Netatmo authentication changes Oct 2022
DomoFlits
Domoticz version: Bld16583
Re: Netatmo authentication changes Oct 2022
Post by DomoFlits »
Yes, also tried with newly created app at dev.netatmo.com.
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
Thuis wrote: Friday 21 March 2025 11:11 I do not need saved credentials in my browser, as i am on my local lan network.
Thank you for the explanation of the network settings, but all the ip's are in the known network settings.
This morning i installed latest beta and i get another warning, the 403 is gone now it is this:
Error: Netatmo Thuis: No access granted, forcing login again (Refresh tokens): invalid_grant
I also did a reset on the netatmo site as well before login with domoticz and grant access.
At least there is a change ...
Invalid Grand
I believe this is when you have selected the wrong scope or provided incorrect credentials
homeJLB
Post by homeJLB »
DomoFlits wrote: Friday 21 March 2025 17:12 I've just upgraded to 16583 also after reading the latest 2 messages.
re-enabled the Netatmo hardware
used the login button to login at Netamo and approved access to the weatherstation and was send back to domoticz again.
unfortunately "computer says no"
2025-03-21 17:01:33.069 Status: Netatmo2: Worker started...
2025-03-21 17:01:38.069 Status: Netatmo2: Use refresh token from database...
2025-03-21 17:01:38.069 Status: Netatmo2: Requesting refreshed tokens
2025-03-21 17:01:38.220 Error: Netatmo2: Invalid/no data received (refresh tokens)... HTTP/2 403
when you have this message you must stop the request to Netatmo for minimum 20 minutes
jpaul
Post by jpaul »
My feeling is that Netatmo has banned some Apps without any communication.
For example, since mid-March 2025, I'm not able to renew the token (invalid grant) on my current Apps used by the stable domoticz 2024.7 version, no matter of the client used (domoticz or a php one: https://github.com/Phil353556/netatmo-manage-tokens.git ).
If I create a new Netatmo App, token renewal works with the php client and the dev Domoticz version (or not, depending on the moon phase).
Has anyone contacted Netatmo to report this issue ? I used this form: https://dev.netatmo.com/contact-us-form paragraph "I need support with the Netatmo API", waiting for an answer ...
DomoFlits
Post by DomoFlits »
homeJLB wrote: Friday 21 March 2025 20:06
I have the hardware disabled continuesly to prevent my logfile filling up with Netatmo errors.
I only enable it for testing possible solutions mentioned in this topic.
homeJLB
Post by homeJLB »
jpaul wrote: Friday 21 March 2025 22:11 Hi,
When Netatmo permanently block a App without communication, we can try so much but always fail. :?
As I read this thread correctly there are users with a New App on dev.netatmo.com but they still have issues.
Not sure what happens there.
Thuis
Post by Thuis »
It just does not work, what ever i do.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
lost
Post by lost »
homeJLB wrote: Saturday 22 March 2025 9:40 When Netatmo permanently block a App without communication, we can try so much but always fail. :?
As always, only solution to avoid this kind of issue that almost always occurs (only unknown there is when?) on devices whose manufacturers do not allow 100% local control: Never buy!!!
pipiche
Post by pipiche »
no luck. Latest domoticz build on Docker, create a new app on Netatmo, still
Error: Netatmo Energy: Invalid/no data received (refresh tokens)... HTTP/2 403
will give up
jcb2
Post by jcb2 »
I have the same issue.
Last béta, reset key, new app, wait severals hours, ... but never the communication with Netatmo.
cadkey
Post by cadkey »
You can run this test to verify if the API is working.
In a browser like Chrome, type this line:
https://api.netatmo.com/api/homesdata?access_token=xyz
Make sure to replace xyz with your valid access_token (not the refresh_token), without single or double quotes.
You should receive a JSON response beginning with: {"body":{"homes":[
jcb2
Post by jcb2 »
Yes I have one result :
cadkey
Post by cadkey »
I'm not surprised. You're receiving a json file because the API is working, which I've been reporting since March 20th. The URL query bug only lasted a few hours. The problem lies elsewhere. You need to look into the connection with the third-party application (on the Netatmo side) or the Domoticz integration (on the Domoticz side). I can't help you further because I don't use Domoticz; all my home automation is managed with my own scripts, Netatmo, Philips Hue, Sonoff and more.
homeJLB
Post by homeJLB »
When I try a restart off the plugin
2025-03-23 16:06:32.920  Error: Netatmo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-23 16:06:32.923  Status: Netatmo: Login 0
2025-03-23 16:10:18.035  Status: Closing application!...
2025-03-23 16:10:18.035  Status: Stopping worker...
Then on the command line I stop the Domoticz-service
and wait 20 minutes
2025-03-23 16:30:15.640  Status: Domoticz V2025.1 (build 16651) (c)2012-2025 GizMoCuz
2025-03-23 16:30:27.548  Status: Netatmo: Status 1
I believe the authentication is functioning but something keeps in memory and blocks the request.
This needs to be found in the source code off the plugin.
Thuis
Post by Thuis »
Well i got back to beta 16490 or something, and just let it go fill my logfile with the netatmo errors. Before this I did reset the app client and secret on netatmo and i logged in with new clientid and secret and the scope. After one day i looked and it was working. Somehow? Also i see different icons on the CO2 sensors. Nice!
Then i did updatebeta and it seems to keep working, no errors. The only thing i see is firefox has a different behavior then edge and chrome. I did deleted all the history and cookie data though. Probably a firefox thing.
Wimpi
Domoticz version: 2025.1
Post by Wimpi »
upgrade to 16583 did the trick!
Netatmo works again :D
dgilbert2
Post by dgilbert2 »
Has the latest beta updated the Netatmo plugin?
Thuis
Post by Thuis »
Restarted the domoticz.service and i spoke too soon got error again:
Netatmo Thuis: Invalid/no data received (refresh tokens)... HTTP/2 403
So i now disabled the netatmo hardware and see what happends if i enable it after 2 hours or so...
Thuis
Post by Thuis »
Waited a few hours and turned the hardware back on.
So i did the login again, granted permission. Then restarted domoticz and it seems to be working again.
I just hope i do not have to do this every time i restart the computer. We'll see.
jcb2
Post by jcb2 »
One new PR is available into new beta about issue of Netatmo.
For me this is always not good. I have wait 20 minutes but always one other error : "No access granted, forcing login again (Refresh tokens): invalid_client"
I have check and check again, make a new app but nothing ...
