[2025.1] No graph data after update Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
geezer
Post by geezer »
I updated also today (via GUI). Worked fine at first (from windows laptop with Chrome). However via macbook with Safari the graphs do not show: Logs of all devices show "no data available" but data in reports is still available. I restored the database, but issue remains.
New feature was I think that you now can zoom in logs. Might this has broken something (invalid zoomrange or something?)
PS: updated also to the latest patches of Bookworm on the Raspberry Pi 5.
Schermafbeelding 2025-05-05 om 23.48.19.png (267.39 KiB) Viewed 3137 times
Schermafbeelding 2025-05-05 om 23.47.11.png (203.5 KiB) Viewed 3137 times
Domoticz version: 2025.1
Re: [2025.1] No graph data after update
This seems to be a browser/cache issue.
Please delete the browser cache and /or try to connect to Domoticz with an private/incognito browser session.
geezer
Post by geezer »
In Chrome clearing the cache works and data is then visible again. In Safari I also cleared the cache, but this did not solve the issue.
geezer
Post by geezer »
geezer wrote: Tuesday 06 May 2025 0:26 Om my Macbook via Chrome and after clearing the cache it works and data is then visible again. In Safari I also cleared the cache, but this did not solve the issue. Switching to "incognito" also does not solve the issue.
On Safari via my iPhone it just works fine.
gizmocuz
Post by gizmocuz »
There should be no reason to clear the browsers cache, unless you are updating from a version from more than 2 years ago.
As it is working on your mobile's safari, is your desktop safari up-2-date? Is your system up-2-date?
Could you open the browsers development console and see if there are any errors reported in the console?
geezer
Post by geezer »
Thx for your reply.
I have a rather outdated Macbook from 2013 that I need to definitely upgrade (I had other priorities...). Safari V18 is not supported on my laptop. Apparenly the Domoticz 2025.1 version uses functionality that Safari V16.6.1 does not support.
geezer
Post by geezer »
Safari console reports this error: "date value is not finite in DateTimeFormat format()"
I chekced on Stackoverflow and found this information:
https://stackoverflow.com/questions/639 ... t-format-w
The error was probably caused caused by having milliseconds attached to the end of dates being used, which apparently is not being correctly handled by this older version of Safari.
TimRob69
Post by TimRob69 »
I have also the same problem, on a MacBook late 2013.
No graph shown in safari. In chrome works it fine.
