Domoticz.log location [solved]
Backbone
- Domoticz version: 2023.2
When I check my log from the settings menu I see a constant data stream filling the log.
But that is a very low fill in. once every 20 seconds or so. No important data. Just scripts starting, weather info data and so on.
When I start a Dzvents thermostat script I created the log is filled every milisecond or so with a line.
I am now assuming that the higher data stream could fill up the store location so quickly Domoticz will lock up.But could be wrong.
So I googled to see where the domoticz.log file could be stored and I had one hit.
/var/log/domoticz.log
However I can find that file on that location when I check with WINSCP.
Any assistance would be appricated.
Paco
Paco
- Domoticz version: 2026.3
Re: Domoticz.log location
It seems you use windows as OS?
Logging to a file is by default disabled because it can become a large file. With a reinstall you can enable the logging to a file.
If you use Linux you can use the instruction in the troubleshooting wiki to switch log to a file on. https://www.domoticz.com/wiki/Troubleshooting
But also every hardware gateway (menu setup - hardware) has settings to switch off log, status and/or error logging. So this would help if one of your hardware gateways is spamming the log a lot.
Also for dvents it depends on the script how much logging you get. Perhaps switch off log statements in the script (add -- before the log line in the script).
Also you can set the log level per script (info, status, error, debug).
Check the log template example to play with this. This is butt the way implemented in 2024.7
i looked for the domoticz.log file, but i could not find it in the /var/log location.
What is the problem:
I have several computers and all except one are able to remotely log in into domoticz. One computer give the login-error "name and/or password" are not correct, but they are correct, other computers can log in. Offcourse I cleared the browser-cache.
So i searched for a log-file in which i can see who is logged in into domoticz and which user is refused and why.
Where to look for that logfile?
Thanks.
Paul
Thanks.
Paul
- jvdz
- Domoticz version: 4.107
Have you looked at the linked wiki page, where it is explained how to generate the log file?
https://www.domoticz.com/wiki/Troublesh ... _log_files
It could very well be that it is not defined thus not generated.
yes, i did
cd domoticz
sudo service domoticz stop
Test if domoticz can be started by hand:
./domoticz
but starting domoticz by hand genereated a lot of error-lines not knowing how to solve.
cd domoticz
./domoticz
pi@raspberrypi:~ $ cd domoticz
pi@raspberrypi:~/domoticz $ ./domoticz
2024-10-20 16:01:05.968 Status: Domoticz V2024.3 (build 15878) (c)2012-2024 GizMoCuz
2024-10-20 16:01:05.969 Status: Build Hash: 29128d91b, Date: 2024-01-27 15:49:44
2024-10-20 16:01:05.969 Status: Startup Path: /home/pi/domoticz/
2024-10-20 16:01:06.002 Sunrise: 08:17:00 SunSet: 18:35:00
2024-10-20 16:01:06.003 Day length: 10:18:00 Sun at south: 13:26:00
2024-10-20 16:01:06.003 Civil twilight start: 07:42:00 Civil twilight end: 19:10:00
2024-10-20 16:01:06.003 Nautical twilight start: 07:02:00 Nautical twilight end: 19:49:00
2024-10-20 16:01:06.003 Astronomical twilight start: 06:22:00 Astronomical twilight end: 20:29:00
2024-10-20 16:01:06.125 Status: PluginSystem: Started, Python version '3.9.2', 1 plugin definitions loaded.
2024-10-20 16:01:06.134 Active notification Subsystems: email, pushover (2/13)
2024-10-20 16:01:06.152 Status: WebServer(HTTP) startup failed on address :: with port: 8080: bind: Address already in use [system:98 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying ::
2024-10-20 16:01:06.153 Status: WebServer(HTTP) startup failed on address :: with port: 8080: bind: Address already in use [system:98 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying 0.0.0.0
2024-10-20 16:01:06.154 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8080: bind: Address already in use [system:98 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind']
2024-10-20 16:01:06.154 Error: WebServer(HTTP) check if no other application is using port: 8080
2024-10-20 16:01:06.161 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying ::
2024-10-20 16:01:06.164 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying 0.0.0.0
2024-10-20 16:01:06.166 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind']
2024-10-20 16:01:06.166 Error: WebServer(SSL) check privileges for opening ports below 1024
terminate called without an active exception
2024-10-20 16:01:06.169 Error: Domoticz(pid:224929, tid:224929('domoticz')) received fatal signal 6 (Aborted)
2024-10-20 16:01:06.169 Error: siginfo address=0x3e800036ea1, address=0x7ff2fc83b8
2024-10-20 16:01:08.327 Error: Did not find stack frame for thread (LWP 224929)), printing full gdb output:
2024-10-20 16:01:08.327 Error: > [New LWP 224931]
2024-10-20 16:01:08.328 Error: > [New LWP 224932]
2024-10-20 16:01:08.328 Error: > [New LWP 224933]
2024-10-20 16:01:08.328 Error: > [New LWP 224934]
2024-10-20 16:01:08.328 Error: > [Thread debugging using libthread_db enabled]
2024-10-20 16:01:08.328 Error: > Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
2024-10-20 16:01:08.328 Error: > 0x0000007f899f083c in __GI___wait4 (pid=<optimized out>, stat_loc=0x7ff2fc6d44, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2024-10-20 16:01:08.329 Error: > 27 ../sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
2024-10-20 16:01:08.329 Error: > Id Target Id Frame
2024-10-20 16:01:08.329 Error: > * 1 Thread 0x7f88e14b40 (LWP 224929) "domoticz" 0x0000007f899f083c in __GI___wait4 (pid=<optimized out>, stat_loc=0x7ff2fc6d44, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2024-10-20 16:01:08.329 Error: > 2 Thread 0x7f88832f40 (LWP 224931) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.329 Error: > 3 Thread 0x7f88031f40 (LWP 224932) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.329 Error: > 4 Thread 0x7f872a4f40 (LWP 224933) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.329 Error: > 5 Thread 0x7f86aa3f40 (LWP 224934) "MQTTPush" syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.330 Error: >
2024-10-20 16:01:08.330 Error: > Thread 5 (Thread 0x7f86aa3f40 (LWP 224934) "MQTTPush"):
2024-10-20 16:01:08.330 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.330 Error: > #1 0x000000556c2a64c0 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2024-10-20 16:01:08.330 Error: > #2 0x000000556bce8e84 in CMQTTPush::Do_Work() ()
2024-10-20 16:01:08.330 Error: > #3 0x000000556c2a41dc in execute_native_thread_routine ()
2024-10-20 16:01:08.330 Error: > #4 0x0000007f89bc6648 in start_thread (arg=0x7f86aa3840) at pthread_create.c:477
2024-10-20 16:01:08.330 Error: > #5 0x0000007f89a1ec9c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
2024-10-20 16:01:08.330 Error: > Thread 4 (Thread 0x7f872a4f40 (LWP 224933) "InfluxPush"):
2024-10-20 16:01:08.331 Error: > #2 0x000000556bce3ebc in CInfluxPush::Do_Work() ()
2024-10-20 16:01:08.331 Error: > #3 0x000000556c2a41dc in execute_native_thread_routine ()
2024-10-20 16:01:08.331 Error: > #4 0x0000007f89bc6648 in start_thread (arg=0x7f872a4840) at pthread_create.c:477
2024-10-20 16:01:08.331 Error: > #5 0x0000007f89a1ec9c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
2024-10-20 16:01:08.331 Error: > Thread 3 (Thread 0x7f88031f40 (LWP 224932) "PluginMgr"):
2024-10-20 16:01:08.331 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.331 Error: > #1 0x000000556c2a64c0 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2024-10-20 16:01:08.331 Error: > #2 0x000000556c00179c in Plugins::CPluginSystem::Do_Work() ()
2024-10-20 16:01:08.331 Error: > #4 0x0000007f89bc6648 in start_thread (arg=0x7f88031840) at pthread_create.c:477
2024-10-20 16:01:08.332 Error: > Thread 2 (Thread 0x7f88832f40 (LWP 224931) "SQLHelper"):
2024-10-20 16:01:08.332 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
2024-10-20 16:01:08.332 Error: > #1 0x000000556c2a64c0 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2024-10-20 16:01:08.332 Error: > #2 0x000000556bc13c6c in CSQLHelper::Do_Work() ()
2024-10-20 16:01:08.332 Error: > #3 0x000000556c2a41dc in execute_native_thread_routine ()
2024-10-20 16:01:08.332 Error: > #4 0x0000007f89bc6648 in start_thread (arg=0x7f88832840) at pthread_create.c:477
2024-10-20 16:01:08.332 Error: > #5 0x0000007f89a1ec9c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
2024-10-20 16:01:08.332 Error: > Thread 1 (Thread 0x7f88e14b40 (LWP 224929) "domoticz"):
2024-10-20 16:01:08.332 Error: > #0 0x0000007f899f083c in __GI___wait4 (pid=<optimized out>, stat_loc=0x7ff2fc6d44, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2024-10-20 16:01:08.332 Error: > #1 0x000000556bbfca00 in dumpstack_gdb(bool) ()
2024-10-20 16:01:08.333 Error: > #2 0x000000556bbfcfbc in signal_handler(int, siginfo_t*, void*) ()
2024-10-20 16:01:08.333 Error: > #3 <signal handler called>
2024-10-20 16:01:08.333 Error: > #4 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2024-10-20 16:01:08.333 Error: > #5 0x0000007f8996da60 in __GI_abort () at abort.c:79
2024-10-20 16:01:08.333 Error: > #6 0x000000556c2aaae0 in __gnu_cxx::__verbose_terminate_handler() ()
2024-10-20 16:01:08.333 Error: > #7 0x000000556c2248ac in __cxxabiv1::__terminate(void (*)()) ()
2024-10-20 16:01:08.333 Error: > #8 0x000000556c2248f8 in std::terminate() ()
2024-10-20 16:01:08.333 Error: > #9 0x000000556bb79d18 in std::_Sp_counted_ptr_inplace<std::thread, std::allocator<std::thread>, (__gnu_cxx::_Lock_policy)2>::_M_dispose() ()
2024-10-20 16:01:08.333 Error: > #10 0x000000556bb7c55c in std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release() ()
2024-10-20 16:01:08.333 Error: > #11 0x000000556bbd65dc in CMQTTPush::~CMQTTPush() ()
2024-10-20 16:01:08.333 Error: > #12 0x0000007f8998376c in __run_exit_handlers (status=1, listp=0x7f89abc688 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at exit.c:108
2024-10-20 16:01:08.333 Error: > #13 0x0000007f899838fc in __GI_exit (status=<optimized out>) at exit.c:139
2024-10-20 16:01:08.333 Error: > #14 0x0000007f8996dddc in __libc_start_main (main=0x556bb11370 <main>, argc=1, argv=0x7ff2fc88b8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=<optimized out>) at ../csu/libc-start.c:342
2024-10-20 16:01:08.334 Error: > #15 0x000000556bb3c740 in _start ()
2024-10-20 16:01:08.334 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2024-10-20 16:01:08.334 Error: > Main thread:
2024-10-20 16:01:08.334 Error: > #0 0x0000007f899f083c in __GI___wait4 (pid=<optimized out>, stat_loc=0x7ff2fc6d44, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2024-10-20 16:01:08.334 Error: > #1 0x000000556bbfca00 in dumpstack_gdb(bool) ()
2024-10-20 16:01:08.334 Error: > #2 0x000000556bbfcfbc in signal_handler(int, siginfo_t*, void*) ()
2024-10-20 16:01:08.334 Error: > #3 <signal handler called>
2024-10-20 16:01:08.334 Error: > #4 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2024-10-20 16:01:08.334 Error: > #5 0x0000007f8996da60 in __GI_abort () at abort.c:79
2024-10-20 16:01:08.334 Error: > #6 0x000000556c2aaae0 in __gnu_cxx::__verbose_terminate_handler() ()
2024-10-20 16:01:08.334 Error: > #7 0x000000556c2248ac in __cxxabiv1::__terminate(void (*)()) ()
2024-10-20 16:01:08.335 Error: > #8 0x000000556c2248f8 in std::terminate() ()
2024-10-20 16:01:08.335 Error: > #9 0x000000556bb79d18 in std::_Sp_counted_ptr_inplace<std::thread, std::allocator<std::thread>, (__gnu_cxx::_Lock_policy)2>::_M_dispose() ()
2024-10-20 16:01:08.335 Error: > #10 0x000000556bb7c55c in std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release() ()
2024-10-20 16:01:08.335 Error: > #11 0x000000556bbd65dc in CMQTTPush::~CMQTTPush() ()
2024-10-20 16:01:08.335 Error: > #12 0x0000007f8998376c in __run_exit_handlers (status=1, listp=0x7f89abc688 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at exit.c:108
2024-10-20 16:01:08.335 Error: > #13 0x0000007f899838fc in __GI_exit (status=<optimized out>) at exit.c:139
2024-10-20 16:01:08.335 Error: > #14 0x0000007f8996dddc in __libc_start_main (main=0x556bb11370 <main>, argc=1, argv=0x7ff2fc88b8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=<optimized out>) at ../csu/libc-start.c:342
2024-10-20 16:01:08.335 Error: > #15 0x000000556bb3c740 in _start ()
2024-10-20 16:01:08.335 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2024-10-20 16:01:08.335 Error: > [Inferior 1 (process 224929) detached]
Aborted
Backbone
Hi Walter,
As far as my knowledge goes I switched off all logging options as you described.
Problem of the filling of the log starts as soon as I start the DZvents script as written below and change the setting manual of a "switch".
Without changing the Switch output the logging is regular.
When I want to abort the logging I have to wait around 10 seconds as domoticz seems to be busy still with the logging.
After this 10 seconds the script screen appears and I can stop the script from running.
Any suggestion or should I put this problem in the DZvents section?
Thanks, Paco
on =
devices = {'Thermostat_Control', 'Heater_Switch', 'Temp_Kamer','Setpoint_Regular' },
timer = {'every minute'},
execute = function(dz)
--local Vartemp = dz.variables('Vartemp') --declared as float value
local Thermostat = dz.devices('Thermostat_Control') -- =idx69
local Switch = dz.devices('Heater_Switch') -- =idx67
local Roomtemp = dz.devices('Temp_Kamer') -- =idx32
local Setpoint_Regular = dz.devices('Setpoint_Regular') -- =idx68
-- "Uit" mode active initiated by thermostat switchselector at level 0
if dz.devices(69).level == 0 then
dz.devices(67).switchOff()
-- "Normaal" mode active initiated by thermostat switchselector at level 10
if dz.devices(69).level == 10 then
if dz.time.matchesRule ('at 00:00-23:59') then
if dz.devices(32).temperature < dz.devices(68).setPoint then
dz.devices(67).switchOn()
}Thanks, Paco
- domoticz dzvents log.JPG (220.1 KiB) Viewed 4110 times
It seems that one of the triggered devices, probably 'Heater_switch', is updated every second so your script is triggered every second. You could remove it from the trigger device list if that is possible for your script
It could be that the dzvents script is doing the trigger itself due to the switching perhaps add a checkfirst() command option before switching.
dz.devices(67).switchOff().checkFirst()Domoticz running on Udoo X86 (on Ubuntu)
Backbone
Re: Domoticz.log location [solved]
Got it solved.
Paco
return
on =
dz.devices(67).switchOn().checkFirst()
