Instal with install.domoticz.com wont work
Kouki31
Post by Kouki31 »
Hello.
i have to install domoticz.
but when i do sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: You are root.
bash: line 101: test: /etc/os-release:22.04: integer expression expected
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: There are 74 updates available for your system!
::: We recommend you run 'apt-get upgrade' after installing Domoticz!
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev... installed!
:::    Checking for libssl1.1...user@domoticz:~$
and its all..
can you help me ?
Domoticz version: 2025.1
Re: Instal with install.domoticz.com wont work
Perhaps run below command first as it seems your system is not updated for a long time (74 updates in queue)
sudo apt-get upgrade
Kouki31
Post by Kouki31 »
thanks.
i try now.
but i try on debian, ubuntu and its same...
reply
i update
and same
PS its new installation.
thanks for your help
user@domoticz:~$ sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: You are root.
::: Your system is up to date! Continuing with Domoticz installation...
ChrisVH1982
Post by ChrisVH1982 »
I am facing the same issue and I am wondering who can help to resolve this issue.
Perhaps try to install libssl1.1 first and then install Domoticz.
This has been changed recently in the install script as newer systems use libssl3. Domoticz needs still the old libssl1.1.
sudo apt-get install libssl1.1
ChrisVH1982
waltervl wrote: Sunday 07 April 2024 14:30 Perhaps try to install libssl1.1 first and then install Domoticz.
You are a legend!
The command you provided did not work out but I found something adequate:
wget http://ports.ubuntu.com/pool/main/o/ope ... _arm64.deb
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2_arm64.deb
After installing libssl1.1 I indeed managed to install Domoticz without any issues. Thank you so much!
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Let it be here
For Ubuntu 22.04
sudo wget http://security.ubuntu.com/ubuntu/pool/ ... _amd64.deb
Sudo dpkg -i libssl1.1_1.1.1-1ubuntu2.1~18.04.23_amd64.deb
Kouki31
Post by Kouki31 »
hello thanks its work very well !!!
cool53
Post by cool53 »
It does not work on my LTS 2024 ubuntu. The libssl1.1 states it is not a deb package.
Frustrating, Domoticz worked well on my ubuntu server, but that seems to be over now.
You can go the docker way or install libssl1.1 manually first.
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
For a debian 12 system you can the following
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb10u6_amd64.deb
dpkg -i libssl1.1_1.1.1n-0+deb10u6_amd64.deb
user4563
Post by user4563 »
cool53 wrote: Wednesday 06 November 2024 19:26 It does not work on my LTS 2024 ubuntu. The libssl1.1 states it is not a deb package.
Try as superuser
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
gizmocuz
Post by gizmocuz »
Using Domoticz in a docker compose container solves this issue as well.
After the next stable release we will force an upgrade to the new debian/ssl
