Ubuntu X86 server LTS PluginSystem: Failed dynamic library load
solarboy
Domoticz version: 2024.6
Post by solarboy »
Latest stable Domoticz 24/7 on latest stable Ubuntu server...
"PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform."
It won't let me install earlier python versions either.
Is there any way around this or do I have to install an older version of Ubuntu server ?
solarboy
Re: Ubuntu X86 server LTS PluginSystem: Failed dynamic library load
Post by solarboy »
OK, found the solution
sudo apt-get install python3.12-dev
Even though python 3.12 was installed. Go figure.
That is indeed a known issue for the plugin framework, it needs additional python modules as indicated on the wiki:
https://wiki.domoticz.com/Using_Python_ ... _Raspbian)
