Latest stable Domoticz 24/7 on latest stable Ubuntu server...
"PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform."
It won't let me install earlier python versions either.
Is there any way around this or do I have to install an older version of Ubuntu server ?
Ubuntu X86 server LTS PluginSystem: Failed dynamic library load
solarboy
- Domoticz version: 2024.6
solarboy
Re: Ubuntu X86 server LTS PluginSystem: Failed dynamic library load
OK, found the solution
Even though python 3.12 was installed. Go figure.
sudo apt-get install python3.12-devIntel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
- Domoticz version: 2025.1
That is indeed a known issue for the plugin framework, it needs additional python modules as indicated on the wiki:
https://wiki.domoticz.com/Using_Python_ ... _Raspbian)
