Hi All,
I have been running in to issues with my domoticz setup. I have a Solaredge inverter and have used the solaredge modbus plugin by Addie Janssen. It all worked but due to an error the Raspberry upgraded and the installation was broken.
I was able to restore the system but I'm no longer able to get this plugin working. The combination Python requirements is not valid to run on Bookworm/Python 3.11.
I have been going back and forth with the help of chat GPT to get stuff running but in ends up the same.
Log:
- Spoiler: show
- 2025-07-18 12:24:13.908 Error: Solaredge Omvormer: (SolarEdge_ModbusTCP) failed to load 'plugin.py', Python Path used was '/home/domoticz/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/:/home/domoticz/.local/lib/python3.11/site-packages:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: Traceback (most recent call last):
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: File "/home/domoticz/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 16, in <module>
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: import solaredge_modbus
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: File "/home/domoticz/.local/lib/python3.11/site-packages/solaredge_modbus/__init__.py", line 7, in <module>
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: from pymodbus.client import ModbusTcpClient
2025-07-18 12:24:13.910 Error: Solaredge Omvormer: ImportError: cannot import name 'ModbusTcpClient' from 'pymodbus.client' (/home/domoticz/.local/lib/python3.11/site-packages/pymodbus/client/__init__.py)
I tried multiple versions of solaredge_modbus and pymodbus but found no working solution. Any tips?
