Problem Replacing Device Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
C4rtm4N
Post by C4rtm4N »
Since I moved to 2025.1 I've had a problem with the HDD device on my Pi motherboard. The old device stopped working, I believe due to changes discussed here viewtopic.php?p=325078&hilit=motherboard#p325078
Whilst I can allow the new device to be created (which does update), if I try to replace the old one, it transfers all of the new data across then doesn't update anymore. A few seconds later a new device called HDD / is recreated
Debug logging shows the replace, the subsequent automatic deletion of the incorrect device then nothing else until I allow the recreation.
Any ideas how I can fix this given the logs don't show much?
2025-08-08 00:26:26.218  Status: Replace old device 14 to new device 718 from 2025-05-10 10:02:52.
2025-08-08 00:26:26.470  Debug: CSQLHelper::DeleteDevices: ID: 718
2025-08-08 00:26:31.282  Debug: SQLH UpdateValueInt Raspberry01 CPU HwID:1  DevID:0000044D Type:243  sType:6 nValue:0 sValue:3.02 IDX: 16
2025-08-08 00:26:31.283  Motherboard: General/Percentage (Raspberry01 CPU)
2025-08-08 00:26:51.294  Debug: SQLH UpdateValueInt HDD /boot/firmware HwID:1  DevID:0000044E Type:243  sType:6 nValue:0 sValue:12.40 IDX: 715
2025-08-08 00:26:51.295  Motherboard: General/Percentage (HDD /boot/firmware)
2025-08-08 00:26:51.299  Debug: Device creation failed, Domoticz settings prevent accepting new devices.
2025-08-08 00:29:41.352  Debug: SQLH UpdateValueInt  HwID:1  DevID:00000450 Type:243  sType:6 nValue:0 sValue:57.44 IDX: 743
2025-08-08 00:29:41.353  Motherboard: General/Percentage (HDD /)
gizmocuz
Re: Problem Replacing Device
Post by gizmocuz »
Just to be sure (because it is a normal percentage device):
Did you press 'Edit' on the >>> OLD <<< device, pressed 'Replace' and selected the >>> NEW <<< device?
C4rtm4N
Post by C4rtm4N »
I did & must now have tried maybe 10 times following beta version upgrades.
I also tried the other way around after previous fails to see whether the histories would merge. Obviously they didn't & I needed to restore from a backup so that I didn't lose 10 years of data.
I'd really hoped the debug log would give me a clue but it looks to me that Domoticz thinks it's working correctly & the problem is with the change in the reporting of the HDD device 😪
Is there a way that I can change the properties of the original device so that they exactly match those of the one that's been reported since 2025.1, ie DevID 00000450 or would this be a bad idea?
gizmocuz
Post by gizmocuz »
I would personally just delete the old sensor... who cares about 10 years of history about harddisk size? :mrgreen:
I think I know what is going on....
This hardware class is using the device 'Options' field to store certain information and this was not copied when replacing a device
Could you try with beta 16758, this should solve the issue
C4rtm4N
Post by C4rtm4N »
Many thanks, this has done the trick :D
