janpep wrote: ↑Friday 04 October 2024 9:17
I will have a look at it later and let you know.
Just looked at it and did a quick test.
1. I did not count the pixels and filesize of the files in the ZIP that is created by the mentioned icon generator, but I can confirm now that it generates the icons 50 x 50 pixels. Nevertheless that does not seem a problem, as it is working fine here.
2. I can confirm that the ON and OFF images that are created have content, as can be seen in the posted example. The other image is indeed 0 kb. I did not notice before. See that this is the case for all of them. I quess this file is not used in the current situation, because I am not aware that miss anything.
3. I thougbht that may be I imported these files in previous version and something has changed meanwhile.
So for testing I added one of the files for a second time after remaning. This goes without a problem.
My preliminary conclusion is that the 50x50 pixels and the mentioned empty png file are not a problem. At least not for me.
What should perhaps be mentioned is that I had a problem uploading icon files several times. It turned out that I had to do a refresh beforehand. However, this is unrelated to the files in question.
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
