How to use the install.domoticz.com script to install not the latest version?
user4563
Domoticz version: 2026.4
Post by user4563 »
By default the script at install.domoticz.com will install the latest version. I want to use the script to install v2023.2 as I would like the transfer my v2023.2 from Windows to my Ubuntu server and stay on the same version.
Looking through the script, I see line 380 which is:
wget -O domoticz_release.tgz "http://www.domoticz.com/download.php?channel=release&type=release&system=${OS}&machine=${MACH}"
and if I change it to the following I'll d/l v2023.2:
wget -O domoticz_release.tgz "https://github.com/domoticz/domoticz/releases/download/2023.2/domoticz_linux_2023.2_x86_64.tgz"
Is anyone familiar with the script know if that's all I need to change?
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
Tukker
Domoticz version: 2023.2
Re: How to use the install.domoticz.com script to install not the latest version?
Post by Tukker »
Bugs bug me.
user4563
Post by user4563 »
Thank you... I did replace the link to download "domoticz_linux_2023.2_x86_64.tgz". Are you aware of anything else required to change in the script?
gizmocuz
Post by gizmocuz »
Why would you need/want to run such an old version?
user4563
Post by user4563 »
I want v2023.2 due to OpenZWave. When OpenZWave was added back it lost some capability with my older thermostats. This is the easier path for now versus replacing thermostats or when I finally migrate to ZWaveJS.
user4563
Post by user4563 »
Ok after first installing libssl1.1 ( viewtopic.php?t=42200 ) and then changing the line in the script it did install 2023.2 successfully.
However, OZW is not in the list. Wasn't v2023.2 the last version to have it?
Screenshot 2024-12-27 171439.jpg (70.61 KiB) Viewed 2821 times
gizmocuz
Post by gizmocuz »
OpenZWave is in the latest version.
But better to migrate to ZwaveJS-UI with MQTT Auto Discovery, and while your doing so, maybe switch to the docker compose version of Domoticz as well so you don't have issues with ssl libraries in the feature
user4563
Post by user4563 »
gizmocuz wrote: Saturday 28 December 2024 15:18 OpenZWave is in the latest version.
I completely agree and the migration to ZwaveJS-UI will be something I will have to tackle in the future.
I tried the latest versions with the return on OpenZWave and for some reason the thermostat modes and fans do not display in the "Utility" tab. If I downgrade they come back. Since OZW hasn't changed something changed in the program from v2023.2 to v2024.2. Nothing stood out in the changlogs. Any idea what changed or how to solve?
v2024.7 :
Screenshot 2024-12-30 144041.jpg (195.44 KiB) Viewed 2727 times
v2023.1 :
Screenshot 2024-12-30 153959.jpg (314.44 KiB) Viewed 2727 times
