support
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
- Xenomes
Make a issue on github, than we can investigate whats wrong.TroisSix wrote: Tuesday 11 November 2025 19:04 Hi Xenomes,
The weird thing is that when I switch on/off whatever plug of my new multi-plugs in Domoticz, it does nothing in real![]()
Thank you for your support![]()
https://github.com/Xenomes/Domoticz-Tin ... gin/issues
l81occitarn
Hi !
Thank you for the job, i use your plugin to read/log the data from my weather station, and it works well for my indoor sensor (principal sensor).
It's a multi-channel weather station, and the others sensors (outdoor sensor, pool sensor) aren't displayed in domoticz.
Is it possible to manage multiple channels in order to display the others sensor data ?
I use the plugin in version 2.3.2.
Thanks for your reply
- Xenomes
Make a issue on github, than we can add the support. Please run the discovery_debug.py and add the dump.json to the issue.l81occitarn wrote: Wednesday 19 November 2025 8:25 Hi !
l81occitarn
There is the result of the debug_discovery.py :Xenomes wrote: Wednesday 19 November 2025 22:14Make a issue on github, than we can add the support. Please run the discovery_debug.py and add the dump.json to the issue.l81occitarn wrote: Wednesday 19 November 2025 8:25 Hi !
What's the problem ?
My configuration seems OK in the plugin config :
And the sensor appears in the temp tab :
Last edited by l81occitarn on Saturday 22 November 2025 12:13, edited 1 time in total.
- Xenomes
The script runs standalone. Edit the file and fill in the values and run again.
jmd33
Hi !
I just start a Raspberry Pi3B Trixie with domoticz 2025.2 and try to install tinytuya.
First, I follow instructions for tuya devices (jasonacox) and it works (outside of domoticz, with python, I can switch my plug on/off)
Then I try to install Domoticz-TinyTUYA-Plugin with sudo pip3 install requests==2.23.0 charset-normalizer==3.0.1 tinytuya -U --break-system-packages but I have an error :
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.4.2
error: uninstall-no-record-file
Cannot uninstall charset-normalizer 3.4.2
and when I start domticzs with hardware tinytuya (named Konyks) I have an error message in the log :
Error: Konyks: handleThread: name 'requests' is not defined line 1028
It seems there is some missing module (requests) : is there an incompatibility between Trixie and tinytuya or domoticz 2025.2 ?
thanks
thanks
Raspberry Pi3B - PiOS Trixie - Domoticz 2025-2
- Xenomes
Hi, Its possible that Trixie python 3.13 can't downgrade the module. I didn't test it yet.jmd33 wrote: Sunday 14 December 2025 16:11 It seems there is some missing module (requests) : is there an incompatibility between Trixie and tinytuya or domoticz 2025.2 ?
Try:
sudo pip3 install requests charset-normalizer tinytuya -U --break-system-packagesHP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
jmd33
Thanks,
but same error.
so what would be a good configuration for tinytuya :
domoticz 2025.2 and PiOS bookworm ?
but same error.
