[2025.1] after update CPU temp increased from 50 to 70°C
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
PSUtec
- Domoticz version: 12896
Thank you for the this stable version; however, since upgrading the temperature of the CPU (RPI4) has increased from usually around 50°C to more than 70°C, even after system upgrade and reboot.
Any idea of the possible reason?
Thanks,
Thanks,
- Domoticz version: 2025.1
Re: [2025.1] after update CPU temp increased from 50 to 70°C
Did your CPU load also increased? Else it could just be your environment also increased in temperature...
PSUtec
Thanks for your reply.
I don't monitor the CPU load, so I don't know if it did increase.
Currently it is around 60%.
It cannot be due to the environment temperature, as it increased suddenly as shown in the atteched figure.
Such a temprature increase would mean my house burning, which is not the case!
- CPU temp.jpg (48.72 KiB) Viewed 1426 times
- user4563
- Domoticz version: 2025.2
Did you do a top/htop to see what is loading your CPU?
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
You can switch on the Domoticz Motherboard sensors so you can monitor your system from Domoticz. It includes CPU usage.
https://wiki.domoticz.com/Motherboard_sensors
Normally CPU temp is directly related to CPU usage. But when you block the airflow around the system it will also affect the temperature.
I do not see any increase on my CPU load due to 2025.1 but I do not have an RPi....
Rik60
I see no temp changes after the updates. I did the update from 2024.7 stable to 2025.1 beta to 2025.1 stable. Did not see any changes, temperature is about 53. Updated without any erros, problems. Running Domoticz on a Pi3B bookworm.
PSUtec
Thanks! It allowed me to identify the application that dramatically increase the CPU load and therefore its temperature.
- gizmocuz
Great! Was it Domoticz or another application?
PSUtec
No, it is meross2domoticz, a PM2 application.
Looking at that application it will probably not work anymore as it has deprecated Domoticz API calls in the js file
https://github.com/mangoose002/Meross2D ... omoticz.js
See the Domoticz wiki how to solve it: https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
PSUtec
Indeed!
I've made the correction in the .js file and now it works fine!
Thanks again to all the guys how helped me.
Users browsing this forum: Bimnomercy and 1 guest
