Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
Since I moved to 2025.1 I've had a problem with the HDD device on my Pi motherboard. The old device stopped working, I believe due to changes discussed here viewtopic.php?p=325078&hilit=motherboard#p325078
Whilst I can allow the new device to be created (which does update), if I try to replace the old one, it transfers all of the new data across then doesn't update anymore. A few seconds later a new device called HDD / is recreated
Debug logging shows the replace, the subsequent automatic deletion of the incorrect device then nothing else until I allow the recreation.
Any ideas how I can fix this given the logs don't show much?
I did & must now have tried maybe 10 times following beta version upgrades.
I also tried the other way around after previous fails to see whether the histories would merge. Obviously they didn't & I needed to restore from a backup so that I didn't lose 10 years of data.
I'd really hoped the debug log would give me a clue but it looks to me that Domoticz thinks it's working correctly & the problem is with the change in the reporting of the HDD device
Is there a way that I can change the properties of the original device so that they exactly match those of the one that's been reported since 2025.1, ie DevID 00000450 or would this be a bad idea?
