Can't get Netfit Easy to run
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
I can't get nefit easy to run, installed through dockge
services:
nefiteasy-http-server:
ports:
- 3000:3000
container_name: myNefitEasy
environment:
- NEFIT_SERIAL_NUMBER=XXXXXX
- NEFIT_ACCESS_KEY=XXXXXXXXX
- NEFIT_PASSWORD=XXXXXX
image: trafex/nefiteasy-http-server
networks: {}
It says in Domotics: Error: Nefit_Easy: Error getting http data! I don't know what to do anymore
Edit Waltervl: removed credentials
services:
ports:
- 3000:3000
environment:
networks: {}
Re: Can't get Netfit Easy to run
edit you access-key ...
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
I don't understand, how must I edit the access-key?
- Domoticz version: 2024.7
Does it run in Docker? What does the log of the docker say?
Did you stop the normal nefit-easy server on your system?
And stop posting credentials like ID and password/PIN codes on the internet!!!!!
Sorry about the credentials ....
dockge says:
[email protected] start
myNefitEasy | > easy-server --host=0.0.0.0
myNefitEasy |
myNefitEasy | HTTP server listening on http://0.0.0.0:3000
no other comments, I do wonder why its not sending on http://127.0.0.1:3000? Can you put that in the docker file?
dockge says:
myNefitEasy |
That probably depends how the docker image has been created.....
Does it even work properly?
In the NefitEasy wiki page https://wiki.domoticz.com/NefitEasy there is a troubleshooting part.
It should give a valid JSON result.
You can also try
or
If one of these works then you have to change the settings accordingly in Domoticz.
If you run Domoticz also in a Docker you probably have to change the settings anyway as 127.0.0.1 is the localhost IP in the container and not of the Domoticz server.
curl http://127.0.0.1:3000/api/status
You can also try
curl http://0.0.0.0:3000/api/status
curl http://<Domoticz Server IP>:3000/api/status
I know I have to change the settings .... but which
curl http://127.0.0.1:3000/api/status:
{"user mode":"manual","clock program":"auto","in house status":"ok","in house temp":27,"hot water active":true,"boiler indicator":"off","control":"weather","temp override duration":0,"current switchpoint":32,"ps active":true,"powersave mode":true,"fp active":false,"fireplace mode":false,"temp override":false,"holiday mode":false,"boiler block":null,"boiler lock":null,"boiler maintenance":null,"temp setpoint":15,"temp override temp setpoint":17,"temp manual setpoint":10,"hed enabled":null,"hed device at home":null,"outdoor temp":30.3,"outdoor source type":"physical"}hjz@debian:/opt/stacks/domoticz/config/plugins/iDetect$
seems all fine
I checked internet and they all show the same settings in the docker file, which one to change?
seems all fine
You are running Domoticz also in a docker?
Find the real IP of your Domoticz server by open up a terminal window and execute the command:
Then you have to change in Domoticz menu Setup - Hardware - NefitEasy hardware gateway http://127.0.0.1:3000 into http://<Domoticz Server IP>:3000
ifconfig -a
That was very simple ... but most things are if you know where to look.
Working!
Working!
It is more that you have to understand what is happening when you use docker.....
