Pushing multiple values to Virtual sensor
beic
Domoticz version: 2004.6
Post by beic »
Hi there,
Is there a way to push more than 3 values to the Virtual Sensor "Dummy (Does nothing, use for virtual switches only)"?
Currently I'm trying to use "Dummy (Does nothing, use for virtual switches only)" for Temperature, Humidity and Pressure and 2 additional "Dummy (Does nothing, use for virtual switches only)" for Humidex and THI separately.
But, I would like to push those 5 values in a single query Temperature, Humidity, Pressure, Humidex and THI, not in 3 separated queries.
Is that possible to do somehow?
Thank you for your answer,
Kind regards,
Viktor
Domoticz version: 2025.1
Re: Pushing multiple values to Virtual sensor
For a temp/Hum/bar you have to send the following parameters in one API call
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEMP;HUM;HUM_STAT;BAR;BAR_FOR
TEMP = Temperature
HUM = Humidity
HUM_STAT = Humidity status
BAR = Barometric pressure
BAR_FOR = Barometer forecast
See for more info the API wiki page https://wiki.domoticz.com/Domoticz_API/ ... /barometer
I do not know what Humidex or THI is but the above mentioned parameters is all you can do. Also be aware you have to supply all values in one call to have the device display the correct values.
beic
Post by beic »
Thank you, yes, I know that, currently I'm using in that way.
I thought that there might be a Virtual Sensor type that you could add "multiple sub sensors" of any type.
No, there is not such a sensor in Domoticz.
beic
Post by beic »
It would be really nice to have that kind of sensor type.
HvdW
Domoticz version: 2023.2
Post by HvdW »
You can put whatever you want in a (dummy) text sensor.
Bugs bug me.
beic
Post by beic »
Nice one!
Could you please give me an example how could I put 5 different measurement into a single "url" text based Dummy sensor?
And how could I add them into 5 separated Chart?
Thank you! 8-)
