A very simple question, makes me feel silly: I have been running an old version of Domoticz, and am now in the process of migrating to a new R-OS and Domoticz.
It runs, but I now find myself locked-out... when I start Domoticz, all I see is the Dashboard and the Setup tabs. Looks like I'm not logged on, but how do I log on to this Domoticz version? I was looking for a logon button, but where is it?
how should I logon
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
manjh
- Domoticz version: 2020.2
how should I logon
Hans
- jvdz
- Domoticz version: 4.107
Re: how should I logon
Did you clear the cache or try Incognito mode?
manjh
Yes, I did clear the cache. But the problem cleared itself... not a good feeling, since it keeps me from understanding the root cause.
Surprisingly incognito mode does solve another riddle: when I click "Setup>Devices" the system tells me it is loading, but nothing happens.
In incognito mode it works OK.
Could this be related somehow?
Hans
- jvdz
Yes, that is also a cache issue! That is why testing with incognito mode is the best way to test as that will download all files inc all *.js includes.manjh wrote: Saturday 01 November 2025 16:20 Yes, I did clear the cache. But the problem cleared itself... not a good feeling, since it keeps me from understanding the root cause.
So likely you cleared the data cache/cookies, but the app cache still contained older version *.js includes.
manjh
OK, that makes sense!
I think I only removed cookies.
Learn something everyday!!
Hans
manjh
I think I was celebrating too quickly... Domoticz is back to showing two tabs only: Dashboard and Setup. When I click Setup->devices, it shows the complete list, so the devices are definitely there.
Any ideas?
Any ideas?
Hans
- jvdz
Also when accessed incognito?
manjh
Yes.
But the good news: I stumbled upon the root cause.
When reading about security in the Domoticz Wiki, I noticed the system will use the first admin user, when on trusted network.
Looking at my user list, I can see three: admin, GeoFence, and Hans. Then "about" page showed that I was logged on as GeoFence. That user does not have a lot of authorizations, when I changed that the tabs showed up.
I tried to log on explicitely using my own userid, but that did not work, the system still takes the first admin user.
I guess I will have to read-up on security...
Hans
- Domoticz version: 2025.1
I guess you have to make 2 of the 3 admins normal users instead of admin.
Users browsing this forum: JanJaap and 1 guest
