Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Xenomes
Domoticz version: 2025.2
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Post by Xenomes »
reinestein wrote:
There was a minor compatibility issue between Domoticz and Python 3.11. This has now been resolved in the latest Domoticz update. I've also updated the plugin accordingly. Make sure to update both to ensure proper functionality.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
reinestein
Domoticz version: 2023.1
Post by reinestein »
Xenomes wrote: Tuesday 03 June 2025 19:34 There was a minor compatibility issue between Domoticz and Python 3.11. This has now been resolved in the latest Domoticz update. I've also updated the plugin accordingly. Make sure to update both to ensure proper functionality.
It works! No errors anymore 👍
Varazir
Post by Varazir »
I updated the plugin
First I got this
pi@domoticz:~/domoticz/data/plugins/Domoticz-TinyTUYA-Plugin $ git pull
remote: Enumerating objects: 114, done.
remote: Counting objects: 100% (113/113), done.
remote: Compressing objects: 100% (69/69), done.
remote: Total 104 (delta 42), reused 94 (delta 34), pack-reused 0 (from 0)
Receiving objects: 100% (104/104), 497.89 KiB | 1.25 MiB/s, done.
Resolving deltas: 100% (42/42), completed with 6 local objects.
From https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin
   0aa22fc..06b5aac  Master     -> origin/Master
   e0a7efa..62c8e7a  pulsar     -> origin/pulsar
Updating 0aa22fc..06b5aac
error: The following untracked working tree files would be overwritten by merge:
        __pycache__/plugin.cpython-311.pyc
Please move or remove them before you merge.
Aborting
so I moved the folder mv Domoticz-TinyTUYA-Plugin ~/ so I have a backup
pi@domoticz:~/domoticz/data/plugins $ git clone https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin.git
Cloning into 'Domoticz-TinyTUYA-Plugin'...
remote: Enumerating objects: 1560, done.
remote: Counting objects: 100% (340/340), done.
remote: Compressing objects: 100% (152/152), done.
remote: Total 1560 (delta 237), reused 286 (delta 188), pack-reused 1220 (from 2)
Receiving objects: 100% (1560/1560), 857.64 KiB | 1.11 MiB/s, done.
Resolving deltas: 100% (842/842), done.
All looks OK so far
This is just a warning but still,
2025-06-12 10:19:07.560 Status: TinyTUYA: Initialized version 2.2.2, author 'Xenomes'
2025-06-12 10:19:07.571 Error: TinyTUYA: !! Warning Plugin overruled by local json files !!
Just to ignore it ?
I'm running in docker.
To note I didn't change to install the pyton plugin in the customstart.sh file.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
bertv
Post by bertv »
Hallo, I need some help.
I have installed the plugin and everything works except for two roller shutter controls. These are from the brand Nedis and work in the Tuya app without any problems. On the Tuya Developers Platform I can control them. Can I change something myself to make them work?
List of devices:
"name": "Rolluik zijkant",
"id": "62331156ecfabc691541",
"key": "Deleted",
"mac": "ec:fa:bc:69:15:41",
"uuid": "62331156ecfabc691541",
"sn": "PGBG28KZH0005B",
"category": "cl",
"product_name": "Curtain controller",
"product_id": "AXnFs1bJQITWAPA4",
"biz_type": 0,
"model": "WIFIWC10WT",
"sub": false,
"icon": "https://images.tuyaeu.com/smart/icon/15 ... br0h_0.png"
Properties of device: 62331156ecfabc691541
"result": {
"category": "cl",
"functions": [
"code": "status",
"desc": "{\"range\":[\"1\",\"2\",\"3\"]}",
"name": "Status",
"type": "Enum",
"values": "{\"range\":[\"1\",\"2\",\"3\"]}"
"status": [
"code": "status",
"name": "Status",
"type": "Enum",
"success": true,
"t": 1748204664968,
"tid": "3ffc149c39a611f0b50a8ad9f66a9c16"
Status of device: 62331156ecfabc691541
"result": [
"code": "status",
"value": "2"
"success": true,
"t": 1748204665301,
"tid": "402d947539a611f0b7363af2f1e8cfff"
Xenomes
Post by Xenomes »
Varazir wrote: Thursday 12 June 2025 10:28 I updated the plugin
First I got this
Aborting
All looks OK so far
Just to ignore it ?
There was an error in the latest push. Please perform a new pull - this should resolve the message you're seeing.
Xenomes
Post by Xenomes »
bertv wrote: Thursday 12 June 2025 11:08 Hallo, I need some help.
List of devices:
"key": "Deleted",
"category": "cl",
"biz_type": 0,
"sub": false,
"result": {
"category": "cl",
"functions": [
"code": "status",
"name": "Status",
"type": "Enum",
"status": [
"code": "status",
"name": "Status",
"type": "Enum",
"success": true,
"t": 1748204664968,
"result": [
"code": "status",
"value": "2"
"success": true,
"t": 1748204665301,
The json appears to be low in values. Did you try configure the device using DP instructions?
bertv
Post by bertv »
[/quote]
[/quote]
Yes, all the devices are set to DP instructions.
The DP instruction set is only status nothing els.
Xenomes
Post by Xenomes »
bertv wrote: Thursday 12 June 2025 23:02 The json appears to be low in values. Did you try configure the device using DP instructions?
Maybe 1 is up, 2 is stop/hold, and 3 is down... Could added to see what it does.
bertv
Post by bertv »
Xenomes wrote: Friday 13 June 2025 21:12
[/quote]
If possible please. 1 is up, 2 is down and 3 is stop.
Xenomes
Post by Xenomes »
bertv wrote: Saturday 14 June 2025 8:28 If possible please. 1 is up, 2 is down and 3 is stop.
Added in version 2.2.4
bertv
Post by bertv »
Xenomes wrote: Sunday 15 June 2025 10:01
Everything is working fine now, may I thank you very much for adjusting the software.
Varazir
Post by Varazir »
I have trying to install the python modules using customstart.sh file but I get an error
https://gist.github.com/varazir/d67eb61 ... 6f82e58e32
I have moved back to my own solution for the time being.
Xenomes
Post by Xenomes »
Varazir wrote: Tuesday 17 June 2025 10:21 I have trying to install the python modules using customstart.sh file but I get an error
Strange, but if you solution works, no problem.
Varazir
Post by Varazir »
Xenomes wrote: Tuesday 17 June 2025 20:25
My solution is to install the modules outside the docker and use this in my compose file ( I # it when I tested with the customstart.sh installation) .
    environment:
      - TZ=Europe/Stockholm
      - PYTHONPATH=/opt/domoticz/userdata/Domoticz_Python_Environment/:/opt/venv/lib/python3.11/site-packages
84dasilva
Post by 84dasilva »
Request for update plugin;
Dehumidifier.
On/off switch works
Mode switch works
Fan speed switch works
Please fix
Set dehumidify value (it shows dropdown values, but doesnt work)
Add: show humidity_indoor, temp_indoor.
Childlock switch.
I see even more functionality in the json...
Thanks in advance.
List of devices:
"name": "MEDION Dehumidifier DH30S",
"id": "bffb66aeb14b86a49edqst",
"key": "Deleted",
"mac": "fc:3c:d7:ef:1e:b7",
"uuid": "d9042d8037864783",
"sn": "10015795002331",
"category": "cs",
"product_name": "MEDION Dehumidifier DH30S",
"product_id": "sime5zc7l7svabdo",
"biz_type": 0,
"model": "DH30S",
"sub": false,
"icon": "https://images.tuyaeu.com/smart/icon/ay ... 904e6a.png"
"name": "LED HOEK VLOERLAMP",
"id": "bfb09e9ebfb177ae70wvta",
"key": "Deleted",
"mac": "d8:1f:12:40:ee:c2",
"uuid": "3f94d32546702aa8",
"category": "dd",
"product_name": "LED CORNER FLOORLAMP ",
"product_id": "sep7rlajunuqmpbo",
"biz_type": 0,
"model": "3H",
"sub": false,
"icon": "https://images.tuyaeu.com/smart/icon/ay ... 90178d.png"
Properties of device: bffb66aeb14b86a49edqst
"result": {
"category": "cs",
"functions": [
"code": "switch",
"desc": "{}",
"name": "\u5f00\u5173",
"type": "Boolean",
"values": "{}"
"code": "dehumidify_set_value",
"desc": "{\"unit\":\"%\",\"min\":30,\"max\":80,\"scale\":0,\"step\":5}",
"name": "\u6e7f\u5ea6\u8bbe\u7f6e",
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":30,\"max\":80,\"scale\":0,\"step\":5}"
"code": "fan_speed_enum",
"desc": "{\"range\":[\"low\",\"high\"]}",
"name": "\u98ce\u901f",
"type": "Enum",
"values": "{\"range\":[\"low\",\"high\"]}"
"code": "mode",
"desc": "{\"range\":[\"Continuities\",\"Auto\",\"Sleep\"]}",
"name": "\u5de5\u4f5c\u6a21\u5f0f",
"type": "Enum",
"values": "{\"range\":[\"Continuities\",\"Auto\",\"Sleep\"]}"
"code": "anion",
"desc": "{}",
"name": "\u51c0\u5316",
"type": "Boolean",
"values": "{}"
"code": "child_lock",
"desc": "{}",
"name": "\u7ae5\u9501",
"type": "Boolean",
"values": "{}"
"code": "countdown_set",
"desc": "{\"range\":[\"cancel\",\"1h\",\"2h\",\"3h\",\"4h\",\"5h\",\"6h\",\"7h\",\"8h\",\"9h\",\"10h\",\"11h\",\"12h\",\"13h\",\"14h\",\"15h\",\"16h\",\"17h\",\"18h\",\"19h\",\"20h\",\"21h\",\"22h\",\"23h\",\"24h\"]}",
"name": "\u5012\u8ba1\u65f6",
"type": "Enum",
"values": "{\"range\":[\"cancel\",\"1h\",\"2h\",\"3h\",\"4h\",\"5h\",\"6h\",\"7h\",\"8h\",\"9h\",\"10h\",\"11h\",\"12h\",\"13h\",\"14h\",\"15h\",\"16h\",\"17h\",\"18h\",\"19h\",\"20h\",\"21h\",\"22h\",\"23h\",\"24h\"]}"
"code": "filter_reset",
"desc": "{}",
"name": "\u6ee4\u82af\u590d\u4f4d",
"type": "Boolean",
"values": "{}"
"code": "temp_unit_convert",
"desc": "{\"range\":[\"c\",\"f\"]}",
"name": "\u6e29\u6807\u5207\u6362",
"type": "Enum",
"values": "{\"range\":[\"c\",\"f\"]}"
"code": "runtime_total_reset",
"desc": "{}",
"name": "\u91cd\u7f6e\uff08\u5de5\u4f5c\u65f6\u95f4\uff09",
"type": "Boolean",
"values": "{}"
"status": [
"code": "switch",
"type": "Boolean",
"values": "{}"
"type": "Integer",
"type": "Enum",
"code": "mode",
"type": "Enum",
"code": "humidity_indoor",
"name": "\u5ba4\u5185\u6e7f\u5ea6",
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":20,\"max\":90,\"scale\":0,\"step\":1}"
"code": "temp_indoor",
"name": "\u5ba4\u5185\u6e29\u5ea6",
"type": "Integer",
"values": "{\"unit\":\"\u2103\",\"min\":5,\"max\":38,\"scale\":0,\"step\":1}"
"code": "anion",
"type": "Boolean",
"values": "{}"
"type": "Boolean",
"values": "{}"
"type": "Enum",
"code": "fault",
"name": "\u6545\u969c\u544a\u8b66",
"type": "Bitmap",
"values": "{\"label\":[\"FULL\",\"Cleaning\",\"E1\",\"CL\",\"CH\",\"LO\",\"COIL\",\"MOTOR\"],\"maxlen\":8}"
"type": "Boolean",
"values": "{}"
"code": "filter_life",
"name": "\u6ee4\u7f51\u5bff\u547d",
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":1}"
"type": "Enum",
"type": "Boolean",
"values": "{}"
"code": "client_id",
"name": "\u5ba2\u6237\u673a\u578b",
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":0,\"max\":99,\"scale\":0,\"step\":1}"
"code": "type_of_equipment",
"name": "\u8bbe\u5907\u7c7b\u578b",
"type": "Integer",
"success": true,
"t": 1757073198813,
"tid": "ea0feb8b8a4e11f0a25e9ed280a40f39"
Status of device: bffb66aeb14b86a49edqst
"result": [
"code": "switch",
"value": true
"value": 55
"value": "low"
"code": "mode",
"value": "Auto"
"value": 56
"value": 26
"code": "anion",
"value": false
"value": false
"value": "cancel"
"code": "fault",
"value": 0
"value": false
"value": 0
"value": "c"
"value": false
"value": 0
"value": 0
"success": true,
"t": 1757073199100,
"tid": "ea2bb0cf8a4e11f0a25e9ed280a40f39"
Properties of device: bfb09e9ebfb177ae70wvta
"result": {
"category": "dd",
"functions": [
"code": "switch_led",
"desc": "{}",
"type": "Boolean",
"values": "{}"
"code": "work_mode",
"desc": "{\"range\":[\"color\",\"dynamic_mod\",\"scene_mod\",\"music\"]}",
"name": "\u6a21\u5f0f",
"type": "Enum",
"values": "{\"range\":[\"color\",\"dynamic_mod\",\"scene_mod\",\"music\"]}"
"code": "colour_data",
"desc": "{\"maxlen\":255}",
"name": "\u5f69\u5149",
"type": "String",
"values": "{\"maxlen\":255}"
"code": "music",
"name": "\u97f3\u4e50\u6a21\u5f0f",
"type": "String",
"code": "RGB_order",
"desc": "{\"unit\":\"\",\"min\":1,\"max\":6,\"scale\":1,\"step\":1}",
"name": "\u7ebf\u5e8f\u8c03\u6574",
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":1,\"max\":6,\"scale\":1,\"step\":1}"
"code": "LED_QTY",
"desc": "{\"unit\":\"\",\"min\":10,\"max\":200,\"scale\":1,\"step\":1}",
"name": "\u706f\u5e26\u70b9\u6570",
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":10,\"max\":200,\"scale\":1,\"step\":1}"
"code": "dynamic_mod",
"name": "\u706f\u5e26\u6a21\u5f0f",
"type": "String",
"code": "scene_mod",
"desc": "{\"range\":[\"CJ_YD\",\"CJ_QC\",\"CJ_WA\",\"CJ_XK\",\"CJ_JH\",\"CJ_YS\"]}",
"name": "\u573a\u666f\u6a21\u5f0f",
"type": "Enum",
"values": "{\"range\":[\"CJ_YD\",\"CJ_QC\",\"CJ_WA\",\"CJ_XK\",\"CJ_JH\",\"CJ_YS\"]}"
"status": [
"type": "Boolean",
"values": "{}"
"type": "Enum",
"type": "String",
"code": "music",
"type": "String",
"type": "Integer",
"code": "LED_QTY",
"type": "Integer",
"type": "String",
"type": "Enum",
"success": true,
"t": 1757073199253,
"tid": "ea57a5aa8a4e11f0a25e9ed280a40f39"
Status of device: bfb09e9ebfb177ae70wvta
"result": [
"value": false
"value": "color"
"value": "0000000001ec"
"code": "music",
"value": ""
"value": 1
"code": "LED_QTY",
"value": 30
"value": ""
"value": "CJ_JH"
"success": true,
"t": 1757073199421,
"tid": "ea7183fd8a4e11f08e5dda57e8f5d0ed"
Xenomes
Post by Xenomes »
84dasilva wrote: Friday 05 September 2025 14:36 Request for update plugin;
Dehumidifier.
On/off switch works
Mode switch works
Please fix
Childlock switch.
Thanks in advance.
Hi 84dasilva, the device is updated in version 2.2.8
The send looks like it is working
2025-09-08 21:39:09.639  Tuya Cloud: Command send to tuya :bffb66aeb14b86a49edqst, {'commands': [{'code': 'dehumidify_set_value', 'value': '50'}]}, iot-03/devices/
84dasilva
Post by 84dasilva »
[/quote]
Hi Xeno,
Thanks for the update! :D
Poweron/off;works
Modus;works
Fan speed;works
Status;works
Sensor status temp/humid;works
Childlock;works
Ionizer on/off;works
Set dehumify value; Does not work.
It refreshes after a while to the current value so that is correct. In domoticz it shows as a selector switch. On selection nothing happens.
Could it be that its mapped to the wrong type of switch? I see a color option which doesnt seem logical.
Is there some debug manual option available so I can test the command myself? Or do checks...
Xenomes
Post by Xenomes »
84dasilva wrote: Thursday 11 September 2025 17:21 Set dehumify value; Does not work.
I see something, code of device is in steps of five the selector switch is steps of one, can you test 50,55,60 see if that works. I check the code why it skip the step size.
Schermafdruk van 2025-09-11 21-03-02.png (28.08 KiB) Viewed 65 times
Edit: The plugin is updated! remove the selection device, restart the plugin the new device will created.
Last edited by Xenomes on Thursday 11 September 2025 21:17, edited 1 time in total.
Domoticz version: 2025.1
@Xenomes: for the dehumify setting perhaps use the new setpoint device (based on thermostat) where you can configure min- ,max value, step size etc
Xenomes
Post by Xenomes »
waltervl wrote: Thursday 11 September 2025 21:16 @Xenomes: for the dehumify setting perhaps use the new setpoint device (based on thermostat) where you can configure min- ,max value, step size etc
Thanks, I didn't try that, I'll check it out.
Edit: Changed the device to the new thermostat with a water image and a humidity symbol.
