Netatmo authentication changes Oct 2022
jpcasta
Re: Netatmo authentication changes Oct 2022
Post by jpcasta »
I updated Domoticz to 2025.1 beta 16657 and it works again for me!!
pipiche
Post by pipiche »
Not working for me viewtopic.php?t=43457
and no idea on how to troubleshoot and understand the error message
Piacco
Post by Piacco »
I've updated to Version: 2025.1
Netamo works well, but after a several days domoticz is crashing.
What could be the cause of this, or better how can I solve this issue :D
Thread 40 (Thread 0x60fe9200 (LWP 20719) "Netatmo Weersta"):
#0 0x7691f034 in __GI___wait4 (pid=25931, stat_loc=0x60fe7bb8, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#1 0x0076a13a in dumpstack_gdb(bool) ()
#2 0x0076a590 in signal_handler(int, siginfo_t*, void*) ()
#3 <signal handler called>
#4 raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#5 <signal handler called>
#6 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#7 0x76893364 in __GI_abort () at abort.c:79
#8 0x00c22060 in __gnu_cxx::__verbose_terminate_handler() ()
#9 0x00bc81e0 in __cxxabiv1::__terminate(void (*)()) ()
#10 0x00bc8236 in std::terminate() ()
#11 0x00bc815c in __cxa_throw ()
#12 0x00af1bac in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#13 0x00af3282 in Json::Value::asString[abi:cxx11]() const ()
#14 0x00963824 in CNetatmo::RefreshToken(bool) ()
#15 0x00971640 in CNetatmo::Do_Work() ()
#16 0x00c1dd42 in execute_native_thread_routine ()
#17 0x76a96310 in start_thread (arg=0x60fe9200) at pthread_create.c:477
#18 0x76957da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
There is a error in the json::throwLogicError, this needs some investigation.
homeJLB
Post by homeJLB »
On my system and on my test system it is still running.
I recommend to un-comment the line
Debug(DEBUG_HARDWARE, "Response sResult %s", sResult.c_str());
and to start with option debug Hardware on to see what is happening wit your setup.
DomoFlits
Domoticz version: Bld16583
Post by DomoFlits »
I've just received this email from Netatmo:
Netatmo API - API Domain Name Change
Dear Netatmo developer,
We hope this message finds you well.
We are writing to inform you of an upcoming change to our API domain configuration. As part of our ongoing efforts to streamline and improve our services, we will be retiring the domain api.netatmo.net and consolidating all API traffic under the existing domain api.netatmo.com.
Effective Date:September 8, 2025
To ensure uninterrupted service, we kindly ask you to update your applications to use api.netatmo.com exclusively before the above date. The structure and functionality of the API remain unchanged — only the domain name is affected.
Sincerely,
Legrand - Netatmo - Bticino
Can anyone comment on whether this will stop the Netatmo devices from working?
homeJLB
Post by homeJLB »
We use
#define NETATMO_API_URI "https://api.netatmo.com/"
So this change in September should not effect the Plugin.
Kind regards
DomoFlits
Post by DomoFlits »
Thanks for the confirmation
dgilbert2
Post by dgilbert2 »
I finally updated to 2025.1 and the Netatmo side is all working, thank you.
One thing I have noticed is that the air pressure resolution for the weather station appears to have changed to 1 hPa where as it was 0.1hPA before the update? This results in quite 'blocky' graphs now.
homeJLB
Post by homeJLB »
Do you mean the Barometer?
This is my log for last year;
Barometer 1.png (179.12 KiB) Viewed 309 times
only on daily it is more blocky
Barometer 2.png (83.2 KiB) Viewed 309 times
Is this a problem for you?
dgilbert2
Post by dgilbert2 »
Yes, barometer. No, its not a problem, just an observation. Here is my daily chart and you can tell when I updated to the 2025.1 after around 9am
Screenshot 2025-08-31 202339.png (55 KiB) Viewed 308 times
MartinAndersson
Post by MartinAndersson »
dgilbert2 wrote: Sunday 31 August 2025 21:29 Yes, barometer. No, its not a problem, just an observation. Here is my daily chart and you can tell when I updated to the 2025.1 after around 9am
Is it the resolution or just slower updates? My netatmo these days only update every 15 minutes, whereas before I think it was every 5 minutes.
