Dear all
After use a command PT2262 switch on/off my RFXcom seems pass in update firmware mode with red light.
Therefore the RFXCOM stop to work and the command send by the switch PT2262 is not take into account.
before the update all working well.
I need to disconect and reconnect physically RFXcom to recover it.
Some other one have the same issue ?
RFXcom firmware version 1051
Domotic version Version: 2025.1 (build 16675)
Thanks for your feedback
Edit waltervl: Moved to the correct subforum (RFXCOM)
RFXCOM down with red light
- Domoticz version: 2025.1
Re: RFXCOM down with red light
Perhaps better to contact RFXCOM?
Is it related to Domoticz 2025.1? Did it work in Domoticz 2024.7?
See also viewtopic.php?t=15441
nico21311
RFXCOM work well on the previews domoticz version with the same firmware on the RFXCOM.
nico21311
additional information
after deeper test, the pt2262 work alone.
I would like to have the possibility to modify the icon however this protocle do not allow it.
therefore I created a dummy switch and I add as a slave the pt2262.
and with this configuration the RFXCOM down always.
- pt2262.jpg (40.43 KiB) Viewed 1996 times
- exemple.jpg (61.14 KiB) Viewed 1996 times
nico21311
Dear
Is it possible to add the icone for the protocle pt2262 ?
- gizmocuz
Yes, you are causing an endless loop!
I am unable to read your screenshots, but it is a normal on/off switch?
Could you show a screenshot of the device overview where I can see the type/subtype of the switch? (Or please write it here)
Maybe best to open a Github issue for this, please mention a link to this forum post
