Cloudfare Captcha Topic is solved
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
Filip
Cloudfare Captcha
Post by Filip »
Since the installation of a new PC (a couple of months now) running Ubuntu 24.04/Linux, addressing the domoticz site (forum or wiki) results in Cloudfare asking for a Captcha "Verifying you are human by completing the action below ... forum.domoticz.com needs to review the security of your connection before proceeding".
Is there any configuration at the domoticz website that triggers this (annoying) behavior?
Any action that can be done to avoid?
(I am from Belgium - Internet provider is Orange Belgium - with Public IP address range 94.104.0.0/13)
jvdz
Domoticz version: 4.107
Re: Cloudfare Captcha
Post by jvdz »
We all get this for a while now... thanks to the folks trying to ddos the site.
FireWizard
Post by FireWizard »
It is pure coincidence that your installation of a new PC with a new Linux OS happens at about the same time that it appears to be necessary to protect the Domoticz forum site against DDOS attacks
So there is nothing that you or others can do to avoid that way of protection. Unfortunately it is needed.
B.t.w. you should not publish your IP address, as this will attract attackers.
jvdz
Post by jvdz »
FireWizard wrote: Friday 28 February 2025 18:04 B.t.w. you should not publish your IP address, as this will attract attackers.
The /13 subnet range is quite a big number of ip addresses that are covered by that. ;)
Filip
Post by Filip »
It is almost 25% of all Belgian Orange customer and publicly available on the internet...
jvdz
Post by jvdz »
adam1 wrote: Tuesday 04 March 2025 14:47 It looks like the Captcha is a necessary evil due to ongoing DDoS attacks on the Domoticz site. It’s not related to your new Ubuntu installation—just unfortunate timing.
There’s no way to bypass it permanently, but you could try using a different browser, enabling JavaScript fully, or even a VPN to see if that helps reduce how often you get the challenge ;)
So you registered on our forums just to echo what was already stated or are there other intentions here?
Domoticz version: 2025.1
I already blocked users for these kind of AI generated answers....
