SolarEdge production throttling from Domoticz
- jvdz
- Domoticz version: 4.107
Re: SolarEdge production throttling from Domoticz
Had a look this morning at the code changes in 2.0.4 and must say that Addie made a very nice update there incorporating the Meters and Battery fields already. He elected to make that selectable whether the plugin looks at them or not.
There is also a ACTIVE_POWER_LIMIT field in there but shown as a text device instead of making it a Dimmer with the update logic.
I will work in the coming days on an update of that code to incorporate the Dimmer and the Sync options.
In the meantime, there is an update pushed to github for the plugin in the active_power_limit branch which will support the On/Off function of the dimmer.
eddieb
I tested the power throttle on my SE3500H and it works nice !
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
- jvdz
Thanks for the feedback!eddieb wrote: Saturday 14 June 2025 16:09 I tested the power throttle on my SE3500H and it works nice !
I've merged the change for the dynamic Power also into my Fork of the "meters" branch so people that currently use the 2.0.4 beta version of the plugin can also use it. The current TEXT device will be replaced by a Dimmer.
eddieb
should I something with this message ?
/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py:64: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
import pkg_resources
2025-06-15 20:24:59.320 Status: Solaredge: Initialized version 1.2.3, author 'Addie Janssen Modified by:jvdzande'
2025-06-15 20:24:59.323 Status: Solaredge: solaredge_modbus version: 0.8.0
2025-06-15 20:24:59.323 Status: Solaredge: pymodbus version: 3.6.9
2025-06-15 20:24:59.550 Status: Solaredge: Connection established with: 192.168.26.239:1502 Device Address: 1
2025-06-15 20:24:59.550 Status: Solaredge: Inverter type: sunspecDID.SINGLE_PHASE_INVERTERRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
eddieb
ok, running your "meters" branch now
power slider does not work correct ... on/of does not work
2025-06-15 20:40:48.824 Status: User: admin (IP: 192.168.26.220) initiated a switch command (179/Solaredge - Inverter - Active Power Limit/Set Level)
2025-06-15 20:40:48.833 Error: Solaredge: Call to function 'onCommand' failed, exception details:
2025-06-15 20:40:48.835 Error: Solaredge: Traceback (most recent call last):
2025-06-15 20:40:48.835 Error: Solaredge: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 701, in onCommand
2025-06-15 20:40:48.835 Error: Solaredge: _plugin.onCommand(Unit, Command, Level, Hue)
2025-06-15 20:40:48.835 Error: Solaredge: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 401, in onCommand
2025-06-15 20:40:48.835 Error: Solaredge: DomoLog(LogLevels.DSTATUS, f"Send active_power_limit Level {Level} to SolarEdge")
2025-06-15 20:40:48.835 Error: Solaredge: ^^^^^^^^^^^^^^^^^
2025-06-15 20:40:48.835 Error: Solaredge: File "/usr/lib/python3.11/enum.py", line 789, in __getattr__
2025-06-15 20:40:48.835 Error: Solaredge: raise AttributeError(name) from None
2025-06-15 20:40:48.835 Error: Solaredge: AttributeError: DSTATUSRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
- jvdz
Thanks, I will have a look at those 2 items tomorrow and let you know.
EDIT:
EDIT:
That should be fixed now. I haven't tested it, but it's a Cut&Paste from the other branch and that loglevel isn't available in this Branch, so pretty sure this should fix it. Will only be able to test it myself tomorrow.eddieb wrote: Sunday 15 June 2025 20:43 ok, running your "meters" branch now
power slider does not work correct ... on/of does not workCode: Select all
eddieb
correct, just tested, looks OK. no error
eddieb
3 devices are created by the latest version ...
- jvdz
Yes when you select in the hardware setting to only monitor the inverter, these 3 are added. They all 3 deal with production regulation and the mod i made changes the active power limit device from text to dimmer so you can dynamically change it. Details can be found in the pdf i linked in the initial post.
I assume that when you select another option for monitoring, more devices will be generated for Meter/Battery.
eddieb
I tried the "meters version" on the system with the battery and meters connected .
No luck yet because of an older version of "git" on that system where I was not able to switch branch ...
1kke
I'm currently testing the "Meters2" branch from jvdz with just one inverter connected, and it's working flawlessly. In addition, I'm retrieving hourly electricity prices from Enever to support my dynamic energy contract.
Although the inverter is capable of automatically throttling the active power limit, I find its built-in logic not ideal for my needs.
To improve this, I combined the "meters" branch with the hourly Enever prices in a small DzVents script that automatically adjusts the inverter's active power limit based on the current price. The script runs every hour, exactly 10 seconds past the hour.
If the electricity price is €0.00 or lower and the active power limit is not already set to 0, the script sets it to 0.
If the price is above €0.00 and the limit is not already 100, the script sets the power output to 100.
This gives me more control and ensures the inverter responds more intelligently to real-time market prices.
Dzvents:
Dzvents:
active = true,
timer = { 'every hour' },
customEvents = { 'delayed' },
if item.isTimer then
domoticz.emitEvent('delayed', domoticz.time.rawTime).afterSec(10)
local prijs_device = domoticz.devices("Actual Electricity Price")
local dimmer = domoticz.devices("Inverter - Active Power Limit")
local prijs = tonumber(prijs_device.rawData[1]) or tonumber(prijs_device.value)
local huidige_waarde = dimmer.level
local gewenste_waarde = nil
if prijs then
if prijs <= 0 and huidige_waarde ~= 0 then
gewenste_waarde = 0
elseif prijs > 0 and huidige_waarde ~= 100 then
gewenste_waarde = 100
if gewenste_waarde ~= nil then
dimmer.setLevel(gewenste_waarde)
domoticz.log(string.format("🔄 Prijs is %.3f EUR/kWh, ActivePowerLimit aangepast naar %d%%", prijs, gewenste_waarde), domoticz.LOG_STATUS)
domoticz.log(string.format("✅ Prijs is %.3f EUR/kWh, ActivePowerLimit staat al correct (%d%%)", prijs, huidige_waarde), domoticz.LOG_STATUS)
domoticz.log("❌ Kon prijs niet omzetten naar getal: " .. tostring(prijs_device.rawData[1] or prijs_device.value), domoticz.LOG_ERROR)
eddieb
I finally managed to get git on the older domoticz system to switch to the "meters" branch
It created the 3 devices BUT the switch is created as a text device ...
- jvdz
Then you are pointing to the original git repo,not my version.
I am currently working on a bigger change to the meters branch which will always check the received info for Meters & Batteries and removed the option to select what to look for. This will free up the last config variable to available for the p1sync option.
eddieb
hmm, I don't think that I am in the wrong repo...
$ git log
commit d1e41afca5cc0f0e262dddb375f6433cb243a54f (HEAD -> meters, origin/meters, origin/Meters2)
Author: jvanderzande <[email protected]>
Date: Sun Jun 15 21:00:46 2025 +0200
Fix error logmessages.
commit 471f26ea791dc67d0d4debece8e97b0ea8ac02f4
Date: Sun Jun 15 19:43:56 2025 +0200
update requirements to 0.8.0
commit c2b8f6ae544857c33bc64f06f33605b930a29aea
Date: Sat Jun 14 19:04:52 2025 +0200
make MaxPower dimmer device and added ability to Send the MaxPower to SolarEdge
commit af45958a07c96fcfaaaf25a6d78c7b527b4c3234
Author: Addie Janssen <[email protected]>
Date: Sat Jul 22 16:21:45 2023 +0200
Bumped version up to 2.0.4RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
- jvdz
My Bad, you have a 3fase inverter and I only updated the device for a 1-fase SolarEdge which I test with.
Have pushed an update to fix that to meters.
Nearly ready to push an update to Meters2, which is the meters branch with updates to check for Batteries and Meters without having to set it.
It also fixes issues when there is no actual battery connected like in my case but still "thinks" they are there since my SE returns the batteries block data with some default values in it.
Soon I will make the decision on how to proceed with this and cleanup the extra branches and go forward with one updated master.
Iam leaning towards this last Meters2 version.
Does anybody see any reason why we should leave the Average/Max calculations in there as I would think that domoticz should simply receive the inverter raw/real data?
eddieb
Allready saw the commit and updated here, looking OK now
next I am going to try the meters and battery part
- jvdz
Niceeddieb wrote: Monday 16 June 2025 19:09 Allready saw the commit and updated here, looking OK now
Could you try that with Meters2 that I just pushed?
eddieb
I will try,
"meters" gave me 94 new devices and a lot of errors ...
All values are 0 (zero)
- jvdz
Currently, a device is created for nearly each value received from the SolarEdge device in the Meters and Battery data blocks, so maybe it is sensible to limit that to the essential devices?
eddieb
Ok, "Meters2" gives me also 94 new devices (all showing 0 (zero)
and a lot of the following errors
2025-06-16 19:25:58.480 Solaredge direct: Inverter returned information for Inverter
2025-06-16 19:25:58.702 Solaredge direct: update device: Active Power Limit nValue:2 sValue:100.00
2025-06-16 19:25:58.703 Solaredge direct: Updated 16 values out of 25
2025-06-16 19:25:59.568 Solaredge direct: Inverter returned information for Meter1
2025-06-16 19:25:59.571 Error: Solaredge direct: Call to function 'onHeartbeat' failed, exception details:
2025-06-16 19:25:59.573 Error: Solaredge direct: Traceback (most recent call last):
2025-06-16 19:25:59.573 Error: Solaredge direct: File "/home/pi/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 697, in onHeartbeat
2025-06-16 19:25:59.574 Error: Solaredge direct: _plugin.onHeartbeat()
2025-06-16 19:25:59.574 Error: Solaredge direct: File "/home/pi/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 253, in onHeartbeat
2025-06-16 19:25:59.574 Error: Solaredge direct: self.processValues(device_details, values)
2025-06-16 19:25:59.575 Error: Solaredge direct: File "/home/pi/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 326, in processValues
2025-06-16 19:25:59.575 Error: Solaredge direct: if (unit[Column.ID + offset] == inverters.InverterUnit.ACTIVE_POWER_LIMIT ):
2025-06-16 19:25:59.576 Error: Solaredge direct: IndexError: list index out of rangeRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
