Version 2025.2 version number in Docker
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
elgringo
- Domoticz version: Left
I run domoticz from a docker container. Updated, everything works. Opend the broweser flushed cache reload and the version remains: 2025.1 build 16804.
I am wondering if the version not has been updated or something else is wrong.
- jvdz
- Domoticz version: 4.107
Re: Version 2025.2 version number
check the domoticz log messages at startup as that should show the version.
mgugu
Same for me:
I use the tag domoticz/domoticz:stable
2025-10-14 10:23:00.355 Status: Domoticz V2025.1 (build 16804) (c)2012-2025 GizMoCuz
2025-10-14 10:23:00.355 Status: Build Hash: 493d81602, Date: 2025-10-12 09:39:00-
arma_esiea
Same too for me
Same too for me
gmarchionni
i confirm the same behaviour. build is updated...but 2025.1 is showing.
also, stable version should only show 2025.2 right? when on docker usually also the build version is visualized....would be great to standardize to the bare metal installed version.
rini52
- Domoticz version: 2025.2
Re: Version 2025.2 version number in Docker
Same here (version 2025.1 build 160804) . Docker stable release installed on a Synology NAS.
Domoticz running on Pi-4, Ubuntu(amd64), Synology Nas and VM
Hardware: RFXCOM, RFLINK, P1-smartmeter-HomeWizard, Z2M Sonoff dongle(20+ devices), Esp8266 (counters), Eaton_3S ups
rini52
pulled the release: domoticz/latest that solved the version number problem:
new:
Version: 2025.2 (build 16816)
Build Hash: 298225976
new:
elgringo
Thats odd according to the help: https://wiki.domoticz.com/Docker#Default_installationrini52 wrote: Friday 17 October 2025 13:59 pulled the release: domoticz/latest that solved the version number problem:
new:
I don't think the stable tag has been updated
- Domoticz version: 2025.1
domoticz/latest is latest compiled version (could be beta or stable, but in practice it mostly will be beta...)elgringo wrote: Friday 17 October 2025 15:43Thats odd according to the help: https://wiki.domoticz.com/Docker#Default_installationrini52 wrote: Friday 17 October 2025 13:59 pulled the release: domoticz/latest that solved the version number problem:
new:
Stable tag is updated, as is the 2025.2 tag (but could be showing 2025.1 as a misconfiguration, check the compile date 2025-10-13)
- qqqqq.png (220.66 KiB) Viewed 319 times
What tag is in your docker compose yaml?MYXOMOP wrote: Friday 17 October 2025 17:22 2 minutes ago
https://hub.docker.com/r/domoticz/domoticz/tags
image: domoticz/domoticz:stable
indeed incorrect, also for tag 2025.2.
Tecnically 2025.1 build 160804 is the same as 2025.2 but is shows incorrect.
- gizmocuz
Sorry about this, it's been corrected
that's good
- qqq.png (279.13 KiB) Viewed 213 times
gmarchionni
altough this is not the official 2025.2 version anymore being revision 2025.2.16818....should be considered Beta? The official version was 16812, based on what is written on the download page.
Also, i used the 2025.2 on the release date using the stable tag...and my revision is 16804 as indicated above....
