Is it possible to add Shelly 2PM GEN 3 to Domoticz?
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
According to this manual it is not possible to add: https://www.youtube.com/watch?v=3PvYhFIsVN4
Does anyone know a way?
Or can someone suggest how to control the blinds using another controller so that it would control %% blinds in domoticz
FireWizard
Re: Is it possible to add Shelly 2.5 GEN 3 to Domoticz?
Post by FireWizard »
Hi @Daro1003,
Of course.
Shelly (any device) ==> MQTT ==> Node-Red ==> MQTT ==> Domoticz (or Node-Red ==> Http ==> Domoticz).
Daro1003
Post by Daro1003 »
Can you help build flows from shelly to NodeRed and to domoticz?
FireWizard
Sure, we can try.
Have you NR installed and working?
And the Mosquitto MQTT server?
If you can test the flow, I think I can build one
Daro1003
Post by Daro1003 »
NodeRed installed and working.
Mosquitto MQTT server is also working.
NodeRed to Domoticz flows from you are also working.
FireWizard
Hi @Daro1003,
Are you sure your product is a Shelly 2.5 Gen 3 and not a Shelly 2 Gen 3, as I cannot find the product in the Shelly list?
Daro1003
Post by Daro1003 »
You are right this product is shelly 2PM GEN 3.
I've already changed the description because I misspelled the designation.
FireWizard
Re: Is it possible to add Shelly 2PM GEN 3 to Domoticz?
Ok Nice,
I will come back with a first flow, probably tomorrow.
Daro1003
Post by Daro1003 »
great, I'm waiting.
I installed additional nodes related to shelly but GEN 3 is missing.
Is it possible to control the roller blinds by percentage in Domoticz?
FireWizard
Hi @Daro1003,
You can use these nodes and Gen 3 exists as well.
What do you think of shelly gen 2+?
These nodes can be used or the default MQTT nodes.
What do you prefer?
I think so. It is specific for roller blinds?
Daro1003
Post by Daro1003 »
Where can I find a shelly GEN 3 node?
I don't have a shelly GEN 2, I bought a newer shelly GEN 3 model because I read online that the GEN 2 models also have a similar problem with temperature as the shelly 2.5.
I currently use percentage control of the blinds with the shelly 2.5 controller because the blinds are set at different times of the day in different positions.
FireWizard
Hello @Daro1003,
I did not say Gen 2, but I said Gen 2+.
This node is used for everything higher or equal than Gen 2.
Gen 3 and Gen 4 use the same protocol as Gen 2 and so the same node is used
FireWizard
Hello @Daro1003,
Currently I'm looking to a possible Node RED flow for your Shelly 2PM gen 3 device.
As I do not have such a device and you should maintain a possible flow in the future, you have to make a decision on how we make it.
1. As you said, that you want to control blinds, you need to use the device in "Cover" mode.
2. Do you want to use the default MQTT node or do you prefer one of the Node-RED contrib node.
If you prefer the contrib node can you configure shelly gen 2+ node and try, if you get a connection.
Double click on the node and insert the hostname or IP address of the Shelly device and select the correct Device Type.
Connect Insert node to the input and a Debug node to the output.
Check, that the Shelly node shows connected and check the debug node, if you push the Inject node.
If you prefer the default MQTT node, I like to know your MQTT configuration of the Shelly device (without credentials)
What type of switches you want to use in Domotiocz (Selector switch? Dimmer?)
And what type of sensor you like to show?
FireWizard
Hello @daro1003,
I see, that you have installed several Shelly nodes.
If you decide not to use MQTT but the contrib Shelly node (https://flows.nodered.org/node/node-red-contrib-shelly), you can leave this node in your palette.
You have also installed https://flows.nodered.org/node/@zebraja ... shelly-3em.
I recommend to remove this one, as it may cause a conflict with the other one and the other one also supports the Shelly 3EM and you do not need support for it now.
You have also installed https://flows.nodered.org/node/node-red ... helly-mqtt. Also that one is not needed.
If you decide to go for MQTT, then we can use the default MQTT nodes. So remove it.
Also another Shelly Pro 3EM node has been installed. Remove that one as well. It is not needed, may cause conflicts and is already supported by the first one.
I looked a little bit to your device and its possibilities.
I found an example, which support the first set of nodes.
See:
https://raw.githubusercontent.com/windk ... rplus.json
Can you import this one and test with your device?
I like to know if this example works.
Daro1003
Post by Daro1003 »
I have removed the nodes you indicated.
Which ones should I remove? The ones in the image remain.
How can I import this https://raw.githubusercontent.com/windk ... rplus.json
import it? How do I do that??
Zrzut ekranu 2025-04-01 202458.png (7.67 KiB) Viewed 4221 times
Daro1003
Post by Daro1003 »
With the settings as in the attached image I managed to get a connection with my shelly.
As for the type of connection I have no idea which one to choose I rely on you.
Zrzut ekranu 2025-04-01 202400.png (47.13 KiB) Viewed 4222 times
ustawienie ok1.png (70.67 KiB) Viewed 4224 times
Zrzut ekranu 2025-04-01 201710.png (10.63 KiB) Viewed 4224 times
FireWizard
Good evening @Daro1003,
Nice, that means everything is online.
Okay then we go for this node, configured as Shelly 2PM GEN3 (Relay S3SW-002P16EU), as we know that this node works.
That is okay.
1, Go to the link as indicated
2. Select everything (CTRL A).
3. Copy (CTRL C or right mouse button and "Copy") and the code is saved to the clipboard.
4. Go to the "Hamburger" menu in Node-RED and select "Import".
5. The window "Import nodes" will open.
6. Paste the contents of the clipboard (CTRL V or right mouse button and "Paste") and Import the flow.
Test it, if this works for you.
And
Can you also answer these questions?
kimot
Domoticz version: v3.8153
Post by kimot »
I think, this Shelly suports scripting.
So why all this mqtt and node red?
Switching on and off works by direct call from Domoticz like all older ones.
And Shelly can send measured values ​​directly to Domoticz using a script running on it.
For example here is a part of my code for sending amount of energy in the last minute on my PlusPlugS.
Shelly.addStatusHandler(function (event, user_data) {
  print(JSON.stringify(event));
   if (typeof event.delta.aenergy !== "undefined") {
    if (startMonitor) {
      print(eAccumulator_prev);
      minute_energy = event.delta.aenergy.by_minute[0];
      eAccumulator = event.delta.aenergy.total;
      // power = event.delta.apower;
      total = event.energy
      power = event.apower;
      print(eAccumulator);
      eDiff = eAccumulator - eAccumulator_prev;
      print(eDiff);
      print(minute_energy);
      minute_energy = Math.round(minute_energy);
       url = "http://192.168.1.2:8080/json.htm?type=command&param=udevice&idx=152&nvalue=0&svalue="+minute_energy;
      print(url);
      Shelly.call(
  "HTTP.GET", {
    "url": url,
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
FireWizard
Hell #kimot,
You wrote:
I think, this Shelly supports scripting.
You are right. All Gen 2, Gen 3 and Gen 4 support scripting.
Shelly offers even a training course to learn the script language.
See: https://shelly.guide/scripting/ and https://github.com/ShellyUSA/Scripts
Course: https://shelly.academy/trainings/13/she ... pring-2025
At the end it is all to the user to decide, which route he/she wish to follow in order to reach his/her goal
This user has already a MQTT broker and also Node-RED up and running.
I supported him in another project in the past with MQTT and Node-RED.
If you have it up and running and you are familiar with it, it is probably easier than scripting.
It is just JSON and that is also a scripting language.and the same as your script.
Thank you, although I probably will not use it, but others may benefit from it.
Daro1003
Post by Daro1003 »
Hello colleagues.
Due to work, I have little time to work at home, but we continue working.
I managed to import the code from the link and I got a working flow. If I click on open or close in NodeRed, it clicks the relay in shelly. So communication with NodeRed works with shelly. Now we need to pass it to Domoticz.
In Domoticz, I would like a switch type with a slider and a precent indicator as in the picture. I also use this type in Dashticz. It controls the blinds using the blinds setting in a given position thanks to the switch with %
czujnik i Domoticz.png (42.91 KiB) Viewed 3433 times
Zrzut ekranu 2025-04-07 073515.png (82.2 KiB) Viewed 3433 times
