I’m developing a Python plugin for a Luxtronik heat pump controller and I’ve run into an odd behavior with Custom Sensor devices (Type=243, SubType=31).
What I’m doing
- I calculate COP (Coefficient of Performance) only when the compressor is actually running.
- When COP is not meaningful (cooling/no requirement/standby), the plugin intentionally does not call Update() for the COP devices.
- The plugin logs “Skipping update … (no valid value)” in those cases.
Even though the plugin is not calling Update(), Domoticz still shows repeated identical COP values at 5-minute intervals in the graph export. Example:
"2025-10-19 13:00:00";3,15
"2025-10-19 13:05:00";3,15
"2025-10-19 13:10:00";3,15
"2025-10-19 13:15:00";3,15
"2025-10-19 13:20:00";3,15
"2025-10-19 13:25:00";3,15
"2025-10-19 13:30:00";3,15
2025-10-19 13:30:12.103 Status: WP: [DEVICE] Skipping update for COP total (no valid value).
2025-10-19 13:30:12.124 Status: WP: [DEVICE] Skipping update for COP heating (no valid value).
2025-10-19 13:30:12.125 Status: WP: [DEVICE] Skipping update for COP DHW (no valid value).
2025-10-19 00:35:00 -> 2025-10-19 08:40:00
What I would expect
If Update() is not called, no new datapoint should be stored. I’m trying to avoid flat “carry-forward” tails for COP because they skew daily/monthly averages.
Questions
- Does Domoticz internally “carry forward” the last known value for Custom Sensor devices into 5-minute buckets even if Update() was not called?
- If so, is there any setting or device flag to disable that behavior per device?
- Is there a recommended device type or Update() pattern for metrics like COP where “no datapoint” is preferred during idle periods?
- COP devices are Custom Sensor (Type=243, SubType=31).
- When COP is N/A I return None from the converter and the plugin never calls Update() for those units.
- I also mark COP devices as non-graphing in my own tracker logic to avoid periodic forced updates.
- I gate COP on:
- Mode (heating/DHW only),
- Passive cooling flag,
- Compressor frequency > 1 Hz,
- Power > 50 W and Heat Output > 100 W (to ignore standby/noise).
