need help dzevets script solar Toon
Wiers
Post by Wiers »
I am running the latest Domoticz on a Pi.
Connected to my P1 meter via usb and working great.
Also got the readings from my Rooted Toon thermostat.
I have solar panels from APSystems.
The problem is:
P1 energy production are from the phase where my solar panels are connected, but that phase also uses power so I don't get a clean "solar production" readout.
In my toon I have a clean readout of my Apsystems.
I found out that if I use this: http://toonIp/solar.html in my browser I get:
{"result":"ok","solar": {"current":3589, "total":11401431, "today":24715, "production":4010, "usage_net":246, "usage_own":-175}}
I also made a virtual device : "solar power"
My question to you smart guy's is, can you help me whit a script that runs every minute that gets a readout of these figures from my toon that i can use for my solarpower device?
Eric
Domoticz version: 2025.1
Re: need help dzevets script solar Toon
According this topic the rooted Toon python plugin should show the P1 meter data including solar: viewtopic.php?p=311034
use this plugin: https://github.com/MadPatrick/domoticz_toon
Wiers
Post by Wiers »
Hi Walterv,
I have the thermostat data from Toon in Domoticz working.
I have the P1 data in Domoticz working.
But I need the data from my solarpower which Toon gets via an app from oepi loepi toe Domoticz.
At the moment I am trying to get a dzevents HTTP request working but getting stuck on to manny errors.
Can you give an explanation what from this json you want to use for your virtual solar panel device in Domoticz?
current is current production in W?
total is total production Wh?
production, usage_net, usage_own is what? Do these values need to be used?
Wiers
Post by Wiers »
The most important is "current"
and today would be nice.
Wiers
Post by Wiers »
this is what i am working whit but no result:
        timer = { 'every 1 minutes' },
        httpResponses = { 'solar' }
        if (item.isTimer) then
            domoticz.openURL({
            url = 'http://192.168.1.56/solar.html',
            method = 'GET',
            callback = 'solar'
        elseif (item.isHTTPResponse) then
            if (item.ok) then -- statusCode == 2xx
                local current = item.json.consumption
                domoticz.devices('production').energy(current)
Edit waltervl: added code brackets for better readability
Wiers
Post by Wiers »
and it is all in W
But what is it? You have to map it to values in the Domoticz device.
And all in W is strange....
Can you post a screenshot of your Toon user interface where it shows the Solar data?
Wiers
Post by Wiers »
Scherm­afbeelding 2025-05-28 om 16.41.26.png (176.86 KiB) Viewed 1576 times
Wiers
Post by Wiers »
So what are the json values from? Seems to be the one with 811W
Those values cannot be put as is in a Domoticz device. That is a function of the Energy dashboard.
Also the second screenshot seems strange for me.
Solar now 2315 W
Total 15.0 Kwh (so not all values are W ;) )
But what is:
Delivered 4514 W
Usage 323 W
I cannot map these values to solar panels. What do they mean?
Wiers
Post by Wiers »
"Stroom nu" is the same as "zon nu" and is the "current" value in the json.
They are different because there are clouds passing by.
this is the actual solar production of my panels in W.
the other values are not important.
I just want this number refreshed in a virtual counter if possible.
Then change line
Into
local current = item.json.solar.current
domoticz.log(' current = ' .. current, domoticz.LOG_INFO )
Also name the device correctly. You write you created a device called "solar power" but in your script you send data to device called 'production'......
Report back the errors and the complete script if it does not work.
It could be that line
Should be
local current = item.json.solar[0].current
Wiers
Post by Wiers »
thanks for the info,
I will try this tomorrow.
I tried different devices and names to get a reaction but i will change them to one name.
Wiers
Post by Wiers »
One step further and without error but unfortunately without data.
I now have this script called "SolarPanels"
domoticz.openURL({
method = 'GET',
callback = 'solar'
It runs without errors but I also think without data.
Scherm­afbeelding 2025-05-29 om 10.55.20.png (38.87 KiB) Viewed 1506 times
And what kind of device do I have to make to receive the data?
I now have this.
Scherm­afbeelding 2025-05-29 om 11.05.48.png (77.97 KiB) Viewed 1506 times
Wiers
Post by Wiers »
Scherm­afbeelding 2025-05-29 om 13.52.43.png (29.22 KiB) Viewed 1482 times
Progress, I got a value "current = 676" which was the output of my panels at that moment.
Now I have to get that in a device/counter.
What do you expect to see? Because you now selected a counter that needs the total kWh data field and not the usage data in Watt.
You can also create an Electric (instant and Counter) device. That needs 2 values. The current in W and the total counter in Wh. (But what is the correct values from the JSON, value total?)
You can also create a Electric Usage device that only needs the Watt values. No historical report on this device.
Be aware every type of device needs a specific update command. See the dzvents wiki.
Wiers
Post by Wiers »
If I have only a Electric usage device which shows me the actual Watt that would be fine.
But I do not know how toe send the value of "current" to that device.
It is time you start better reading the dzvents wiki, it is all there: https://wiki.domoticz.com/DzVents:_next ... _scripting
Use
domoticz.devices('your_device_name').updateEnergy(current)
Wiers
Post by Wiers »
I am reading in the wiki but as a non programmer it is a lot "Chinese" for me.
It is easy to make a mistake by typing one digit wrong.
You are steering me in the right direction and together with the wiki and internet I think I will figure it out.
