New Philips hue bridge Pro support
Bidibulle
Domoticz version: 2025.1
Post by Bidibulle »
I just purchased the new Philips Hue Pro, and it doesn't work on Domoticz when retrieving the token.
Error : method, GET, not available for resource, / when Register on Bridge
log : Error: Philips Hue Bridge: Invalid data received, or invalid IPAddress/Username!
Domoticz Version: 2025.1 (build 16777) - Build Hash: a4dcfe349
Last edited by Bidibulle on Friday 12 September 2025 20:11, edited 1 time in total.
gizmocuz
Re: New Philipe hue bridge Pro support
Post by gizmocuz »
This error you should not get when registering the user on the bridge but when it tries to poll the status
In the hardware setup page, disable the hardware
Next, empty the username, set the bridge in LINK mode, next press on 'Register on Bridge' in the hardware page
You should now get a username.
Next make sure the 'enabled' checkbox is set to enabled, press the 'Update' and it should work.
Did you switch from an old bridge to the new one? Then disable the old hardware, and start with a fresh hardware
Bidibulle
Re: New Philips hue bridge Pro support
Post by Bidibulle »
I did a fresh install, with the Bridge Pro, same message.
It works with the old Hue.
There's probably a change in the Hue Pro API because I tested it with Home Assistant, and a new version was released with a fix for the Hue Pro. (https://community.home-assistant.io/t/u ... pro/927325)
Second test: I generated a token using this procedure: https://developers.meethue.com/develop/get-started-2/
Copy the token into my new Domoticz instance, and all the lights are displayed.
The states are also displayed, on/off, etc. However, any action in Domoticz doesn't work with Error: Hue Bridge Pro: Error received: invalid/missing parameters in body
sloeber70
Domoticz version: latest
Post by sloeber70 »
I have the same problem.
I've tried both setups... none are working.
indeed by using the api method and getting a userkey that way.. it does find all the devices, But Domoticz cannot instruct them.
Also tried gizmocuz method.. not working still "/get error" error message.
Strange thing is that the log reports all HUE things when you manually press a dimmer switch.
When I click a lamp button, it does show that the lamp is on, but the lamp itself stays off. Furthermore, the lamp gets an off status within 5 secs in Domoticz.
Log entries:
2025-09-19 10:51:27.485 Error: HUEPRO: Error received: invalid/missing parameters in body
2025-09-19 10:51:27.487 HUEPRO: Light/Switch (WCLamp2)
2025-09-19 10:51:33.703 HUEPRO: Light/Switch (WCLamp2)
2025-09-19 10:51:56.010 Error: HUEPRO: Error received: invalid/missing parameters in body
2025-09-19 10:51:56.013 HUEPRO: Color Switch (Living GO 1)
2025-09-19 10:52:06.086 HUEPRO: Color Switch (Living GO 1)
2025-09-19 10:52:16.994 HUEPRO: Color Switch (Keukenplafond)
2025-09-19 10:52:17.005 HUEPRO: Color Switch (Keukenaanrecht)
2025-09-19 10:52:17.010 HUEPRO: Color Switch (Group Keuken)
2025-09-19 10:52:17.429 HUEPRO: Light/Switch (ZLLSwitch KeukenDimmer)
Kind regards,
Sloeber70
Linux Debian 13 standard edition
Domoticz latest beta on ProxmoxVE Virtual Machine
sloeber70
Post by sloeber70 »
Still testing:
errolog:
2025-09-19 13:33:16.118 Status: User: pcla (IP: 10.10.3.114) initiated a switch command (581/BureelStaandeLamp/Off)
2025-09-19 13:33:16.387 Error: LNTBEHUEPRO: Error received: invalid/missing parameters in body
2025-09-19 13:33:16.389 LNTBEHUEPRO: Color Switch (BureelStaandeLamp)
2025-09-19 13:33:21.128 LNTBEHUEPRO: Color Switch (BureelStaandeLamp)
2025-09-19 13:33:23.580 Status: User: pcla (IP: 10.10.3.114) initiated a switch command (581/BureelStaandeLamp/Off)
2025-09-19 13:33:24.007 Error: LNTBEHUEPRO: Error received: invalid/missing parameters in body
2025-09-19 13:33:24.009 LNTBEHUEPRO: Color Switch (BureelStaandeLamp)
2025-09-19 13:33:25.912 Status: User: pcla (IP: 10.10.3.114) initiated a switch command (581/BureelStaandeLamp/On)
2025-09-19 13:33:26.334 Error: LNTBEHUEPRO: Error received: invalid/missing parameters in body
2025-09-19 13:33:26.337 LNTBEHUEPRO: Color Switch (BureelStaandeLamp)
Tried https by using 443. Not OK
Moved HUE Bridge tot my domoticz test system: not OK. same errors.
So final:
Device states are updated
Manual operation of lamps, dimmers, etc.. in Domoticz not possible
States getting updated.
** Security problem *** ???
Kind regards,
Sloeber70
Bidibulle
Post by Bidibulle »
Feedback:
On the Pro bridge, the HTTP connection no longer works, only HTTPS.
I created Build Domoticz from source, modified the file hardware/PhilipsHue/PhilipsHue.cpp.
Changed all HTTP connections to HTTPS.
Added the hardware for the Pro and set port 443 instead of 80.
Registered on bridge, Token ✅
All devices, groups, and scenes ✅
Actions (On/Off) ✅
I created another hardware with the V2 and everything works too.
The developer will need to modify this file for the next build.
sloeber70
Post by sloeber70 »
Hoping this will be implemented soon.
Thx for the update.
Kind regards,
Sloeber70
Bidibulle wrote: Friday 19 September 2025 19:29 Feedback:
Actions (On/Off) ✅
Please create a PR for this or at least a github issue. There should be an option now to use http or https
Bidibulle
Post by Bidibulle »
Bidibulle
Post by Bidibulle »
I tested it with build 16785 and everything is fine.
Thank you very much ☺️
sloeber70
Post by sloeber70 »
here too .. THX !! Working fine !!
Kind regards,
Sloeber70
Alain
Domoticz version: 2022.1
Post by Alain »
I just bought one of these new bridges. Looks like I'll finally need to update Domoticz. I'm still on 2022.1 build 14394. I'm pretty wary of doing this because in past updates it always caused a lot of work because things wouldn't work anymore due to compatibility of all sorts of things like python versions etc.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Use docker if you are worried about that. For latest beta with the hue Pro support you have to be on a recent OS as it needs libssl3. See viewtopic.php?t=43485
