I have a motion sensor from Aqara. Its not what i expected.
But i read that with zha you can change settings.
I use a rflink and domoticz and have no idea how to adjust the settings
Please help
Gert
Aqara motion sensor settings
FlyingDomotic
- Domoticz version: 2020.2
Re: Aqara motion sensor settings
ZHA stands for ZigBee Home Automation. So protocol is ZigBee.
Rflink protocol is 433 (and sometimes 868) MHz. You may eventually add a NRFL01 to support MiLight protocol. But no ZigBee.
ensingg
But my sensor is connected using rflink 433 to domoticz.
Anyway to configure aqara sensors?
FlyingDomotic
What kind (reference) of aqara sensor do you have?
ensingg
In this case its the vibration sensor and i like to change sensitivity
FlyingDomotic
Are you using a DJT11LM Aqara vibration sensor?
If not, what's the exact reference of you sensor?
ensingg
Ean 6970504212527
Cannot find your type
Box says Aqara vibration sensor
claude2666
I can see from the ean number that is clearly an Aqara Zigbee sensor.
https://www.zigbee2mqtt.io/devices/DJT1 ... ra-djt11lm
You can update the sensitivity in the Zigbee UI. Before you update the settings, you need to wake up the device by pressing the button on it.
And then change the sensitivity to the desired setting.
- Capture.JPG (44.32 KiB) Viewed 2172 times
FlyingDomotic
EAN 6970504212527 is clearly a ZigBee device. It should be managed by a Zigbee coordinator. Unless you have a bridge between ZigBee and 433 MHz (I never saw one, but this can even perhaps exist), there's no way to get it from RFlink.
Could you send us a print screen of this device line into "Setup" > "Device" menu?
You may have a ZigBee coordinator somewhere, it could be a good idea to use it to setup device sensibility.
