dz is running in a serverrack in a container
there is also a pi also running another dz
is it possible to have the one in a container and the other one as slave?
master-slave whereas master is in container
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Re: master-slave whereas master is in container
update:
it is possible
it is possible
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2024.7
Why would you make 2 Domoticz instances in your house and connect them?
I can understand you do this for an holiday home that you remotely want to control from your own Domoticz server. But not in your own house....
This regards a somewhat big Scouting building. There's a technical space in which the master domoticz is running on a server in 19" rack.
To monitor the elecrtrical counter the slave pi is nearby the P1 meter. The meter is in a small room in which I don't like to have the 'heart' of the automation.
Bart
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Ah, you dont need Domoticz master-slave for that. You can also just forward the P1 meter data directly to the only Domoticz server with for example ser2net https://wiki.domoticz.com/SharingSerialDevices In Domoticz you use the P1 Smart Meter with LAN interface" gateway.
See also wiki https://wiki.domoticz.com/Dutch_DSMR_sm ... o_Domoticz
This will save you some extra management of a Domoticz instance as the ser2net is a very simple maintenance free implementation.
And you also can use a cheap ESP device instead of an RPi if you want to save some money. https://smart-stuff.nl/product/p1-donge ... ter-esp32/
