Easy modbus solution for Marstek home Battery
RNEE
Domoticz version: 2026.4
Post by RNEE »
Have a modbus device like the Homebattery Marstek Venus V2 5,12 Kwh and want a direct connection not using the API ?
No more waiting until data synchronize or wondering where the data went.
Like this ?
With just a few minutes of your time, a few easy steps and and only 108 configuration lines in just 2 .json files !
You can find my project on Github : https://github.com/RneeJ/Domoticz-Marstek
More is easy possible, even controlling the device, also for other modbus devices, having a rs485 port, that store data in registers.
(you need the manual for these register#)
With only the use of the PUSER-DR134 (a € 15 device) and MqttMapper plugin (by Flyingdomotic) you can bypass programming, api's etc.
Thanx to Waltervl (who told me to report here) and Flyingdomotic for helping !
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee|deCONZ Conbee II|Marstek 5,12Kwh|Pusr-dr134/dr164|Xemex Csmb|MQTTMapper|Quatt v2|DTGbot|QwatD|
eddieb
Re: Easy modbus solution
Post by eddieb »
Nice work @RNEE ...
Hope to receive my PUSER-DR134 soon and follow your work to get stuff going.
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Henielma
Domoticz version: 2026.2
Post by Henielma »
This looks good. I have already the DR134 and the Marstek V2 is ordered. '
It seems to me that this Modbus sollution reads the status and data of the Marstek.
Is there an example how to control the Marstek using Domoticz and the DR134?
RNEE
Post by RNEE »
I currently don’t have time to work on controlling, nor do i have a need to change my current NOM workmode.
From what i know now it should not be to difficult:
You can write commands to a specific topic witch the DR134 reads.
Before someting can change you have to change the command setting in register 42000 first.
Henielma
Post by Henielma »
Thanks for the info. This helps me to get started in sending commands to the Mastek.
First wait on de delivery next week.
Henielma
Post by Henielma »
I have used the DR134 to readout the registers as RNEE described in this topic. Thanks for sharing this.
I made some changes in the MqttMapper.json file to add CellVoltage and CellPower.
Using the DR134 to send Modbus registers to the Marstek seems not possible.
DR134 velden.png (190.39 KiB) Viewed 53647 times
For sending registers to the Marstek using modbus I now use a Wemon mini D1 with EspEasy flashed into it. Additionally I connected an RS485 driver board to the serial port of the Wemos. Receiving binary data from the serial port is not working here for longers registers. But send registers to the Marstek via the Modbus works fine here. The EspEasy RS-485 bus is connected in parallel to the RS485 or the DR134.
So the DR134 is still used to read the registers and the EspEasy is used to send registers to the Marstek.
Hereafter a screenshot of the Devices that are created in Domoticz. The Selector switch is used to send http messages to the EspEasy. A short rule does the transmission to the Marstek.
Screenshot Marstek control.png (41.59 KiB) Viewed 53647 times
If people are interested I can post more details about this sollution to send registers to the Marstek Venus E V2.
eddieb
Post by eddieb »
Can you please post de DR134.json and the mqttmapper.json you used ?
Henielma
Post by Henielma »
eddieb wrote: Monday 29 September 2025 21:14 Can you please post de DR134.json and the mqttmapper.json you used ?
See the attachment.
DR134 (1).zip
(919 Bytes) Downloaded 4845 times
Do not forget to change in the Domoticz Devices 'MQTT mapper - MTCE' and 'MQTT mapper - MTDE' the divider into 100 to get these values in kWh with two decimals.
Furthermore I changed the following Edge gateway settings but this is for your own choice:
Poll intervall 9000
Reporting interval into 60
This because the very fast update is not needed for my application. And the more quite Modbus gives more opportunity to send commands to the Marstek using the EspEasy.
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
Henielma wrote: Sunday 28 September 2025 16:11 ...
It is definitely possible to control the Marstek Venus (at least v1 and V2, I have a V1) using the DR134.
I am running two Python3 scripts (so not using MQTTMapper):
One that runs every 5 seconds to update domoticz sensors based on modbus registers (ie. the equivalent of the MQTTMapper solution)
One that is triggered by Domoticz switches/selectors to control the Marstek via modbus.
This is my " set_marstek" script. You just have to modify the IP of your DR134 in the code an provide the correct parameters and it should work.
No warranty and use at your own risk!!!
#!python3
# set-marstek
progname='set_marstek.py'
version = "v0.1"
from pyModbusTCP.client import ModbusClient
from pyModbusTCP import utils
import argparse
import sys
def set_mode(mode):
  if mode == 'manual':
     result = marstek.write_single_register(43000, 0) #0-manual/1-anti injection/2-trade
  elif mode == 'self':
     result = marstek.write_single_register(43000, 1) #0-manual/1-anti injection/2-trade
  elif mode == 'self_trade':
     result = marstek.write_single_register(43000, 2) #0-manual/1-anti injection/2-trade
  elif mode == 'charge':
     result = marstek.write_single_register(42010, 1) #0-stop/1-charge/2-discharge
  elif mode == 'discharge':
     result = marstek.write_single_register(42010, 2) #0-stop/1-charge/2-discharge
  elif mode == 'stop':
     result = marstek.write_single_register(42010, 0) #0-stop/1-charge/2-discharge
  else:
     result = False
  return result
def set_discharge_power(watts):
  result = marstek.write_single_register(42021, watts) # 0-2500W
  return result
def set_charge_power(watts):
  result = marstek.write_single_register(42020, watts) # 0-2500W
  return result
def set_soc_target(percentage):
  result = marstek.write_single_register(42011, percentage) # 10-100%
  return result
#Initialize
#Commandline arguments parsing
parser = argparse.ArgumentParser(prog=progname, description='Set Marstek')
parser.add_argument("-m", "--mode", type=str, choices=['manual', 'self', 'self_trade', 'soc', 'discharge', 'charge', 'stop', 'reset'], required=True)
parser.add_argument("-v", "--value", type=int )
parser.add_argument("-u", "--unit", type=int, required=False, default=1)
args = parser.parse_args()
print(progname)
print('Connect to:' )
print('IP/port    : ' + '192.168.0.15' + '-' + ' 502' ) #<= Adapt to IP & port of the DR134
print('Modbus unit: ' + str(args.unit))
#setup connection & enable control mode
try:
    marstek = ModbusClient(host='192.168.0.15', port=502, unit_id=args.unit, auto_open=False, auto_close=False) #<= Adapt to IP & port of the DR134
except ValueError:
    sys.exit("Failed to establish connection (host or port params)")
if not marstek.open(): #open socket
   sys.exit("Failed to open connectione")
#    command_on: 21930 # 0x55AA in decimal
#    command_off: 21947 # 0x55BB in decimal
if not marstek.write_single_register(42000, 21930): #control mode enable
   sys.exit("Failed to enable control mode")
if args.mode == 'reset':  #<= Does not seem to work :-(
   if not marstek.write_single_register(41000, 21930):  # 21930 is 0x55AA in decimal
      print("Failed to reset")
   else:
      print("Reset succesful")
if args.mode in {'manual', 'self' , 'self_trade'}:
   if not set_mode(args.mode):
      print("Failed to set manual/self/self_trade mode")
if args.mode == 'soc':
   if not set_soc_target(args.value):
      print("Failed to set soc target")
if args.mode in { 'charge', 'discharge', 'stop'}:
   if args.mode == 'stop':
      if set_mode('stop'):
         print("Stop mode set")
      else: print("Failed to set stop mode")
   elif args.mode == 'charge':
      print("Try setting charge mode")
      if args.value:
         print("value found")
         if set_charge_power(args.value):
            print("Charge power set")
            if set_mode('charge'):
               print("Charge mode set")
            else: print("Failed to set charge mode")
         else: print("Failed to set charge value")
      elif set_mode('charge'):
      else:
   elif args.mode == 'discharge':
      print("Try setting discharge")
      if args.value:
         if set_discharge_power(args.value):
            print("Discharge power set")
            if set_mode('discharge'):
               print("Discharge mode set")
            else: print("Failed to set discharge mode")
         else: print("Failed to set discharge value")
      elif set_mode('discharge'):
      else:
marstek.close()
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
Henielma
Re: Easy modbus solution for Marstek home Battery
Post by Henielma »
Good to see that it is possible to control the Marstek using the DR134 from Domoticz. For me it is not needed now because I use an EspEasy module for this. But for other people this sounds like an easy sollution.
bldewit
Domoticz version: Stable
Post by bldewit »
Joost, could you also post the script you run to update your Domoticz-sensors with values from the Marstek every 5 seconds?
And is there a link/post for the hardware/interfacing I need with the DR134?
Thx,
Bart
joostvanderlinde wrote: Thursday 20 November 2025 1:09
#!python3
# set-marstek
version = "v0.1"
import argparse
import sys
def set_mode(mode):
  else:
     result = False
  return result
  return result
  return result
  return result
#Initialize
print(progname)
try:
except ValueError:
   else:
      if args.value:
      else:
      if args.value:
      else:
marstek.close()
Running on rPi 4b (main) and rPi 3b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
eddieb
Post by eddieb »
As the modbus discussion is a bit quiet here ...
Seems modbus is by far the most stable way to communicate to the Marstek battery
Reading all the HA stuff it should be rather easy to read all you want using a elfin EW11 of EE11 (both are also cheap ...)
Perhaps someone with far more programming knowledge than I could give it a try to use ModbusTCP ???
according to https://github.com/ViperRNMC/marstek_venus_modbus it should also work with the dr134 in modbus-tcp mode ...
RNEE
Post by RNEE »
Well, it worked for me flawless since july 2025.
I run always in NOM mode, self-consumption, and the reporting works the way i need it. I have no need for controlling the Marstek from Domoticz.
I made some automated warnings like a high temperature warning over telegram.
If you like you can add more reporting registers from the mentioned github page to the DR134. i can add some for you in the .json configuration. Just tell me.
Controlling the Marstek Venus needs more study, but i think it should be possible wth the DR134 and mqttmapper.
eddieb
Post by eddieb »
Henielma wrote: Monday 29 September 2025 21:49
See the attachment. DR134 (1).zip
Poll intervall 9000
I added the 2 extra devices you are using but the batteryPower you read on 32102 gives me a totally different value, it never reads more than 1000W while it charges to 5.12kw ... Are you using a Venus E2 or an other model ?
Henielma
Post by Henielma »
These sensors are about power not energy.
The maximum power of the Marstek Venus E2 is 2500 Watt
The maximum energy that can be stored is 5.12 kWh (kilo Watt Hour)
manuloup
Post by manuloup »
I own a Marstek Venus E Gen 3 battery and I would like to control it with domoticz using modbus, since no extra hardware is required.
I also checked and the port 502 is responding :
root@domoticzvm:/home/pi/domoticz/scripts# cat test.py
from pymodbus.client import ModbusTcpClient
client = ModbusTcpClient("192.168.1.19", port=502)
client.connect()
rr = client.read_holding_registers(
    address=32104,
    count=1,
    slave=1
print(rr.registers)
client.close()
root@domoticzvm:/home/pi/domoticz/scripts# python3 test.py
[17]
Sadly, there is currently no plugin for Marstek Venus E Gen 3 using modbus with domoticz.
I do not have the skills to create one sadly, but may be I can help.
Am I the only one interested, since the local API is still not working (and I am not optimistic enough to believe it will one day) ?
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
jslegers
Post by jslegers »
I would also be interested in a a modbus plugin.
