Python plugin: We-connect VW ID3
Andreotti
Domoticz version: latest
Post by Andreotti »
Hi, I made a Domoticz plugin to read my VW ID.3 battery percentage and distance left.
It is not perfect, but it is working. There's room for expansion and improvement.
Download the code section. Name it plugin.py and place it in /home/pi/domoticz/plugins/we-connect
Make sure chmod is 644
You need weconnect-cli for Python. Install steps are in the code.
I had to make a small change in the API code to get it working. See readme.txt attachment
# We-connect - Volkswagen group - Domoticz plugin
# Tested with my VW ID.3
# Author: Andreotti 2024
# Uses: Python API for the Volkswagen WeConnect Services
# Web: https://github.com/tillsteinbach/WeConnect-python
# Setup We-connect API on Raspberry Pi
# apt install python3-pip
# pip3 install weconnect-cli
# When you get this error: "externally-managed-environment"
# pip3 install weconnect-cli --break-system-packages
# Test:
# weconnect-cli --username 'email' --password 'my_password'
# P.S. the check for the right VIN is not working for some reason!
<plugin key="We-connect" name="We-connect" author="Andreotti" version="1.0.0" >
  <description>
    <p>VIN is optional. Use it if you have more then one car connected in your app.</p>
    Credentials:
  </description>
  <params>
    <param field="Username" label="Username" width="150px"/>
    <param field="Password" label="Password" width="150px" default="" password="true"/>
    <param field="VIN" label="VIN (optional)" width="150px"/>
  </params>
</plugin>
import Domoticz
from weconnect import weconnect
class BasePlugin:
  runAgain = 1
  def __init__(self):
    return
  def onStart(self):
    if len(Devices) == 0:
      Domoticz.Device(Name="Battery", Unit=1, Type=243, Subtype=6, Switchtype=0).Create()
      Domoticz.Device(Name="Distance", Unit=2, TypeName="Custom", Options={"Custom": "1;km"}).Create()
      Domoticz.Log("Created device: ")
  def onStop(self):
    return
  def onDisconnect(self, Connection):
    return
  def onHeartbeat(self):
    self.runAgain = self.runAgain - 1
    if (self.runAgain > 0):
      return
    self.runAgain = 60  # 1x per 5 minuten checken (60 x 5 sec)
    weConnect = weconnect.WeConnect(username=Parameters["Username"], password=Parameters["Password"], updateAfterLogin=False, loginOnInit=False)
    if (weConnect):
      try:
        weConnect.login()
        weConnect.update()
      except Exception as e:
        Domoticz.Log(f"Error during weConnect update: {str(e)}")
        return
      try:
        for vin, vehicle in weConnect.vehicles.items():
          # if (Parameters["VIN"] == "" or vin == Parameters["VIN"]):
            if "charging" in vehicle.domains and "batteryStatus" in vehicle.domains["charging"]:
              Devices[1].Update(nValue=0, sValue=str(vehicle.domains["charging"]["batteryStatus"].currentSOC_pct.value))
              Devices[2].Update(nValue=0, sValue=str(vehicle.domains["charging"]["batteryStatus"].cruisingRangeElectric_km.value))
        Domoticz.Log(f"Error reading weConnect data: {str(e)}")
        return
    weConnect = None
global _plugin
_plugin = BasePlugin()
def onStart():
  global _plugin
  _plugin.onStart()
def onStop():
  global _plugin
  _plugin.onStop()
def onDisconnect(Connection):
  global _plugin
  _plugin.onDisconnect(Connection)
def onHeartbeat():
  global _plugin
  _plugin.onHeartbeat()
This fits my needs, but change it if you want to.
readme.txt
(1.19 KiB) Downloaded 61 times
Domoticz version: 2026.3
Re: Python plugin: We-connect VW ID3
Thanks for creating the plugin. It would be helpfull if you put the plugin on GitHub as every other plugin is there. It is easier to trackand download future changes in the plugin (user can do a git pull) than here on the forum.
Andreotti
Post by Andreotti »
I added the project to github:
https://github.com/Andreotti100/We-connect
