Python Plugin: Luxtronik Heat Pump Controller Plugin for Domoticz
JaapB
Domoticz version: 2025.2
Re: Python Plugin: Luxtronik Heat Pump Controller Plugin for Domoticz
Post by JaapB »
Ragdag wrote: Saturday 25 October 2025 10:45
JaapB wrote: Sunday 19 October 2025 12:12
Ragdag wrote: Saturday 18 October 2025 12:00
I'll give it a try not reporting back COP if not heating and see how that goes. Will need to update last seen on the device otherwise it will show timeout, I think.
Am testing with 3 devices and no updates if they are 0
I now take the monthly reports for energy used and energy generated to calculate the COP but that's in a spreadsheet abouth energyconsumption that I've been using for ages :)
Maybe it's possible to calculate on dayly basis?
Currently still testing with 3 cop devices and not sending data back when the pump is not in use and that seems to work well, as long as you disable the Domoticz Setting that is discussed here:
viewtopic.php?t=44046
Have a pretty full schedule this week but will try to finalise in the coming weeks and update github repo.
Thank you for the effort for updating and upgrading this usefull plugin.
Ragdag
Post by Ragdag »
JaapB wrote: Saturday 18 October 2025 11:46 I've been using this plugin for a while now and there is just one thing that doesn't count in the right way and that's the COP since it also counts the moments that there is no heat-exchange. So there are a lot of zero's in the list.
For example augustgives 0,15 as COP while counting it the result is 4, only hot water used.
Have not forgotten about you, am busy figuring out a proper way of doing this.
Am getting really close, only downside is that I have moved towards the new DomoticzEx framework, so it will all be new devices.
In Domoticz you can transport your history from old to new devices.
Am looking to see if there is a way to automatically do that but that seems really tricky
JaapB
Post by JaapB »
Ragdag wrote: Tuesday 02 December 2025 19:51
Thank you for putting in this effort.
I will have to plan this for a day with not too much different plans to look how it will work out.
Ragdag
Post by Ragdag »
JaapB wrote: Monday 08 December 2025 17:04
You can run them side by side, as long as you give the new plugin hardware a different name to the old one
2025-12-09 11_14_09-Domoticz - Hardware — Mozilla Firefox.png (9.24 KiB) Viewed 2714 times
Also the new topic is located here: viewtopic.php?t=44176
JacekKacz
Post by JacekKacz »
Hi there sorry for jumping into this thread but i need some help from you guys :)
1/ I have a alpha inotec heat pump which i belive the Luxtronik 2 controller (panel on the front)
2/ i can access the heat pomp web interface via http://IP/Webserver/index.html and login to service account
details:
Status instalacji
Typ pompy ciepła MSW3-12
Wersja programu V3.88.0
Revision 9015
Max/IO
Revision:
8889
CPU:
3
Regulator
Revision:
2003
Inverter SW Version 47
Stopień biwalentny 1
Stan pracy Ogrzewanie
Wydajność
but... it seems it doesnt listen on :8888
:~ $ nmap 192.168.1.114
Starting Nmap 7.80 ( https://nmap.org ) at 2025-12-19 17:52 CET
Nmap scan report for 192.168.1.114
Host is up (0.014s latency).
Not shown: 998 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
so i am a bit stucked if luxtronik... is the fron panel https://alphainnotec.pl/assets/PLIKI-DO ... KOWNIK.pdf
which i have or sth inside the firmware ? There is a BMS "Off" function which i cant turn on.
Not sure what is the proper way to use it :) many thanks for your advices
Ragdag
Post by Ragdag »
I'm not a Heat pump expert :D
The 8888 port is not a web port that responds.
Have you tried the new plugin (viewtopic.php?t=44176) if it works?
