Daikin Cloud Controller - BRP069C4
dorenberg
Domoticz version: 4.10982
Re: Daikin Cloud Controller - BRP069C4
Post by dorenberg »
So I guess we have to wait a bit. I have no clue how to fix it.
pat44
Post by pat44 »
I read all this post, and thanks for this good work based on nore-red. That's very impressive.
However, does anyone have a similar solution compliant with the new offical API here using OIDC auth ? https://developer.cloud.daikineurope.com
or any other solution (python ....) able to interface domoticz with this new daikin API. Thanks.
Domoticz version: 2026.3
In this discussion Daikin AC is also discussed: viewtopic.php?t=21126&start=80
pat44
Post by pat44 »
Thanks @waltervl for your quick answer.
So today, there is no straigthforward solution. :(
hetisweergezellig
Post by hetisweergezellig »
Hi All,
I had the same problem you are facing and I am now working in a concept that can integrate the Daikin Cloud API on any platform.
I am using NodeRed to call the Daikin API.
Next step is to publish the retreived values from daiking on MQTT so any platform can ingest from there.
It is not finished yet but here are the steps of this concept.
1. Create an account in the developer portal of Daikin.
2. Create an app.
3. Use Postman to make the first connection using OpenID. The return URI used is https://oauth.pstmn.io/v1/callback (select the option Authorize using browser.
Once this is done you can get the first acces token and refrersh token.
From here you can use "normal" https calls to refresh the access token. I created a sqlite database where I store the Access token and refresh token. This access token I can use in NodeRed the call the api functions of the daikin api. When the access token is expired I can call
POST https://idp.onecta.daikineurope.com/v1/oidc/token?
grant_type=refresh_token
&client_id=[YOUR_CLIENT_ID]
&client_secret=[YOUR_CLIENT_SECRET]
&refresh_token=[YOUR_REFRESH_TOKEN]
In nodeRed I can build this URL using the client_id and client_secret of the created application and the refresh_token I stored into my database.
The response is a new access token that can be used to make new calls to the api. And so on.
So this is not a shippable solution but I have the concept working. When I am finished with my project I can try to upload that here.
pat44
Post by pat44 »
Thanks hetisweergezellig,
Your strategy is promising. Yes I'm very interesting in your solution as I already have MQTT devices working in my side!
INendels
Domoticz version: 2025.1
Post by INendels »
I am also very interesting in this solution.
I have a working MQTT and NodeRed and also an account in the developer portal of Daikin.
i tried different solutions but with no luck to connect to my Daikin Airco yet.
gizmocuz
Post by gizmocuz »
Probably a strange question...
I used to own Daikin airco's myself... And have build native support for it in Domoticz
Does this not work anymore?
INendels
Post by INendels »
The daikin lan interface in domoticz is for local control, my airco is now 1 year old, but can not be controlled localy.
Only through the cloud api. But i have not found a working one for domoticz or node-red
Syndomo
Post by Syndomo »
@Gizmocuz: on recent units there is no LAN interface anymore... so your native support can't control them.
Daikin has opened a cloud developer portal, but there are severe limitations on the number of calls per hour/day or so. So severe that it's simply unusable for me. They don't even differentiate the limit in function of the number of units you have (8 in my case). I also understand that the functionality is rather limited (for the time being ?).
One of my 8 units doesn't have a LAN interface, so I installed a Faikin module. Works better than the original LAN...
Raspberry Pi 4 4GB - Bookworm - Domoticz v2026.3
INendels
Post by INendels »
Do you have a link for this module, so i can see if i can use it in my daikin airco
INendels
Post by INendels »
Found it, it is open source esp32 module. This can be connected to a daikin s21, x50 or s403 connector.
At first i thought it was a typo because the f is next to the d.
But it is a real faikin module :)
Ordered it from amazon, so i can test it, can coexist with the original wifi module.
INendels
Post by INendels »
Installed the Faikin Module, and connected to my WiFi network.
in Domoticz added hardware "Daikin Airconditioning with LAN (HTTP) interface" and it worked directly.
no more cloud connection for me, local connection is the best.
mgugu
Post by mgugu »
Is Onecta still working after installing Faikin in coexistence with original controller ?
INendels
Post by INendels »
Onecta was stil working, the original wifi module is still connected.
But i do not want to send all the data to the cloud, so i disabled the internet connection for this wifi module in my router.
Then onecta does not work anymore, but i do not need that, when domoticz has a local connection.
BurningTyre
Domoticz version: 2026.4
Post by BurningTyre »
INendels wrote: Tuesday 15 July 2025 19:42 Installed the Faikin Module, and connected to my WiFi network.
In installed the Faikout/Faikin module. Connected it also to my WiFi network. The faikout is working if i control the Daikin from the webpage.
I also added hardware "Daikin Airconditioning with LAN (HTTP) interface" and can see in the Domoticz log: "Status: Faikout Airco Woonkamer: Worker started"
I also enabled adding new hardware. But no new devices are created. Do i need to create them by hand?
epierre
Post by epierre »
a promising interface to daikin cloud in python:
https://github.com/divenal/python-onecta
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Barry
Post by Barry »
[Daikin Onecta ↔️ Domoticz bridge — cloud API, no hardware mods]
Once I had a couple of Daikin airco units installed in my home, I was looking for a way to integrate them into my Domoticz setup. Reading this forum, I discovered that might not be so easy. With brand new devices under warranty, I did not want to physically modify anything, and installing a Faikin module was not something I was interested in either.
So I decided to try vibe-coding a bridge between Domoticz and the Daikin Onecta cloud API. I fed the Daikin API documentation to an AI model (GLM 5.3 Flash), and after a couple of weeks of iteration I have been successful: currently all 6 of my Daikin units are integrated in Domoticz — fully readable and controllable, all through the native Onecta cloud API and with zero hardware modifications.
What you get per unit:
• Switch On/Off
• Set temperature setpoint
• Change mode (Auto/Heat/Cool/Dry/Fan)
• Change fan speed (Auto/Quiet/1–5)
• Read current temperature
• Read electricity consumption
It runs as a simple Python script (stdlib only, no dependencies) on any host that can reach both Domoticz and the internet, polls at a safe interval within Daikin's 200 API calls/day limit, and handles token rotation automatically. Setup requires creating a free app in the Daikin developer portal (about 5 minutes, step-by-step in the README).
Since it has been running smoothly in my home for weeks, I figured others might benefit from it as well. So here it is: http://github.com/VarletNL/daikin-onect ... icz-bridge (warning: vibe-coded with GLM 5.3 Flash — but rock-solid in production here 😉)
